Please help - Desperate - REWARD
Old Dec 17, 2006 | 03:25 AM
seanberry's Avatar
I just drove home tonight in my 2004 TSX. About a mile from my destination my nav turned off, my radio turned off, and my clock turned off. But, MOST IMPORTANT, I can't put my can in reverse or park. No fuses are blown that I can tell.
WHAT ELSE CAN THIS BE??? Please help...
Reward to the first person who helps me fix this...
Either:
$10 or
1 of several 2004 Tsx stock interior parts for ebony interior.
Old Dec 17, 2006 | 03:29 AM
Whiskers's Avatar
Go Giants
Old Dec 17, 2006 | 03:34 AM
seanberry's Avatar
Come on whiskers... that doesn't help the situation.
Old Dec 17, 2006 | 03:48 AM
seanberry's Avatar
Sorry that I am posting to two different topics, but I am desperate.
Either:
$10 or
Old Dec 17, 2006 | 03:49 AM
JT Money's Avatar
global warming
Old Dec 17, 2006 | 03:51 AM
synth19's Avatar
interesting. good thing for the warranty.
Old Dec 17, 2006 | 04:05 AM
SpeedyV6's Avatar
Either:
$10 or
The first item sounds like a blown relay. The second is bewildering. What happens when you try to put the car in park? Are you just unable to remove the key from the igniton or are you having trouble shifting into park or reverse? You may want to pm JensH1963, but for all I know he may be tired of giving out tech tips for free - especially to unappreciative AZine members.
Old Dec 17, 2006 | 04:14 AM
seanberry's Avatar
I have an AT and when I try to put the car in park or reverse I simply can't. It is an if the transmission is stuck. I can remove the key from the ignition, and I can start it again in neutral, but still can not shift.
Side Note: I drained my battery two days ago when I left the dome lights on. Since then I have started and driven the car several times without a problem.
Believe me, if there is someone who can help I will be appreciative.
Old Dec 17, 2006 | 04:17 AM
SpeedyV6's Avatar
....Believe me, if there is someone who can help I will be appreciative.
Jens is in Germany so he may be awake right now. The guy was an Acura Tech at Park Avenue Acura so he probably knows the car better than anyone. Did you try pm-ing him?
Old Dec 17, 2006 | 04:23 AM
seanberry's Avatar
Nope, have not tried pm-ing, but will right now.... THANKS.
Old Dec 17, 2006 | 05:28 AM
amisconception's Avatar
werd
You can try roadside assistance
Old Dec 17, 2006 | 07:11 AM
dallison's Avatar
registered pw
um, have the dealer tow it for free?
Old Dec 17, 2006 | 07:20 AM
Whiskers's Avatar
Go Giants
Mod should move it to the TSX forum....
Old Dec 17, 2006 | 07:40 AM
ZtotallynakedZ's Avatar
Why don't you just have it towed to a dealer?
Old Dec 17, 2006 | 08:35 AM
SouthernBoy's Avatar
Registered Member
Either:
$10 or
Does your engine still start and run? If so these are possibles. Fusable link. Major circuit breaker.
Keep us posted.
Old Dec 17, 2006 | 09:51 AM
GreenMonster's Avatar
I thought I WAS in the TSX forum for a minute
We can't move from offtopic to the model specific forums, so off we go to cartalk...
edit: Probably should repost the question in the TSX forum where the TSX members hang out:
https://acurazine.com/forums/acurazine-1/
Old Dec 17, 2006 | 09:53 AM
S A CHO's Avatar
That was uncalled for...
Are your brake lights working?
If not, then there must be a sensor at the brake pedal that is not telling the transmission the brakes are pressed as well as to turn on the brake lights.
As for the other problem, I'm just as lost as you.
Old Dec 17, 2006 | 10:30 AM
Threads merged.
Old Dec 17, 2006 | 10:53 AM
seanberry's Avatar
Red face
I was hoping the car would 'sleep it off' but trying again this morning resulted in more of the same.
A few more notes on what does and doesn't work. Brake lights work. All electrical devices work except center console (radio, clock, display for temp, 12 V outlets) although seat heaters still work.
Car starts fine (in neutral) ... but I did notice the "anti theft" light on the 'tuning' knob of the radio was blinking even with the car started.
If I can't figure it out soon, then I am definitely going dealer style today.
