Nissan GT-R can't take aftermarket wheels
Old 02-07-2008, 08:52 PM
trev0006's Avatar
Motor Trend's Scott Kanemura sat down with Michizio Niikura, the president of MINE'S Motor Sports, the first aftermarket firm to get its hands on the new Nissan GT-R. The conversation centered on the roadblocks Nissan has put in place to stymie high speeds and limit modifications to the GT-R.
We've previously reported on how the GPS system fitted to the GT-R would remove the 111 mph (180 kph) speed limiter when the car arrives at a track, but according to Niikura, it will only work on pre-approved racetracks. However, the GPS sensor doesn't automatically remove the limiter by itself, it has to be manually changed by navigating through a series of menus on the GT-R's touch screen. While having to go to a Nissan-approved track is daft in its own right, it's even worse when you leave. After the track day, owners are required to head on over to a Nissan High Performance Center where a $1000 safety check is performed. Don't do it and the factory warranty is void.
Another rumor that began circulating after the Tokyo Auto Salon has also been confirmed: aftermarket wheels are out. Supposedly, all the GT-Rs on display at TAS had to be driven in on the stock rollers, jacked up and then fitted with the tuner's chosen wheels. Due to a sensor mounted on the valve stem, if the GT-R is driven with aftermarket rims, an error code is thrown on the dash. And although MINE'S has fitted a custom exhaust to their shop car, they've found that any modification to the intake system causes the ECU to go haywire.
While all these findings are disturbing draconian, GT-R owners here in the U.S. won't have to worry about the speed limiter/track day issue. Nissan has said that the GPS system won't be implemented here in the States, but the future of tuning the GT-R remains questionable.
trev0006 is offline
Old 02-07-2008, 08:56 PM
Sly Raskal's Avatar
Old news, already in the GT-R thread.
https://acurazine.com/forums/showpos...postcount=1461
Sly Raskal is offline
Old 02-07-2008, 09:51 PM
I shoot people
is300eater's Avatar
Received 3,056 Likes on 1,482 Posts
^^^don't even bother
is300eater is online now
Old 02-07-2008, 10:58 PM
dɐɹɔ ǝɥʇ ʇɐɥʍ
iTimmy's Avatar
So its got something similar to TPMS valves? not the end of the world, have the valves from the OEM wheels installed in the new wheels, problem solved, right???
iTimmy is offline
Old 02-07-2008, 11:07 PM
mcflyguy24's Avatar
There are ways around everything. If you can afford the GT-R I bet you can afford to have the ECU hacked for an intake and the wheel sensor thingy disabled.
mcflyguy24 is offline
Old 02-07-2008, 11:25 PM
What Would Don Draper Do?
JediMindTricks's Avatar
the stock wheels look good enough for me.
JediMindTricks is offline
Old 02-08-2008, 02:46 AM
ilitig8's Avatar
I am sure the guys at MINES never thought of that!
ilitig8 is offline
Old 02-08-2008, 05:05 AM
That's Racist
Time For Sleeep's Avatar
they do, but the sporty nature of the car as well as its history and 'pedigree' just beg for aftermarket options and capability.
it'd be a terrible mistake on nissan's part to not fix these issues.
Time For Sleeep is offline
Old 02-08-2008, 08:54 AM
pebe's Avatar
Why change anything?
pebe is offline
Old 02-08-2008, 08:59 AM
juniorbean's Avatar
Received 1,760 Likes on 1,046 Posts
As mentioned, old news. Feel free to post your article in the GT-R thread if you'd like...
juniorbean is offline
christopher1
3G MDX (2014-2020)
09-10-2015 06:43 PM
ellisd03tls
09-08-2015 04:17 PM
trinikidcl
09-04-2015 12:56 AM
NSolace
09-03-2015 08:02 PM
pesobreeze
1G RL (1996-2004)
09-03-2015 12:26 PM
Quick Reply: Nissan GT-R can't take aftermarket wheels
