Tyler's Owdi B5 S4 Build & Update(s) Thread
Old 12-22-2017, 09:27 AM
  #1521
Turd Polisher
TylerT's Avatar
Received 3,006 Likes on 1,514 Posts
Originally Posted by SamDoe1
You better be keeping this thing for the rest of time at this point.
Despite all that has happened in the last 3 months, you could say I'm still pretty attached to it.
A solid Stage 3 K04 car is really all I want out of this.
Old 12-22-2017, 10:29 AM
  #1522
teh CL's Avatar
how?
Cliff notes:
- first car at 17 (97 2.2CL)
- "build" motor for car aka slap h22 head on f22 block (G22)..motor goes boom one block from home, pistons melted
- F20B swap CL few years down the road, get it street tuned, revving to 8k. Start hearing rattling noises. End up limping home in 1st gear for probably 15 miles. Flywheel bolts backed out and there were literally only 2 bolts still holding it in place. Ended up mangling the threads on the crank so I drilled out the threads and helicoiled it with the motor in the car.. .. then loctite the shit out of the new bolts ... still holding strong to this day..
I could go on but those were 2 memorable moments, get a good laugh every time I think about it. I could almost tear up thinking about it. Could of abandoned the car game which I was encouraged to by pretty much everyone but you could say I'm determined AF & here we are today. The next chapter is gonna be something to look back on, that's for sure.
The following 2 users liked this post by teh CL:
rockstar143 (12-22-2017), TylerT (12-22-2017)
Old 12-22-2017, 11:11 AM
  #1523
Turd Polisher
TylerT's Avatar
Originally Posted by teh CL
Cliff notes:
This makes me feel a bit better.
The incorrectly installed rear main seal & botched clutch install kinda hurt my pride a bit - to my credit, the rear main seal on the B5 S4 is an absolute bitch to do ... most say if it's not leaking, don't replace it or it'll potentially leak. Mine was leaking for some time and I had no choice.
The clutch issues to me is a total fluke. I have a hunch it's the pilot bearing, but there's really no telling until it's apart.
teh CL (12-22-2017)
Old 12-22-2017, 11:16 AM
  #1524
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
It may hurt your pride, but you just doubled down on your man card, pulling that sucka apart again
Old 12-22-2017, 11:39 AM
  #1525
Turd Polisher
TylerT's Avatar
If you gunna be dumb, you gotta be tough.
Old 12-22-2017, 11:46 AM
  #1526
teh CL's Avatar
If you don't want your pride hurt, get away from the car game, start running..
Cars will literally gut you emotionally, physically & financially but with that said, nothing is better than that first start after a swap or any kind of work for that matter. It's literally what keeps me going.
Old 12-22-2017, 11:54 AM
  #1527
oonowindoo's Avatar
Received 4,273 Likes on 3,050 Posts
Hey... you are becoming an expert in repairing S4 in record breaking time..... as miserable as you are feeling now, you are winning!
Old 12-22-2017, 11:58 AM
  #1528
Turd Polisher
TylerT's Avatar
Thanks for the encouraging words guys, much appreciated.
teh CL (12-22-2017)
Old 12-22-2017, 01:14 PM
  #1529
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
My forearm is highly developed from my major teenage past time...
ultimately that didn't leave a lot of time for me to learn how to swap engines.
teh CL (12-22-2017)
Old 12-22-2017, 01:18 PM
  #1530
Turd Polisher
TylerT's Avatar
I know you - if you had the time, you'd be a master tech.
Old 12-22-2017, 01:19 PM
  #1531
Time, space and money and all things can be accomplished...
I wish I knew it all...I'd be a car flipping fool for sure. Parts aren't usually that expensive, especially with the internet.
Old 12-22-2017, 01:20 PM
  #1532
teh CL's Avatar
Guess I was am a good multi tasker..
Old 12-22-2017, 01:23 PM
  #1533
I'd like to watch you work, man.
Old 12-22-2017, 01:25 PM
  #1534
Turd Polisher
TylerT's Avatar
:gheyhug:
Old 12-22-2017, 01:28 PM
  #1535
teh CL's Avatar
vacation?..
Old 12-22-2017, 01:29 PM
  #1536
Oui!
Old 12-22-2017, 01:57 PM
  #1537
Received 8,584 Likes on 6,630 Posts
Hey... you are becoming an expert in breaking S4 in record time..... as miserable as you are feeling now, you are winning!
too soon ... too soon
Old 12-22-2017, 02:02 PM
  #1538
oonowindoo's Avatar
^LOL for a second, i actually thought that was what i said... because it does sound right
Old 12-22-2017, 02:21 PM
  #1539
TacoBello's Avatar
I wasn't kidding about the man card thing. I'm ready for you to propose to me. I'll do anything.
TylerT (12-22-2017)
Old 12-22-2017, 02:23 PM
  #1540
TacoBello's Avatar
It's sad how on an Acura devoted forum, I have to go into the audi thread to see a good build
TylerT (12-22-2017)
Old 12-22-2017, 02:39 PM
  #1541
Turd Polisher
TylerT's Avatar
I do occasionally check into the 3G section to see the FI / NA builds .. 4G / 5G are just plain sad.