Thanks to all. I will let you know what happens
Old Dec 17, 2006 | 11:37 AM
S A CHO's Avatar
How about you disconnect your battery for 10-15 minutes and hook it back up, maybe something just needed a hard reset...
It's one of the simpler things you can try...
Old Dec 17, 2006 | 11:42 AM
seanberry's Avatar
Trying the battery disconnect right now... keep the suggestions coming.
Old Dec 17, 2006 | 11:51 AM
Sclass88's Avatar
Tow it to the dealer. I'm not trying to be a smartass but if you continue to screw around with it and wait to bring it to the dealer, you might be causing more harm than good. They will be able to fix it. Tell them its an emergency and the car needs to be looked at immediately. Good luck!
Old Dec 17, 2006 | 11:59 AM
S A CHO's Avatar
Yeah, seems like the most logical thing to do at this point...
Old Dec 17, 2006 | 12:05 PM
seanberry's Avatar
The service dept. can't look at my car until tomorrow. So, until then I have a day to try to figure it out myself.
Ahhhhh!!!
Old Dec 17, 2006 | 12:10 PM
Whiskers's Avatar
Go Giants
I wouldn't drive it until tomorrow
Old Dec 17, 2006 | 12:27 PM
crazymjb's Avatar
Did your car get struck by lightning recently?
Mike
Old Dec 17, 2006 | 12:34 PM
seanberry's Avatar
If that lightning question is serious... no, no lightning.
However, I was driving in the first rain since I have owned the car (2 months)
Old Dec 17, 2006 | 12:38 PM
crazymjb's Avatar
While it shouldn't have, I suppose it is possible you some how got water into the electronics. From what it sounds like, you are having a major electronics problem. Check under the hood and see if any animals chewed up any of the wiring harnesses.
Mike
Old Dec 17, 2006 | 12:39 PM
seanberry's Avatar
Already looked under the hood... no visible problems I can see.
This happened while I was driving...
Old Dec 17, 2006 | 12:42 PM
Whiskers's Avatar
Go Giants
You bought the car used, I wonder what the previous owner did...
Old Dec 17, 2006 | 12:43 PM
Scrib's Avatar
Administrator Alumnus
Sorry to hear about your troubles, but this sounds like a warranty issue that Acura should resolve.
Why all the fuss???
Old Dec 17, 2006 | 12:52 PM
iTimmy's Avatar
dɐɹɔ ǝɥʇ ʇɐɥʍ
Try disconnectig the battery for a minute, if a relay is stuck or something like that it will reset it and possibly solve the problem. Otherwise I have no clue about an easy fix
Old Dec 17, 2006 | 01:04 PM
seanberry's Avatar
... and my alarm will not go on. Not sure if this is because the car is not in park, but doors lock, unlock.
Old Dec 17, 2006 | 01:55 PM
seanberry's Avatar
I checked all of the fuses last night (actually around 1:00am this morning) and all of them looked OK. But, since I have nothing else to do I decided to check them again. Turns out my ACC fuse (7.5 amp, top row, second from right on the fuse box by the driver's foot) was blown. Replaced it and everything came back on!!! And I can put my car in reverse, park, etc.
But now it is asking me for a pin when I turn on the car. Where do I get this?
Thanks to all.
Old Dec 17, 2006 | 02:13 PM
SpeedyV6's Avatar
Thanks to all.
The pin should be a code that was given to you when you bought the car. It's an antitheft feature Acura built into the vehicle. Check your owners manual. I'm still surprised that this would have affected your transmission. It sounds like Acura outsourced their circuit design to Fiat.
Old Dec 17, 2006 | 02:23 PM
Whiskers's Avatar
Go Giants
Thanks to all.
Wow, its amazingly scary that one fuse can do all that damage.
Old Dec 17, 2006 | 02:27 PM
seanberry's Avatar
I found the numberS I needed to get everything working on a card in my owners manual case. I needed one number for the nav system to come on and one for the stereo. Thank goodness it is all over.
I hope someone else with the same problem will come across this post some day and will have an easier (less stressful) time dealing with it.
Thanks to ALL
Old Dec 17, 2006 | 02:34 PM
Crazy Bimmer's Avatar
Glad we could help
But what would make that fuse blow so early? I would still have it checked out.
Old Dec 17, 2006 | 02:54 PM
S A CHO's Avatar
Sweet... Glad to hear we all somewhat helped
Old Dec 17, 2006 | 11:28 PM
Sclass88's Avatar
Glad that's resolved for you!
