Tyler's Owdi B5 S4 Build & Update(s) Thread
Old 05-21-2018, 10:02 AM
  #1801
GEEZER
1killercls's Avatar
Received 2,214 Likes on 1,418 Posts
Originally Posted by SamDoe1
What was the code?
Hell if I remember it was over a year ago. No problems since.
Old 05-21-2018, 11:08 AM
  #1802
Turd Polisher
TylerT's Avatar
Received 3,017 Likes on 1,515 Posts
I have a used OEM Bosch alternator on the way .. should be here this week.
Old 05-21-2018, 12:02 PM
  #1803
Received 6,060 Likes on 3,980 Posts
Well I have no idea then. The N80 is definitely not a fuel line check valve though. The only explanation I have for your situation is that the valve was stuck closed and increasing the amount of time to build pressure and also not pumping fumes into the fuel rail at start up.
Old 05-21-2018, 01:06 PM
  #1804
CCColtsicehockey's Avatar
Received 3,773 Likes on 2,546 Posts
Jeez...
remove the 3 15's and the xtant amp and you should be fine...
man I haven't heard xtant in forever
Old 05-25-2018, 08:13 PM
  #1805
rockstar143's Avatar
Received 19,986 Likes on 14,496 Posts
I'm old!
Old 05-29-2018, 10:54 AM
  #1806
Turd Polisher
TylerT's Avatar
Had some time on Saturday / Monday to work on the ETH FO and fixed my pestering voltage issue.
Sorry for the long winded post:
A word of advice from an idiot: Don't throw parts at an issue because you have a "hunch". Had I done a bit more troubleshooting & tried cheaper options, I would have fixed my voltage issue for $4 dollars in less than 10 minutes of work versus the 3 1/2 hours & $60 spent on swapping in a used / working OEM Alternator.
Long story short - ever since I pulled my motor back in October, my car's electrical system has been weak. With the car started and the alternator churning, you should be seeing between 13.5v-14v. Under battery power, 12v.
I would notice that when I first started the car, it would be at around 14v but as I started packing on the accessories like AC / headlights / heated seats, the voltage would drop just at about 12.5v, sometimes even lower under full throttle. It was not enough to trip the battery light and just enough to charge the battery.
Stumped, I cleaned both terminals / I cleaned & verified all of my grounds were tight (Main ground goes from the negative on the battery terminal to the body, other primary ground goes from the framerail to the bottom motormount bracket, and there are another 2 that connect on the secondary firewall / inside of the cabin)
My battery is less than 6 months old, so I figured my 135,000 mile alternator was the issue.
Wrong.
One of my factory grounds must have failed to the point where voltage was dissipating / escaping.
I went to Home Depot and picked up some 8 gauge wire. I ran it from the primary framerail ground connection to a bolt holding on the larger upper motormount bracket against the block and voila, voltage has stabilized.
So pissed ... yet so happy
I also washed her up and detailed the interior.
No updates as of new files / revisions ... hopefully soon.
Old 05-29-2018, 10:59 AM
  #1807
shit yes, Tyler...
I love simple fixes...
sometimes I sit there, usually at night...for some reason with a fleshlight on my head (pzel or whatever) and some solitude...I can kinda think clearly and trace wires back and look and figure shit out.
The following 2 users liked this post by rockstar143:
Aman (07-21-2018), TylerT (05-29-2018)
Old 05-29-2018, 11:40 AM
  #1808
Turd Polisher
TylerT's Avatar
shit yes, Tyler...
Minus the fleshlight, I do the same. exact. thing.
In this case, all that thinking lead me to swapping the alternator when the grounding was in fact the issue all along.
Live and learn!
Old 05-29-2018, 11:46 AM
  #1809
I should check mine...yukon started slowly today and i know for a fact the battery is new and the alternator looks newish
Old 05-29-2018, 11:59 AM
  #1810
Turd Polisher
TylerT's Avatar
It's possible - funny you mention that because .. I noticed that the S4 was starting a lot more quickly / consistently now that the electrical system is basically on viagra now.
I noticed the Yukon had a little rust so ... corroded / weak grounds make for a weak electrical system. Fairly certain 13.5v-14v is the target voltage for most cars so, grab your multi-meter and measure what your voltage is at the positive terminal while the car is on.
Old 05-29-2018, 01:26 PM
  #1811
Turd Polisher
TylerT's Avatar
I'm getting a new tune tonight ... one step closer to E85.
Old 05-29-2018, 01:28 PM
  #1812
Old 06-04-2018, 01:41 AM
  #1813
Turd Polisher
TylerT's Avatar
Good weekend on the S4.
