Paddle shifters - column versus wheel C&D
Old 08-09-2011, 10:13 PM
Buffa's Avatar
I thought this was interesting. Got the latest issue of Car and Driver and there was a drool worthy comparo featuring the Ferrari 458 Italia (what a beauty). In it, they make this statement:
"A brief aside on those paddles, which are mounted to the steering column: Arguments exist for placing them on the steering wheel, as McLaren does, but Ferrari’s point is that you should not change gears while the wheel is turned."
It sparked my interest because when I was shopping for my TL, I also drove the Nissan Maxima and found that the paddles were on the column versus the steering wheel like the TL. I think there are pros and cons to both, but apparently Ferrari claims you should pick the gear you want BEFORE heading into a turn. Makes sense because I find them awkward to use in sharp turns anyway. I wonder if the Maxima is easier. Miss the old fashioned SportShift lever in my 2001 CL-S.
Old 08-09-2011, 10:35 PM
jasonwdp10's Avatar
I strongly prefer autos to have the option to use the gear selector to shift (manu-matic?). I think many automakers have this option (even hyundai has it), and it is much more useful because i can make turns with both hands, and briefly tap the shifter with my right hand.. then it goes back on the wheel.
With the TL, especially for twisty back roads where you're steering wheel is rarely "center", I find that the shifters fly all over the place, especially when making tight turns. Extremely inconvenient for me.
I much prefer the setup the G37 has, where the paddles are column mounted AND there's the manual shift gate on the shift lever.
Old 08-10-2011, 07:23 AM
Pseudomaniac's Avatar
^^ The 07 Type S works in the same fashion. They got rid of the tapper in 09.
From someone with a couple hundred hours of auto-x and road track experience; I'd rather have them at my finger tips than having to make a move to the column.
The last thing you want is your thumbs getting bound up in the wheel on a switchback trying to keep the revs in the sweet spot. One thing to flip a stick where you're intending to drop one hand.
Old 08-10-2011, 08:19 AM
jjsC5's Avatar
I agree on both counts. My Lexus (GS) doesn't have paddles, but it has an excellent floor shifter. You simply move it to the left to put in sport mode, then forward or back to shift up or down. The truth is that where I live and what I use the car for (commuting in Houston traffic) I use the shifter for getting in the right gear occasionally to get around traffic on the freeway.
Old 08-10-2011, 08:43 AM
BEAR-AvHistory's Avatar
Received 2,600 Likes on 1,581 Posts
My car has both ratchet on the floor shift & pull paddles RT-UP/LT-DN on the wheel. I like it on the wheel much better once you get used to it.
Old 08-10-2011, 12:32 PM
6G TLX-S
Edward'TLS's Avatar
Received 1,156 Likes on 827 Posts
Originally Posted by Pseudomaniac
The above steering wheel is missing the digital readout for rpm information.
Old 08-10-2011, 12:53 PM
normallywho's Avatar
I loved the visceral feel of tap shifting gears on the shifter, but I like keeping my hands on the wheel more. I also prefer the paddle shifters be mounted to the steering column instead of the wheel so that they are always in the same place. The mental math necessary to figure out which paddle to hit if I want to downshift while the wheel is facing down is just too much for my simple brain.
Old 08-10-2011, 01:54 PM
Back at it with the TL SH
Mr.Skytech's Avatar
Is that a real streering wheel?
Old 08-10-2011, 02:51 PM
On the MP4-21 the TACH was actually at the base of the cockpit above the wheel.
Old 08-10-2011, 09:32 PM
Currently Post-Acura
MaxMike93's Avatar
I'd rather have them on the wheel just like say, your on a highway with a slight curve and you need to pass some jackass. Assuming you always have your hands at 10 and 2, I'd think it would be easier. Still, Brian Cooley on CNET ONLY wants them on the column. And just for the record, BMW changed the logic for shifting with a gate on the shifter (forward for downshift, back for an upshift).
