The RR Journals: Quick oil drain valve
http://www.fumotovalve.com/
Haven't seen this mentioned, and Search revealed nothing, but this is a great product for quick engine oil drains, and once you get it installed properly*, you do not have to worry about crush washers and leakage from frequent bolt loosening and tightening. And it also is available with a hose nipple on the end, so if you have suspension mods (like the x-brace on my S2000) that limits access to the oil drain plug, or it spills onto something (like my x-brace), the Fumoto is the answer. Built very, very well.
Do not overtighten - it is made of brass, and uses a high quality fiber gasket - usually only a 1/4 turn past initial contact is all that is required. I have seen people break them by going crazy with over-tightening. I just went a bit past snug until it "felt" right, but I have a calibrated wrist/arm.
Have a fumotovalve on one car since new with 300+K on it now. 15 years and never removed it. On another with 220K+ 10 years same story Great! Have another car with Fram sure drain and very happy with that. Actually prefer the Fram because it is a little neater and I think a safer design.
A question for you...
Does this compromise ground clearance or is it above the fray? Any risk of snapping it off with a high center obstacle?
How much does it stick down vs. stock drain bolt?
(Not planning any off-road rallyes)
XP
XP
mada51589
05-03-2022 08:54 PM
SidhuSaaB
05-30-2020 12:40 AM
STL TL-S
09-23-2015 08:52 PM
