Throw-out Bearing Noise
Hi All,
Hope you can help with this as I am at my wits end.
I had an OEM clutch kit installed on my 1998 Acura 2.3 CL Premium. A couple days later it developed a noise which I think was the thrust bearing. I took the car back and they said it was the throw out bearing. So they replaced the whole kit...or so they say they replaced the whole clutch kit again. A day later after getting the 2nd clutch kit installed the noise came back even louder. The noise stops if I just depress the clutch pedal a 1/4 of an inch. I do not want to take it back to the same place because now I do not trust them. It was not an Acura dealer.
I see an adjustment on the clutch pedal I could make that would basically put more pressure on the throw out bearing which eliminates the noise and vibration but I do not know if this would be harmful or even if it is the correct adjustment to solve the noise problem.
It's hard to believe that I have another bad throw out bearing.
Any help would be much appreciated.
Thanks,
Jim
Thanks,
Jim
go like hell
1 Post
Originally Posted by JD3
Hi All,
Thanks,
Jim
Thanks,
Jim
now about the throw bearing. I had similar issue when I had a Civic back in the day. it was a stick. I'd shift and that thing make a hell of a noise. I ended up replacing the whole throw out bearing. it wasn't to hard to do. just took a Saturday or Sunday after noon.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