Old 08-10-2011, 10:05 PM
Costco's Avatar
Received 3,489 Likes on 2,089 Posts
The best kind of shifter:
I've tried different automatic shifters... IMO the best would be a button-style steering wheel mounted shifter like on late 90's-early 00's Lexus cars. Like so:
I go with the school of thought that you should be in the correct gear before the corner. The button-style shifters let you leave your entire hand on the steering wheel... all you have to do is move your thumb to downshift or tap on the back button to upshift.
Too bad those Lexus shifters were slow as hell, at least in the IS300s I've driven.... the one in the IS-F is lightning fast though.
Old 08-10-2011, 10:12 PM
AZ Community Team
Bearcat94's Avatar
Received 7,771 Likes on 4,342 Posts
Not sure which models/trims it applies to but the 3G TL-S auto, when in auto, will try to delay shifting when in a corner (detected via yaw sensor?) so as not to "upset" the car mid-corner.
So, at least on some level, Acura agrees with Ferrari's logic.
Old 08-10-2011, 11:00 PM
oo7spy's Avatar
Received 7,249 Likes on 4,859 Posts
2G RL paddles are wheel mounted with stick capability also. If you know your car well enough , the paddles have different textures in case you lose your spot and have to find the paddles. I have shifted many times pulling out onto a street (making a right turn), and my hands never left the wheel.
Old 08-10-2011, 11:25 PM
I drive a Subata.
JS + XES's Avatar
Received 2,603 Likes on 1,571 Posts
or nothing
Old 08-11-2011, 12:03 AM
Rick_TL-S's Avatar
Received 1,239 Likes on 703 Posts
When I read up on performance driving techniques, I had always read what Ferrari was saying because a shift mid-corner could upset the car.
I know Lamborghini follows this same idea.
Porsche actually implemented that as well on some models.
[/quote]
Old 08-11-2011, 06:41 AM
CocheseUGA's Avatar
If I had the misfortune to own such a car, I'd want them on the column.
Old 08-11-2011, 07:28 AM
AZ Community Team
Legend2TL's Avatar
Received 4,287 Likes on 2,645 Posts
It's probably a McLaren F1 car steering wheel, for whatever reason McLaren put the instrumentation on the top of the cockpit cowl in their cars. The old traditional place, all the other F1 teams including Mercedes Benz put their instrumentation on the steering wheels.
http://www.automotto.com/entry/new-f...to-compliment/
Old 08-11-2011, 07:48 AM
CCColtsicehockey's Avatar
Received 3,860 Likes on 2,580 Posts
I have always wondered if they would be better on the column. The F has them on the wheel. I find it awkward to use them while turning regardless of where they are.
Old 08-11-2011, 08:13 AM
F23A4's Avatar
Received 1,671 Likes on 932 Posts
However, it's days are numbered.
Old 08-11-2011, 08:19 AM
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
^^^ so we need to get em while we can!!!
Old 08-11-2011, 08:30 AM
juniorbean's Avatar
Received 1,760 Likes on 1,046 Posts
The wife's E350 has them behind the wheel. Doesn't really matter b/c she never uses them anyway. When I'm driving her car, I don't use them either.
If I was in a Ferrari, different story. I'd probably agree with them on the column mount...
Old 08-11-2011, 09:03 AM
The Dumb One
Rockstar21's Avatar
just to add to the above few.
and if they do become extinct, so does real driving
Old 08-11-2011, 09:09 AM
^^^ This is why I am adding one to my TSX
Old 08-11-2011, 10:09 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
There are times where you DO need to shift up a gear while mid corner and not having them on the wheel makes sense to have BUT that said if you wheel is turned that far that your hands cant reach where they are mounted you probably shouldnt be shifting.
Old 08-11-2011, 11:58 AM
F23A4's Avatar
Seriously,
Old 08-11-2011, 02:30 PM
The sizzle in the Steak
Moog-Type-S's Avatar
Received 1,877 Likes on 1,297 Posts
My GTI w/ DSG gearbox has them placed in the perfect spot: On the wheel (behind).
Right side up shift
Left side down shift
Sure, Ferrari's logic of "don't shift mid-turn" may be sound, but I have found that now and again I will shift mid turn in a longer sweeping turn, and the paddles are right where I need them to be....no need to move my hands.
