Tires... too soon to toss?
I have about 8k miles on my car. (06' 05AT) when i stop short sometimes i hear the tires screech.. more often now then ever... i know the oem michelins are garbage but 8k is a little too soon don't you think?? safety hazard or do the michelins just tend to be a little loud??
Note that i live in new york so the driving conditions are "extreme"....
Do the penny test to see if there is enough tread left. But I know the stock Michelins are crappy wheather or not you have tread. I suggest get another set of rims and winter tires since you're in NY.
If you don't like 'em take 'em off and sell them in the black market here. Tires are going to squeal regardless of the make or model. Harder tires (that last longer) will tend to squeal more... The OEM's are "touring" tires IIRC, so they are made to last long, and aren't considered to be "performance" tires (which grip more, but usually wear alot quicker).
I had 2 OEMs that lasted for 50K miles... so @ 8K miles your tires are still brand new... The other 2 OEM's I had, had issues with the sidewalls (I blew one out on a pot hole, the other on a curb).
I'm frugal, so I'd run 'em until they hit the wear indicators (2mm), but if you don't like the tires, and don't mind spending money replacing almost brand new tires, get your self some performance tires.
Originally Posted by Tsx6363
i c.. but just as a survey... who else has had problems with poor grip with low mileage???
http://www.tirerack.com/tires/tirete....jsp?techid=67
Moderator Alumnus
Originally Posted by GreenMonster
All tires will get better grip after some wear... there's a reason why racers "shave" new tires...
Of course the lower the tread the higher the chance you will hydroplane when you hit water at highway speeds. And the lower it is, the less water it takes.
Make sure they are inflated correctly also.
blownby
08-31-2015 12:44 PM
6peedSleepR
09-04-2004 08:55 PM
