Steering Wheel wobble @ low speeds
Anyone have experience with this? Below 35 the wheel goes side to side. At highwayspeed it's not an issue.
Any help is appreciated.
I had tires doing that once and think the belts were braking. not alot of miles but the car didnt get driven much either. going slow you could see the wheel shake and barely feel it but speed up and it went away
Registered but harmless
Received 1,111 Likes
1) Check tire pressure- low pressure will cause this.
2) Wheel alignment
3) Wheel balance
4) Bent wheel rim
5) Defective tire[s], i.e. separating belts
_____ like a rabbit
Originally Posted by Will Y.
Possible causes:
2) Wheel alignment
3) Wheel balance
4) Bent wheel rim
2) Wheel alignment
3) Wheel balance
4) Bent wheel rim
and make sure no ice is stuck on ur wheels, happened to me last week when it was coldddd as hell. Went away after i chipped away ice that was stuck on the inside of my wheel...
I had the same exact issue and i thought it was an alignment. Turns out it was from a flat I had and there was a bubble in the tire. Good thing i changed it too cuz it could have cause a blowout. Make sure you get it checked out
Went to NTB last night. They balanced the tires, put them back on with no improvement. They then rotated the tires with no improvement. The car is out of alignment but not that much and the tires are relatively old. NTB guys said it could be wheel bairings or bushings.
It was tires. Replaced them last night with a set of Yokos. I'm amazed at the change in the car's ride.
Guys at NTB said my car was out of alignment but that a camber kit was needed to do the alignment - it's my winter car - 94 Accord. You guys ever heard of this?
