One CLEAN Z32 **PICS**
This is really clean! I know some of you guys like the old Z's....
1991 Nissan 300ZX TT
19K miles
Stillen intake
2.5" B&B catback exhaust
JWT ECU
Blitz SBC-iD boost controller and Blitz Powermeter-iD
ARC sidemount intercoolers
HRE 547 3-piece wheels 17X8.5 and 18X9.5
Wilwood 6-piston big brake kit up front
Stillen cross-drilled rotors and Metal Matrix pads in the rear
'99 JSpec fascia w/license plate bracket removed
Kaminari sideskirts, rear valence, and rear spoiler
Stillen louvered panel
'99 JSpec tailights
Philips HID conversion kit
Stillen heavy duty clutch
Other things that will be installed soon (already bought):
Greg Dupree test pipes
B&B split flange downpipes
19K miles
Stillen intake
JWT ECU
'99 JSpec tailights
sweet Z32. I think I've met that guy before.
GEEZER
That body style is timeless. Beautiful car,
Most likely, the owner has 2 more Z32's, 3 total. This one doesn't see many miles. Here is his collection:
Originally Posted by Shoofin
You really think it only has 19k mileS?
Z32 > Z33
Not Registered
His is nice, but I would rather take Wagz Z32
Greddy Dual TD05 16G Turbo Kit
GinnMotorsports Front Mount Intercooler
SpecialtyZ DownPipes
Greddy External Waste Gates
Greddy Race Manifolds (reinforced)
Newly Rebuilt Stock 300ZX TT Engine
87.5 Sized Pistons (Swain Coated)
JWT Valve Springs
Sunbelt Racing Camshafts
Koyo 3.0Ltr Radiator
Border 850 Fuel Injector and Fuel Rail Kit
JWT Dual Intakes – Custom Chromed
AshSPEC Tuned ECU/Eprom Switch
Custom Dual Mass Air Flow Sensors
Custom Labree 5" Wide Oval Cat Back Exhaust
Stillen Mid Pipes
A’pexi Super Air Flow Converter
N.O.S. Wet Kit – 60 Shot w/ custom fitted lines & chrome AN Fittings
N.O.S. Purge Kit & Blow Down Tube
Unorthodox Under Pulley
Greddy Blue ProfecB Boost Controller
HKS Type 1 Turbo Timer
B&M Supercooler Polished Oil Cooler w/ AN Fittings
A’pexi Twin Chamber Blow Off Valves
Custom Hard Pipes– Custom Chromed
SX Fuel Pressure Regulator w/ AutoMeter Race Gauge Blackface mounted on the unit (blue)
SX Fuel Filter (blue)
Stainless Steel Fuel Lines
New EFI wire harness
Steel Clutch Line
RPS 6puck Max Race Clutch
PowerTrain 1 piece Aluminum Drive Shaft
PCV Valve Relocation
EGR Elimination Kit
Custom Water Line Removal Under Plenum
High PSI Pwr Steering Hose
HoseTechniques FloBlu Vacuum Hoses
NGK #7 Copper Plugs gapped at 34
New OEM Oxygen Sensors
Pentroof Mirror Finished Cylinder Caps
Redline Fluids (radiator, gear, & tranny)
PowerTrix Custom Carbon Fiber Face Gauge Bezel
PowerTrix Custom Carbon Fiber DIN Panel
PowerTrix Custom Chromed Radiator Guide and Matching Side Panels
PowerTrix Custom Stainless Steel Chromed Side Panels
Suspension:
Top Speed Front Strut Bar w/ Powdercoated Towers & chrome bolts
Eibach Pro Spring Kit (.08)
New OEM Struts
Energy Systems Rack Bushings
Energy Systems Tension Rod Bushings
SpecialtyZ Sub Frame Bushings
Interior:
Ztoyz Custom Interior Trim, Seat, Shift & e-Brake Boot Kit – Charcoal on Black
Carbon Fiber Interior Trim Kit by Woodtrims
Carbon Fiber DIN Panel-custom made
Carbon Fiber Gauge Bezel-custom made
Carbon Fiber Itolla Shift Knob
Stillen Short Shifter
A’pexi Indiglo Blue Boost Gauge, Fuel
Pressure Gauge, Dual EGT Gauges
GR Racing Custom Overgauge Dual Pod
AutoMeter Phantom White N.O.S. Gauge
Custom Made White Reverse Illumination Face Gauges by Ashpowers
AutoVations.net Custom "Twin Turbo" Racing Pedals w/ Dead Pedal
Simpson 5pt Racing Harnesses
AutoPower Race Roll Bar Custom Painted w/ Chromed Bolts
2.5lb Halatron Chrome Fire Extinguisher
New “Z” Floor Mats & Hatch Carpeting
Ztoyz Custom Black T-top Covers
Custom N.O.S. Purge/Toggle Switches
Stereo:
Alpine CDA 7965 Blue LED Head Unit
Alpine & Rockford Amps
Custom fiberglass sub enclosure housing 3 Alpine Amps & 2 Alpine 10" Type R subs
Built in/fitted NOS Bottle w/ Stainless Holley NOS Bottle Brackets
Wheels/Tires:
HRE fully polished 540
Rear: 18x12
Front: 18x9
Michelin Pilot Sport C1's
Rear: 335/30/18
Front: 265/35/18
Brakes:
StopTech Big Brake Kit (front)
StopTech X-drilled 13" Front Rotots w/ 4 Piston Calipers
StopTech Steel Brake lines (front and rear)
Brembo X-drilled Stock Sized Rotors (rear)
Axxis Ultimate Brake Pads
Motul Brake Fluid
JWT Valve Springs
Stillen Mid Pipes
Steel Clutch Line
EGR Elimination Kit
Suspension:
New OEM Struts
Interior:
Stereo:
Wheels/Tires:
Rear: 18x12
Front: 18x9
Rear: 335/30/18
Front: 265/35/18
Brakes:
Motul Brake Fluid
3?? damn. sweet as hell.
wow that's the first widebody Z32 I've ever seen. amazing.
lame to post it in here, but oh well.
