Ultra 94 (94 Octane) Fuel
Old Jun 26, 2014 | 01:06 PM
FreshmanProfessor's Avatar
7th Gear
Does anyone know if there are any issues with using 94 octane fuel? I find that my car runs better with it over Premium (91 octane), but want to make sure I'm not damaging my engine.
Old Jun 26, 2014 | 01:18 PM
oo7spy's Avatar
Low octane will cause early detonation and engine knock (a.k.a. ping). High octane fuel will not. The RL is designed for 91 octane. TX only offers 87, 89, & 93, so I ran 93. The RL does have an engine knock sensor that will retard timing (and performance) to accommodate low octane fuel. I am assuming you are asking about your ILX, and I cannot comment on the recommended octane or any protection modes in that car.
How are you quantifying that your "car runs better"?
Old Jun 26, 2014 | 01:59 PM
lift3d_'s Avatar
rock the block
for an ILX, i'd say you're just spending more than you have to, but if you feel it is better in some indescribable way, nothing is stopping you.
Old Jun 26, 2014 | 02:01 PM
Ken1997TL's Avatar
You'll be fine. 94 octane is meant for sea level. So don't bring a can of it with you to Colorado!
UA6's Avatar
UA6
Unless you shaved seconds off of your 1/4 mile time on a track, it might just be all in your head. The same feeling you get when you throw on a CAI and it feels like your car is supercharged.
Old Jun 26, 2014 | 02:43 PM
All Acuras run on high compression engines.
it would be better to run a higher octane than a lower one.
Old Jun 26, 2014 | 02:52 PM
oo7spy's Avatar
The K24Z7 in the ILX has an 11:1 compression which matches the K24Z3 in the 2008-12 Accord. Did the Accord require 91 or higher? That would seem counter-intuitive to the idea of making an I4 Accord.
Old Jun 26, 2014 | 03:09 PM
thisaznboi88's Avatar
Run premium is it says to run it. Accord run regular because they retard the craps out of the timing
Old Jun 26, 2014 | 03:13 PM
Costco's Avatar
It was probably designed to run on 93/94 octane (AKI) but the computer will compensate and pull timing for 91, especially in hot weather.
Some cars have improved performance and gas mileage with 93 vs. 91, but it varies. There are many, many more areas with 93 available vs. 91.
Old Jun 26, 2014 | 03:15 PM
ECU tuning also plays a role.
I know the Acura's have more aggressive timing than their Honda counterparts.
Old Jun 26, 2014 | 04:53 PM
CLpower's Avatar
teh Senior Instigator
Motortrend did an article back int he late 90's with an accord with the J30. Did dyno testing on 87/89/91
87 performed the best in terms of power.
Old Jun 26, 2014 | 07:24 PM
SuperTrooper169's Avatar
In the Mid-South meow
^ Late 90s maybe but a Honda engineer said the J30 in the 7th gen Accords made 10 more hp using premium over regular gas.
Old Jun 26, 2014 | 08:22 PM
7th Gear
Thanks for all the replies! I'm glad that the higher octane will not make a difference in terms of wear and tear (and may actually be better according to some). We have 91 and 94 available here and there is basically no price difference.
As for the quantification of the difference in performance… it's probably all in my head, but it just seems like my engine sounds like its not working as hard (i.e. running smoother) when I use 94.
Old Jun 26, 2014 | 08:50 PM
His right and I have the article from them that prove it also
joflewbyu2
Aug 18, 2019 10:38 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
joflewbyu2
Oct 8, 2015 11:16 AM
San Yasin
Sep 29, 2015 10:52 AM
