Running Nissan/Infiniti 66mm center bore wheels on our cars, danger??
Anyone have issues with running these wheels on a Honda/Acura? I'm getting scary steering vibration when driving over 100kmph (60+mph) My wheels are G37 that are the 66mm hub bore size. The car is a TL 64mm hub bore size. What do you think is my problem? I need some 2mm hub rings to correct this? Or maybe the used tires i got with them? They have even wear it appears. Or possibly not balanced correctly? Thanks.
a) you need hub centric rings.
b) the used tires are bad.
c) you need to check the balance of the tires.
d) one or more of the wheels are bent.
e) if you're using the stock Honda/Acura (ball seat) lug nuts, you need conical lug nuts.
f) something else
g) one or more of the above
f) something else
GEEZER
Hub centrics dude.
Get hub centric rings. Have wheels rebalanced.
