Sleeper? I'll give you a sleeper.
OK, so the exhaust blasting out of the front fender and the roll cage are both slight tipoffs, but boy you could really freak people out with something like this.
Power comes from a Supra 2jzgte engine swap with a 321 stainless steel header that David fabbed himself. Turbo is a Turbonetics T72 P-trim with a .81 A/R. Wastegate is a Tial 40mm. Intercooler is an Isuzu NPR with 2 3/4 stainless intercooler piping. Engine is completely stock from top to bottom including stock cams. Injectors are 83lb top feed. Controlling them is an SDS EM4-6F with MSD coils. Power was 480whp at 18psi boost and 677whp at 33psi boost and 678 ft lbs or torque. Tranny is a GM powerglide with a 5000rpm stall with a custom adapter plate. Rear end is factory Toyota 1 ton with 3.90 gears and 28X11.50X15 Mickey Thompson ET streets. Quarter mile shakedown runs at only 18 psi boost netted 10.5 @ 133mph with a 1.5 60ft.
http://sdsefi.com/features/feb05toy.htm
I can't find vids of that truck in particular, but here are a couple similar ones.
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/7Wgwy_W6ECg&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/7Wgwy_W6ECg&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/RKGg9H_aN00&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/RKGg9H_aN00&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
Try this sleeper- http://www.hottiesonhoods.com/detail...1-2l1196303478
Originally Posted by mcflyguy24
Wow. That is a true sleeper indeed.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
