My Check Engine Light is on...
Go Giants
2008 Infiniti G35x....It just went in for regular maintaince about 3 weeks ago.....I tighened my gas cap. Any way to avoid going back to the dealer?
The sizzle in the Steak
other than the gas cap....looks like you are gonna have to go back to the dealer.
Go Giants
I haven't refilled the tank yet, could that reset it?
Go Giants
Autowhat?
Go Giants
Go Giants
Is it hard to disconnect the battery?
registered pw
lift the red cap covering the positive.
take wrench or socket to positive terminal and loosen.
using a rag, remove the cable by twisting back and forth.
try to rest cable away from the terminal
Go Giants
Ok. Ill try tomorrow.
I don't lick the battery, correct?
registered pw
after 10 min, use the rag(so you don't touch the terminal) and twist the cable back on the terminal.
use socket or wrench to tighten nut.
once the nut starts to become tight, tighten it just a little bit more to make sure it is secure. this is called "snugging it"
restart car
restart car
registered pw
you drop your pants
EDIT; drop your boxers, tidy whitey's etc
insert your right index finger in your ass
lick your left thumb and index finger
grab the positive + terminal as hard as you can
enjoy
enjoy
Last edited by dallison; 12-29-2008 at 07:23 PM. Reason: whiskers doesn't go commando
Go Giants
suite. Thanks.
dɐɹɔ ǝɥʇ ʇɐɥʍ
Not that it matters much, but as long as the light isn't flashing its nothing serious. When it flashes, that's when you know you're screwed!
Another possible solution, if the battery doesn't fix it, is to track down a local member who has an OBDII scanner, it would literally take 30 seconds.
Registered but harmless
Received 1,102 Likes
If you get a chance to see this thread before electrocuting yourself, is there a separate "check gas cap" light on the instrument panel?
If not, you may be OK to drive around a little while to see if the light goes off-- sometimes a slightly loose gas cap permits enough vapors to activate the CEL, which will then go off a couple of days after tightening the cap and driving normally.
Go Giants
Turn "710" upside down (think "blonde" joke).
When you turn the ignition to "on" (or before pushing the start button) when all the warning lights come on in the instrument panel for a few seconds to show that they are operating-- is there a separate light for "check gas cap?"
If there is, but it goes out once the car has started, then it's not the gas cap, but something else (which means see the dealer, preferably without wiping out the code).
If there is no such "gas cap" light, then the CEL may be on because of the formerly loose gas cap.
Go Giants
^^Check...
CL in lawnmower status
definately disconnect the battery
but before you do that check the owners manual, as some cars need programming after the battery is connected again, good luck
Go Giants
Trolling Canuckistan
I'm not sure if Infiniti used theft protected nav and radios, but if they do, make sure you know where you codes are. You will most likely need them after disconnecting the battery.
Received 2,329 Likes
My life here on Acurazine is now complete. Whiskers posted an on topic question in the car talk forum..
Go Giants
Screw you all....Except NSXNext, thanks, but Im not able to meet up.