These cars are never ending projects ... just once you have one thing fixed you discover something else that needs refreshing
I've been running on a busted CV boot for a few months but finally got it rebuilt with the help of a friend. What a messy job... my only goal was not tracking in any kind of axle grease into the house .. that's for sure
Disassembled:
Funny thing was, I didn't get any other pictures because my hands were so dirty ... lol.
Following that, I picked up my R8 ignition coil conversion .. huge upgrade as power levels start to increase. I noticed my AFR lean up a bit because all fuel coming from the injectors was being used
After the ignition system upgrade, I spent about 2 hours sending logs & receiving revisions. Car is definitely faster .. I would say I have around 3-4 more files until 91 octane is completed and we move to doing a whole other e85 tune.
Slowly but surely.
Old 06-04-2018, 02:06 AM
  #1814
Turd Polisher
TylerT's Avatar
Here's a quick pull in 3rd & 4th gear.
Doesn't seem much faster than my last video but yeah, I can tell an immediate difference .. especially after 6000rpm.
The following 3 users liked this post by TylerT:
1killercls (06-14-2018), Predatorbird (06-04-2018), SuperTrooper169 (06-05-2018)
Old 06-04-2018, 06:39 AM
  #1815
definitely not slowly.
also, don't call me shirley.
TylerT (06-04-2018)
Old 06-04-2018, 10:40 AM
  #1816
Turd Polisher
TylerT's Avatar
Current mod list to date:
Tuned by ETSpec
85mm Intake w/ Hitachi MAF
Frankenturbo K04 hybrids
Wagner Intercoolers
APR Bi-Pipe w/ 3 BAR Map sensor
Walbro 450 w/ Racetronix harness upgrade
750CC EV14 injectors
R8 coil conversion upgrade w/ ICM deletes
NGK Iridium IX BKR7EIX @ .025
SSAC 3" Downpipes w/ 3" Miltek 2 muffler catback
FX400 6 puck clutch w/ new OEM Dual Mass Flywheel
AEM X series wideband w/ Glowgift mechanical boost gauge
Bilstein shocks w/ Eibach lowering springs
EBC Red stuff w/ StopTech Blank rotors
ECS Inline Fuel pressure gauge
STERN transmission mounts w/ RS4 engine mounts
SWEDIT headliner (Thanks Jin!)
Old 06-04-2018, 12:36 PM
  #1817
Bird is the Word
Predatorbird's Avatar
It's def pulling hard at those speeds. It's going to be a monster on e85!
TylerT (06-04-2018)
Old 06-04-2018, 01:43 PM
  #1818
Turd Polisher
TylerT's Avatar
A fully custom tune done remotely can be kind of frustrating ...
Good news is .. I got 4 different revisions on the car this weekend - but it took anywhere from a 1 hour response, to 12 hours to get a revised file once I submit my logs. Southern California isn't exactly known for having wide open freeways so I have a designated area to do a full 3rd / partial 4th gear pull.
First world problems but, I have a feeling it's going to take at least another week or two before E85 is really a possibility.
Old 06-04-2018, 05:12 PM
  #1819
oonowindoo's Avatar
Received 4,273 Likes on 3,050 Posts
looking good...
How much have you spent on it already without labor of course... since you are free
TylerT (06-04-2018)
Old 06-04-2018, 05:57 PM
  #1820
Turd Polisher
TylerT's Avatar
Let’s just say I just entered 5 digits recently ... that includes tools, all maintenance, and Stage 3.
Old 06-04-2018, 06:29 PM
  #1821
oonowindoo's Avatar
You better keep that thing for a long time because you know you aint getting that $$ back if you sell it.
TylerT (06-05-2018)
Old 06-04-2018, 07:39 PM
  #1822
Bird is the Word
That's a pretty quick turn around for revisions. When I was tuning the FoST, it would take approx a week to get a revision back from my tuner. I live in a good area where I can get some 3rd gear pulls in. 4th gear pulls are a little tough due to the speeds needed to reach redline.
TylerT (06-05-2018)
Old 06-05-2018, 09:21 AM
  #1823
In the Mid-South meow
SuperTrooper169's Avatar
Received 2,149 Likes on 1,096 Posts
Dude sooooooo glad to see things have finally fallen into place with your build! You're shooting for some massive numbers... and me likey. She's pulling hard in 3rd and 4th video.
TylerT (06-05-2018)
Old 06-05-2018, 10:00 AM
  #1824
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
Pfff the car is super slow. My TL pulls the same in 1st gear, the way Tyler's Audi pulls in 4th gear. He needs a faster car
TylerT (06-05-2018)
Old 06-05-2018, 10:35 AM
  #1825
that joke wasn't even funny in 2016.
I have a road to test out over 100 mph about 1/4 mile from home...
Corn fed for more head...order a custom decal for the rear
Old 06-05-2018, 10:43 AM
  #1826
Turd Polisher
TylerT's Avatar
Agreed. At this point, I don't plan on selling the car in the near future.
