Oil Quality
#41
the recomendations for Acura change to every 3.5K for severe driving. Since city driving falls under severe, I compromise on 3 and and 7200 miles and go for around 5K. Now that winter is here 5K is still a good compromise since driving in cold weather is hard on a car and the oil........
#43
Originally Posted by SodaLuvr
Acura and GM use an oil life monitoring system to determine service intervals now. GM's service intervals average more than 8500 miles in between service with conventional oil according to a recent nationwide poll. Unsure of any official figures on Acuras, but most 3G TL owners are going 6-7k.
Post the links to the tests. Real tests. Not a few random UOA reports. Those do not qualify as "controlled" tests.
As for arguing, prove your point by backing it up with real evidence....
GM has had Oil Life monitoring system since 1997.
#45
Whatever. RR's disapproval towards RP is just one opinion.
I've read up on all of the independent tests. I've yet to find a single one that proves Amsoil to be superior to all. All of the tests showing Amsoil's superiority were done by Amsoil contracted labs under questionable conditions.
GM has had their oil life monitoring system well before 1997. It wasn't until right after 2000 did the maximum service interval increase to 12500 miles/1-yr under the most ideal conditions. Previously, it was 7500 miles on most vehicles. The elimination of the flat tappet design allowed for slower degradation of the oil additives. And yes, this was on BITOG, posted by a GM engineer. Go read up on it.
As for me? I just buy the cheapest oil and filters and change every 7500 miles. Earliest is 5k. Mostly 1-3 mi trips too. How's that?
#47
Originally Posted by Crazy Sellout
Well crap, while i have you here....
Some people say that you dont need to change the oil filter as often as the oil. That true?
My tech told me that he smelled gas in my oil and that i should change it every 4k miles with M1 5w-30. What would cause gas into the oil? So should i just change the oil every 4k miles and leave the filter on for every 8k miles?
I have a modded 1.8t A4 btw.
My own research says that it is more important to change the filter than the oil. In fact, many knowledgable people change the filter, top off the oil (premium and/or synthetic) and run 10,000 miles still getting good results from the lab. (I wouldn't do this and I don't recommend it.)
A lab analysis is inexpensive. I always send a sample of my used oil into the lab and get the results by email within 2-3 days. It will show fuel contamination as well as water, antifreeze, etc.
As mentioned several times earlier here, bobistheoilguy.com site has an extensive library of oil analyses both "virgin" and used. Any oil that is on the market has been tested and reported on there. It is very informative.
My Acura TL is very low mileage so I change my Mobil 1 based on the calendar and not on miles or the MID. Every six months. I'm in Florida. We don't do winter so I have no seasonal considerations.
#48
Originally Posted by Xpditor
Might as well add my .
#49
Originally Posted by pimpin-tl
Not "ALL" the tests were done by Amsoil. But Road Rage like you said is one of the veterans here on oil info. He also agree's Amsoil is the best.
Oil Analysis kits are $15 from Oil Analyzers and $30 from Blackstone.
#50
Originally Posted by SpeedyV6
After perusing BITOG I've learned a couple of things:
1. I'm convinced that WalMart SuperTech Synthetic is actually a pretty good oil .
2. Also fwiw, in my admittedly uninformed opinion , there is little difference between Amsoil, Mobil 1, Royal Purple, and Redline when used in passenger vehicles that adhere roughly to normal or slightly greater than normal oil change intervals. No one brand appears to be conclusively better, although M1 is consistently very good.
3. The recommended 3,000 or even 5,000 mile oil change interval is gross overkill.
i'll try supertech synthetic. i don't care. whatever full synthetic brand is cheapest at the time of my oil change is good enough for me.
i change my oil every 6000kms anyways...
IBankMouse
06-13-2020 12:53 PM
emailnatec
29
09-28-2018 04:27 PM
SinCityTLX
20
10-19-2015 11:23 AM
