Nitrogen instead of air in tires.
Old 04-06-2006 | 07:16 PM
  #41
Shoot2Thrill's Avatar
Walk the walk
Nitrogen is a hogwash. You will NEVER see any real data because it is impossible! However, it will bring the in uneducated to buy tires and have the oil changed. PV=NRT Do the high school gas equations!
Old 04-06-2006 | 07:28 PM
  #42
Sly Raskal's Avatar
What's impossible about it? To measure the improvements of using N instead of O2?
If that is what you are referring to, you are partly correct.
However, like the facts have said,
using Nitrogen helps prevent the formation of condensation on the inside of a tire. In very cold climates I can see this as a benefit if you ask me.
I really don't know how much it would help people here in so cal, but if it's free at costco, why not? what do you have to lose?
Old 04-06-2006 | 07:49 PM
  #43
CLpower's Avatar
teh Senior Instigator
Tell that to all the race cars running nitrogen
Old 04-06-2006 | 07:52 PM
  #44
MarbleGT's Avatar
'08 MX5 GT 6spd.
Originally Posted by Always Dirty
I only fill my tires with air directly from the supple, pink lungs of a baby panda bear aged 6 months or less. And not one of those ghetto captive/zoo pandas, either.
Old 04-06-2006 | 07:56 PM
  #45
Walk the walk
You wheels are NEVER going to suffer in any way do to nonexistant condensation. It may be more than they teach in HS but not in Engineering School/Real world experience with material and processes. So when you really know you will know that is total hogwash. Sure if is available and you need to pressurize your tires fine. Just don't expect ANY measurable difference. Sure keep your tires pressurized but the bottom line is it not worth one penny or one minute more.
Old 04-06-2006 | 07:58 PM
  #46
Walk the walk
If you NASCAR fine, otherwise especially low profile tires are laughable.
Old 04-06-2006 | 08:24 PM
  #47
kurt_bradley's Avatar
Who is this chick?
Old 04-06-2006 | 08:34 PM
  #48
CLpower's Avatar
again, tell that to all the race cars that are using nitrogen, specifically the ones in SCCA, SWC, JGTC etc that all run low profile tires
Also tell it to all the guys running it who are monitering their tire temps. Ask them what differences they are seeing.
It may be moot to some, but it is proven and effective.
Old 04-06-2006 | 08:44 PM
  #49
subinf's Avatar
One on the right for me
You get those cool green valve stem caps
Old 04-06-2006 | 10:06 PM
  #50
Walk the walk
Clearly, not for anything driving up to Jiffy lube or Costco. I'm just trying to educate, don't shoot the messenger. Trying to save guys from wasting time and money.
Old 04-06-2006 | 10:11 PM
  #51
Sly Raskal's Avatar
Fine you don't think there isn't ANY condensation in the tire in severe cold weather. I guess the moisture in the tire from the air is free from all gas laws because it's in the tire, and that moisture in a tire doesn't freeze unlike the rest of the water in the world?
It may be small amounts, but those small amounts over a long period of time is what this is aiming to help. it may be miniscule, but hell, they're are trying to help people improve on gas mileage and tire wear.
In addition you think there's no measurable amount of data between using o2 instead of N in your tires even though there IS known differences in how much the two gases expand? Hell just driving down the street increases the tire pressure in your tires. hence why they always say to check your tire pressure before you start driving to ensure the air isn't heated up because you won't be getting accurate readings.
Why don't you forward your comments to the flight mechanics, the race car mechanics and others using nitrogen and see what they say.
I haven't used Nitrogen in my car even though I had heard about it because 1) I didn't know it was readily avialable at costco and 2) i wasn't aware of it's improvements and was skeptical at first. But from hearing about it from so many people that it can benefit I may give it a try.
What do I have to lose, it's FREE at costco.
Old 04-06-2006 | 10:16 PM
  #52
Sly Raskal's Avatar
what does going to jiffy lube or costco have ANYTHING to do with it?
regardless of what kinda car you drive, rubber is rubber. the point of using nitrogen is improved mileage and better wear on your tires because they don't expand and contract as much.
and what messenging service are you working for anyways? because you seem to be more than you are delivering a message.
  #53
Sly Raskal's Avatar
Oh and forgot to mention,
for people that do a lot of driving whether it's long distances for work or whatever, I really think using N can help those people too. even if it's just a little help.
Old 04-06-2006 | 10:27 PM
  #54
Walk the walk
Don't need to: 2 Graduate degrees and just design,test and perform failure analysis on nitrogen fluid power components for the F18 E/F and numerous other HIGH performance systems.