Maybe it's a combination of being a bit impatient / lack of communication from my tuner.
At the end of the day, I'm happy the car is getting done
Thanks much Todd! Stay tuned, more videos coming soon!
Old 06-05-2018, 10:47 AM
  #1827
Turd Polisher
TylerT's Avatar
I'm jealous.
I COULD go to the freeway and do logs but the risk of getting a ticket is high ... plus, I got a ticket about 6 months ago so .. I'd like my insurance rates to stay the same right now .
Despite being about 20 minutes away, the road I am doing logs on is great. It's a 4 lane road, no side streets, 1 mile straight, and a median separating oncoming traffic.
Old 06-05-2018, 11:02 AM
  #1828
I mean, I'm probably stating the obvious but the faster you go the harder you are to catch by the cops.
I bet once you get the E85 you can do all the pulls you want without much worry.
#gingerbreadracingteam
Old 07-20-2018, 11:38 PM
  #1829
Turd Polisher
TylerT's Avatar
Haven't had a ton of updates, but some subtle changes here and there.
Finally got myself an OEM RS4 grill ... sooo much better than my eBay one.
Random shot a month or so back:
Buffed and sealed my headlights & exterior door trim - they were beginning to look a bit oxidized.
4th of July morning cruise: (S4 badge added on RS4 grill)
So, after a few logs it revealed that my intake air temperatures were almost in the 65-70c range. If there's anything a turbocharged car DOESN'T like, it's hot air.
I had to improvise.
2 pieces of sheet metal & some gold reflective tape later, I cut my IATs down almost 20C at WOT after a few consecutive pulls.
Logs this morning indicated I am pulling 48c IATs at redline - this is roughly 7C hotter than the $500+ intake system 034 makes.
Could be better, but it'll do (for now).
Funny story about my ignition upgrade.
Once I reset my battery (which clears your fuel trims), the tune did not like the new ignition system ... at all. My AFRs leaned up quite a bit and we essentially needed to re-tune the car. I started that process this week ... slowly but surely
Fuel trims bang on:
Couple pictures from last weekend's detailing session.
Quick wash, detailing spray, cleaned the interior and used Plastic-X on all trim pieces ...
Thanks for reading!
I am going to hopefully finish up 91 octane this weekend .. I am literally a file or two away.
Old 07-21-2018, 12:28 PM
  #1830
CLtotheTL32's Avatar
Received 9,503 Likes on 6,173 Posts
TylerT (07-25-2018)
Old 07-23-2018, 06:51 AM
  #1831
Fuckin Sexy...
don't have kids...they will be a letdown in comparison to your car!
TylerT (07-25-2018)
Old 07-25-2018, 12:05 PM
  #1832
Turd Polisher
TylerT's Avatar
Fuckin Sexy...
Old 07-25-2018, 12:08 PM
  #1833
Turd Polisher
TylerT's Avatar
Well, the time has come. Been waiting for 7 months to get the car to this point!
I got my first E85 base tune a few days ago. I plan on flashing it tonight at the pump and going through the small bit of mixed 91 still left in there.
I’m expecting a solid whp & torque increase.
As promised, I’ll grab videos once the car is healthy enough to take a beating.
Old 07-25-2018, 12:14 PM
  #1834
bro, are you silly?
are you still gonna send it?
Old 07-26-2018, 02:00 PM
  #1835
Turd Polisher
TylerT's Avatar
Hopefully the image & Video imbeds okay, posting from mobile.
Car is officially on E85 as of yesterday.
Tuner says the car shouldn’t be faster because we haven’t put any additional ignition timing, but I think I picked up power.
The real fun starts when the cars fuel trims get dialed in and we move onward to finishing the tune.
Old 07-26-2018, 02:23 PM
  #1836
Received 5,464 Likes on 3,734 Posts
TylerT (07-27-2018)
Old 07-26-2018, 05:19 PM
  #1837
oonowindoo's Avatar
My 20-40 is just as fast as your 40-60...
TylerT (07-27-2018)
Old 07-26-2018, 06:38 PM
  #1838
TacoBello's Avatar
My 20-40 is just as fast as his 0-100
TylerT (07-27-2018)
Old 07-27-2018, 06:41 AM
  #1839
that needs sure goes up fast...
that's incredible
TylerT (07-27-2018)
Old 07-27-2018, 09:33 AM
  #1840
Turd Polisher
TylerT's Avatar
Thanks guys, I’ve never been more excited to get through a tank of gas.
Even with a few gallons of 91 in the tank, AFR is bang on and fuel trims are pretty much right where they should be so I cant imagine the tune will take more than 2-3 files.
I want to go M3 hunting ... 2 x e92s didn’t want to play this morning
Quick Reply: Tyler's Owdi B5 S4 Build & Update(s) Thread