Old 12-22-2017, 03:20 PM
  #1542
TacoBello's Avatar
There is some 3G stuff coming back again, but it seems in general, most guys are cheaping out with whatever they do with that car. I can't blame them. Likely doesn't make much sense to put 5000 dollar wheels on a car worth 9000.
Old 02-02-2018, 11:05 AM
  #1543
Turd Polisher
TylerT's Avatar
Finally up and running after 5 weeks.
As some of you know, I was experiencing some clutch issues and it turned out to be the pilot bearing install. To insure 0 issues, I decided to order a brand new LUK OEM dual mass flywheel and start fresh like I should have done from the start.
After all of this, I would say this is probably the best "version" of my build so far, I did the following:
Re-did all of my wastegate lines w/ 3/16" fuel line hoses & new clamps
Bought new 2.25" to 2" high temperature silicon couplers for the turbos & inlets, also added heatwrap to the areas where it gets toasty:
FX400 clutch disk & pressure plate were good.
I also re-adjusted & pressure tested my wastegate cracking pressure from 14psi to 12psi. Boost is much more predictable now with less compressor surge.
Motor went back in on Sunday and also added my new Wagner sidemounts.
Beautiful thing about these sidemounts? Uses all of my OEM intercooler hoses and didn't have to trim my bumper or core support.
The ER / SRM / RS4 intercoolers require new hoses, core support trimming, etc.
We were delayed 2-3 hours towards the end because we couldn't figure out a simple ground issue
Live and learn, she's back:
I've driven it about 75 miles since last night and everything looks solid .. battery is a little tired but otherwise behaving normally.
I need to perform a boost leak test to make sure everything is snug, but otherwise I should finally be taking steps forward rather than 3 back
Started to get excited about finishing this project ... it's been a long journey.
The following 9 users liked this post by TylerT:
1killercls (02-02-2018), CCColtsicehockey (02-08-2018), jangkai (02-19-2018), Predatorbird (02-03-2018), rockstar143 (02-02-2018), SuperTrooper169 (02-07-2018), TacoBello (02-02-2018), teh CL (02-06-2018), ttribe (02-07-2018) and 4 others liked this post. (Show less...)
Old 02-02-2018, 12:30 PM
  #1544
hey tyler, have you considered changing your accessory belt? it seems really accessible in that 2nd to last pic.
regards!
Old 02-02-2018, 12:33 PM
  #1545
TacoBello's Avatar
Why is your custom plate for the car, hanging on your wall? Did you go with something else?
Old 02-02-2018, 12:36 PM
  #1546
3.5 psi
gnuts's Avatar
congrats! in for vids. Did you get the exhaust done? or is that on hold from all the motor work?
Old 02-02-2018, 12:37 PM
  #1547
I thought that too, Adam...
I think he probably had to remove it to access something to remove the bumper.
Old 02-02-2018, 12:56 PM
  #1548
2024 Honda Civic Type R
RPhilMan1's Avatar
Received 1,454 Likes on 923 Posts
No tags on the plate on the wall. It was probably the front plate that he removed and is now an ornament.
TylerT (02-02-2018)
Old 02-02-2018, 01:01 PM
  #1549
or that...maybe he manned up and no more front plate!
although the braps of stage iii and the attention it'll demand might not want to push your luck
Old 02-02-2018, 01:37 PM
  #1550
front plate brahs
Old 02-02-2018, 02:59 PM
  #1551
Turd Polisher
TylerT's Avatar
regards!
Accessory belt is pretty new, maybe 15,000 miles on it or so
Currently exhaul-less, I know Jason is secretly cheering me on to keep it this way but damn ... it's a magnet for cops. Constantly on the lookout
My goal tomorrow is getting it welded up tomorrow
From there, my wideband gauge can be put into the secondary o2 slot ..
Bingo.
Old 02-06-2018, 06:58 PM
  #1552
oonowindoo's Avatar
Damn those gold plated wrap looks hella cool.
Old 02-06-2018, 08:23 PM
  #1553
Car running strong?
Old 02-07-2018, 08:58 AM
  #1554
Bird is the Word
Predatorbird's Avatar
Videos please!!!
Old 02-07-2018, 09:25 AM
  #1555
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
He's driving the fit....
Old 02-07-2018, 10:01 AM
  #1556
3.5 psi
gnuts's Avatar
but its got VTEC yo
Old 02-07-2018, 10:03 AM
  #1557
Old 02-07-2018, 10:59 AM
  #1558
TacoBello's Avatar
I didn't know you're a big fan of tying various rope knots, also!!
Old 02-07-2018, 11:23 AM
  #1559
Eagle Scout, baby!
Old 02-07-2018, 11:54 AM
  #1560
In the Mid-South meow
SuperTrooper169's Avatar
Received 2,098 Likes on 1,086 Posts
You're getting good at this engine in, engine out, engine back in routine aren't ya?! Nice work man!
Quick Reply: Tyler's Owdi B5 S4 Build & Update(s) Thread
