the new '04 TL 5AT wow
COOPERATION BETWEEN 5AT AND DRIVE-BY-WIRE
With the new Drive-by-Wire Throttle System, the function of the engine and transmission can be closely choreographed for faster, smoother shifting. Upshifts from first to second gear, and from second to third gear, are more than 0.3 seconds quicker-a 33 percent or better improvement. In manual mode, driver-commanded downshifts are also more than 0.3 second quicker. Meanwhile, the peak g-or "shift shock"-has been reduced significantly during upshifts and downshifts
but does it explode and as we get more repalcements will this be the tranny we get?
.3 tenths if i remember the CL-S' is .9 so now it's .6 thats good
Liquid Ice
Re: the new '04 TL 5AT wow
Drive by wire didn't do anything super special for the 2k2+ maximas.. i feel that drive-by-wire is actually hindering my 2k3 maxima (auto) from its peak performance
my hope is that they will make the auto TL have the ability for the driver to control the 2 - 1 shifting and be able to control 1st gear. as the current TL/CL sportshift doesnt allow control over 1st gear
Originally posted by Nashua_Night_Hawk
no you can not control first-second shift.. it is the same as the current 5AT
thats gay as hell.
i wonder if this is the same shitty tranny they already have? youd THINK that honda would go back to the drawing board and totally do a brand new transmission after the disaster they currently have. hopefully so. otherwise the TL will have a very dark cloud following it around.
The Acura Granddaddy
On the Type S autos they were cutting timing in the ECU during shifts to keep power down and help with wear and tear. Hopefully the drive by wire will do a better job managing the tranny.
Sold 12/29/04 :-(
Originally posted by Black CL-S 4-Life
Yeah but it has the same 4th gear ratio as our car.
Parting out 02 Type S :(
did any of you guys bother checking into why the trannies falining? i know some did but very few. anyways, i highly doubt drive by wire will make much of a difference. but it will allow for the comp. to pay better attention to the tranny. the reason for failure is not poor design. it is because of a part that was went cheap on. the only reason they changed the ecu is to furthur prevent the tranny from overheating.
i think honda didnt spend enough time on its tranny at first, but the revised one had some decent attention
Liquid Ice
Along with this, as long as Honda redesigned the tranny to allow for more ATF to enter the clutch packs (to levels where it would not overheat, the problem that owners were experiencing with the CL/TLs should be reduced greatly.
Originally posted by LiQiCE
DBW is considered a countermeasure to help prevent the tranny from overheating by reducing or eliminating throttle at shift points. If the problem is overheating, and DBW by controlling the throttle reduces heat to the level where it won't overheat then I say thats a solution ... I'm sure Honda put some more thought into the tranny this time, ensuring that the quality control on the clutch packs did not go unnoticed as it did with the earlier CL Type S's.
vpasla1
09-17-2016 07:24 PM
mrkingstonvi
02-22-2016 01:53 PM
MrHeeltoe
79
10-14-2015 08:47 AM
joflewbyu2
10-08-2015 11:16 AM