Not to mention they never get in the way like the column mounts tend to get from time to time.
Old 08-11-2011, 03:30 PM
West6MT's Avatar
Originally Posted by JS + MS3
or nothing
x 1000
Old 08-11-2011, 05:35 PM
Dr. Colorado's Avatar
Originally Posted by West6MT
x 1000
Paddle shifters on PDK and Lambo's E-gear both kick ass but this still works for me
Old 08-11-2011, 05:51 PM
ttribe's Avatar
Received 5,939 Likes on 2,930 Posts
Right side up shift
Same with the E60 M5:
Old 08-11-2011, 05:55 PM
oo7spy's Avatar
I think the wheel mount is the most useful for everyday driving, while Farrari and Lambo will cater to what us most useful on a track. Staying in gear around a corner is probably a good idea at 100+ mph. Doesn't really matter at 25.
Old 08-11-2011, 06:17 PM
It's not about speed, it's about weight transfer.
Changing gears mid corner can transfer weight (the same as braking, accelerating, or steering to aggressively) and cause you to lose control.
Old 08-11-2011, 06:40 PM
Rooting for Acura
knight rider's Avatar
Received 1,767 Likes on 806 Posts
The "changing gears in a corner" thing is certainly true for sportsbikes. As a rider myself I pick the gear and entry speed before I go into a turn and throttle steer out of the corner. Changing gears in a fast turn on a bike can lead to disaster.
In a car I can see how this principle would apply too. I agree with oo7spy, that this just doesn't matter if you're not going fast anyway. The vehicle would need enough torque difference while downshifting for this to matter. As for me, I have a G37 (with both the paddles and the gear shifter) and I prefer the paddles 10 out of 10 times. There is something to be said about keeping both hands on the wheel when you're downshifting to pass someone abruptly.
Old 08-11-2011, 06:57 PM
^^ Do you really use the paddle shifters all that much with the automatic transmission?
The shift delay is maddening, no?
Old 08-11-2011, 07:07 PM
Rooting for Acura
I don't. Not necessary, and yes you are correct about the delay. It's unreal. When I do use it I get into the desired gear, check around me first then go like hell. Other than that they look cool.
Old 08-11-2011, 07:56 PM
oo7spy's Avatar
So when I up shift going 25 around a gradual corner in my SH-AWD car I risk losing control?
What about when I slow down from 70 into a gradual corner and come out going 55. Say I want to downshift a split second before completely straightening out, will I risk losing control?
Old 08-11-2011, 08:23 PM
speedemon90's Avatar
if you're pushing your car close to its limit in those corners yes.
If the speedlimit through the corner is 25mph and you're going 25 nothing will happen.
Then again it also depends on the curve?? I know long sweepers can require up shifts, or other corners that have slow entry but fast exits?
Old 08-11-2011, 08:55 PM
oo7spy's Avatar
I don't drive a smart car. The limits of my car are far beyond 25 mph. How many DD get pushed to their limit everyday?
Old 08-12-2011, 03:32 AM
Costco's Avatar
It's just proper form. Reality is, I shift mid-turn all the time.... it's just that when I do, it's usually when I'm driving calmly and shifting from 1st-2nd gear while doing a left turn at an intersection or something.
But when you're approaching a corner with your brake pedal buried, a downshift rockets you to within 1000 rpm of your redline and you're coming up on a tight turn.... you'd better take the steps necessary to make sure your car is ready to take that corner as much as you are. Heel-toe rev matching, proper braking sequence for weight transfer... so on.
Then again, I don't think you would do this in an RL anyway. It's a luxury car with a great AWD system, not a 350Z.
Old 08-12-2011, 06:57 AM
AZ Community Team
Legend2TL's Avatar
My favorite shifter
Second favorite shifter
Old 08-12-2011, 11:38 AM
Majofo's Avatar
Received 11,843 Likes on 8,574 Posts
Quick Reply: Paddle shifters - column versus wheel C&D
