Stuck spark plugs
Old May 17, 2010 | 10:14 AM
vas25tl's Avatar
The Box
Angry Stuck spark plugs
Azine, I have a problem. We were doing the 105K service and we can't get the spark plugs out. 4 out of 6 are stuck and I'm afraid of puling too hard and damaging the actual block. Have any of you had a similar experience? I'm hoping someone has some insight.
It is a 03 MDX but this is a problem that could happen on any make/model so I'm thinking Car Talk is the way to go.
They are the original plugs.
Thanks in advance.
Old May 17, 2010 | 10:30 AM
teranfon's Avatar
Moderator Alumnus
Thanks in advance.
What are you using to remove them? If you're using one of those ridiculous T-handle spark plug removers, then toss it away. Purchase a correct spark plug socket. It's generally a six point deep socket with a rubber insert at the top of it. You will also need an extension and a proper ratchet. You need to make sure you have proper leverage to remove the plug.
If this doesn't work, then re-install the plugs you took out. Start the car and run it until normal operation temperature. Shut off the engine and then try again. If they still refuse to come out, then spray the base of the plug liberally with penetrating fluid while the engine cools down.
They should come out. Again, make sure you have a correct six point socket and proper ratchet and extension.
Terry
Old May 17, 2010 | 10:40 AM
phee's Avatar
I got the Shifts
x2 on using the socket.
spray some lube in there.
Old May 17, 2010 | 12:51 PM
KaMLuNg's Avatar
X 3
Old May 17, 2010 | 12:56 PM
fsttyms1's Avatar
X4
ANd when reinstalling new plugs put some antisieze on the threads
Mike734
Dec 10, 2021 01:25 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
