Needs some advice on a 1995 Acura Legend
I over heated the engine and I found collent in my throttle body and the intake manifold. I'm trying to figure out wear the leak could be coming from? I know its not the head gasket becuase I don't have milky oil.
chronic lurker...
I don't know too much mechanically about where that would be leaking from but I do know over heating the engine on a Legend was a big problem with that block. My dad had one and it happened quite often.
Received 2,329 Likes
Is the throttle body coolant line leaking?
Yep, later versions of that engine had more aggressive fans/timing which prevented headgasket issues.
one way to check for this would be to just bypass the coolant line to the TB... you don't really need it... i have it bypassed on my car... and if you see no more coolant in your TB/IM, then problem solved... why did the car overheat in the first place?
Change your thermostat. Remove the top radiator hose from the engine side, coolant will spill, and the thermostat is right there. $12 at a local auto store. Get a new gasket and o-ring too. It should take 10 min tops and will fix your heating problem (most likely). Buy a new radiator cap while your at it too. $7 is much cheaper than repairs.
Soul_Deamon
11-13-2018 04:44 PM
mike from annapolis
05-07-2017 08:21 PM
BobbyGraham388
10-22-2015 05:05 PM