Old 04-06-2006 | 10:32 PM
  #55
Sly Raskal's Avatar
Well, I won't doubt your degree or experience because I don't know you.
But like many other technologies or methodologys, they start in the high tech market and trickle down to the consumer market. Hell I should know, I work for JPL and have seen a lot of the spinoffs that came from doing research for components to be used in space.
regardless of how miniscule you think the performance benefit is, the benefit of using N in consumer cars isn't seen overnight which everyone knows. it's seen in the long haul over the life of the tires.
to each their own.
Old 04-06-2006 | 11:32 PM
  #56
subinf's Avatar
Does Jiffy Lube offer nitrogen?
Old 08-17-2006 | 10:05 PM
  #57
fast-tl's Avatar
I love cars!
Nitrogen is complete overkill for 99.9% of people.
Honestly? I'm a car nut, have my own compressor but even I don't check my pressure often enough. This way I could check the tires twice a year, right?
Old 08-23-2006 | 01:34 PM
  #58
Savio's Avatar
TSX
recent story
http://www.wltx.com/news/story.aspx?storyid=41208
Old 01-24-2007 | 11:45 AM
  #59
IlliNorge's Avatar
Benchwarmer
I just saw some Jeep dealer offering nitrogen for $30 instead of the free air. This girl is pretty much right on. The only advantage to nitrogen filling is lack of water condensation in the winter. However, if you fill your tires in the winter or have access to low humidity air there will be no difference. N2 will not leak less slowly than O2. Or argon, chlorine, xenon, or even laughing gas. PV = a constant regardless of the gas.
This is similar to the effect of breathing pure oxygen on the sidelines of a football game. There is enough oxygen in air to saturate your lungs upon breathing, so increasing the dose from 20-100% is overkill. It's all in the head.
Old 01-24-2007 | 02:00 PM
  #60
Deity711's Avatar
Yes it is!
My Acura dealer has sent me little service reminder slips advertising they have nitrogen for something like $60, IIRC.
That's ridiculous. I understand that it probably has benefits, but I'm not paying for it. I don't have a Costco membership and I doubt I'll start servicing my tires there.
When I get new tires, if the shop has a machine and fills them for free, cool, otherwise, not worrying about it.
Old 01-24-2007 | 04:54 PM
  #61
runnerX's Avatar
Originally Posted by Dan Martin
I try to be accurate but sometimes I slip up.
This reminds me of the good year tire commercial on youtube.com. lol
Old 01-24-2007 | 05:20 PM
  #62
bkzjimmy's Avatar
NiGhT rIdEr
i would never pay $30 for air. i get it for free from my POS compressor/vacuum that i got 2 christmas ago and HESS down the block from me wich also has a free air pump.
Old 01-24-2007 | 09:11 PM
  #63
knight rider's Avatar
Rooting for Acura
I got nitrogen put in my tires and I can say that it did make an improvement in my tire pressure. I paid for it, but I don't have to pay for any refills for as long as I own my car.
We have had an array of temperatures in Central Texas and on and off rain for the last few months and I can tell you (from previous experience) my tires have never held their tire pressure so well.
For all of the science buffs.... you don't have to be a meteorologist to know which way the wind is blowing.
Old 01-27-2007 | 09:14 PM
  #64
Shoofin's Avatar
I'm going to be taking my car to my friend to fill at least one of my cars to see what it's all about.It would be for free, so I have nothing to lose, really. My friend put Nitrogen in the tires of my father's car, and my father is saying he is getting a little better fuel economy because of the Nitrogen. My friend gave me a bunch of reasons why it's better to use it, but among some mentioned in this post, one more reason is that it's a LIGHTER kind of gas, so it reduces some of the weight, helping the economy, ride, handling and general feel. But then again, wtf do I know..
Old 01-27-2007 | 09:16 PM
  #65
Shoofin's Avatar
"Nitrogen in tires is becoming a popular replacement for standard air. Nitrogen is all around us... the air we breathe is 78% nitrogen, 21% oxygen and the rest is small amounts of other gasses. When it comes to tire inflation, nitrogen has many advantages over oxygen. With nitrogen tire inflation, improvements can be noted in a vehicle's handling, fuel efficiency and tire life through better tire pressure retention, improved fuel economy and cooler running tire temperatures. Here at the Get Nitrogen Institute our goal is to provide consumers, over-the-road truckers, fleet managers and others information about the benefits of using nitrogen in tires."
http://getnitrogen.org/
SidhuSaaB
05-30-2020 01:40 AM
tsx_boy
12-13-2019 09:33 PM
Biggie_B
02-26-2017 12:14 PM
rcs86
08-02-2016 07:52 PM
hashbrown
09-29-2015 01:13 PM
