Most Insane R8 EVER!!!
Old Aug 15, 2008 | 08:05 AM
Storm982's Avatar
http://www.autoblog.com/2008/08/13/a...-r8-blackbird/
Old Aug 15, 2008 | 08:32 AM
ThermonMermon's Avatar
haha, those guys need to get laid badly. or maybe the judgment should be left for the owner. all that $$, he should of spent it on hookers. sure that would be more beneficial to him.
Old Aug 15, 2008 | 09:27 AM
AS3.0CL's Avatar
F1 cart racer
either hes trying to do what the guys did tin the M5 by going across country the fastest, or their running the gumball with that car. if none of those then idk why? haha but anyways thats a lot of weight to put into the car lol. vry nice integration though.
Old Aug 15, 2008 | 09:55 AM
phee's Avatar
I got the Shifts
whats the pulse generator for?
Old Aug 15, 2008 | 10:30 AM
Bdog's Avatar
Not Registered
^ I got these from Bull Run 2008 discussion
http://www.talklambo.com/showthread.php?t=3869&page=3
Interesting theories, however, a radar jammer is considerably smaller and wouldn't need liquid cooling.
1) Environmentally sealed mil-spec data port. Only used for adjustments and uploading settings. Power is fed by 7000 watt peak modified sinewave inverter. Power connections are not visible in this picture.
2) Coolant lines are low pressure UL 94 VO Rated ultra high purity perflouroalkoxy tubing with stainless steel quick disconnect bayonet fittings. Pressure tested up to 60 PSI at 300 degrees F. Maximum operating temp on unit is 190 degrees. PVC tubing is rated to 140 degrees max. PFA tubing is tested to -350°F to 500°F.
3) The unit is not powered up in this picture. For safety reasons, it is never operated while the vehicle is stationary or when people are in front of it. The bubbles are due to the fact that the unit is removed regularly for cleaning and adjustments. The air bubbles are bled off and cleared when the coolant pump begins to operate.
4) The liquid is tinted green and is low conductivity (0.36 micro Siemens). It is not anti-freeze. It is non-toxic and UV reactive.
5) On this point you are partly correct. This unit is not available to the public. It is not United States military technology and therefore does not fall under any military classification...yet.
I will neither deny nor confirm your conclusion in any public forum.
hmMmmm, i have a theory, based off these assumption (i konw, i know)
mounted in the front - offensive
infrasonic - << 15hz
7000W peak - LOTS of energy and not very efficient/directed, thus the coolant lines
not used when stationary and/or harmful to humans
so:
well, i figure since its infrasonic, and is driven by a huge power supply, it must affect the area directly in front of it. since the aperture (that we can see) is tiny, i assumed that dispersion takes place and spreads out and apparently at great distances b/c it uses infrasonic waves, this would mean that the emitted waves have the ability to defract sharply around bends in the roads, hills, ect. that AC supply suggests something powerful too, wires would melt @ 7000W if supplied by DC, too much resistance. besides, itd be quite stupid to convert DC to AC back to DC if it was powered off some kinda battery/capacitor.
i think its a radar/laser jammer; not an electronic kind, instead a physical kind. since sound waves are compressions and expansions of the medium that they travel through, i would imagine this device has the power to change the index of refraction of the air either directly infront of it (or if its tied into the chassis) the air around the car with infrasonic waves. this would mean that incoming photons (laser, radar) would have "zig zag" through the different indicates of refraction as they are traveling to, and bouncing away, from the car, slightly increasing the distance they have to travel and/or curving them (literally) away from the car. heh, kinda like a force field.
what does this mean? a radar/laser gun assumes that the speed of light in the detecting medium is constant...and it is, assuming constant density. this device might change the density of that medium (air) oh so slightly so that it throws range finders/speed detectors out of whack by varying that constant. *think* heat shimmer on the roof of a car on a sunny day, hot air immediately over searing metal is less dense than the cooler air far from it, so the light gets messed up (meaning bent) as it passes through that area en route to your eye. this device does something similar, changing the density of the air with sound wave *think* bomb blast shock wave or LOUD sub woofer* instead of heating it, or, it might heat it too. so in a nutshell i think its a ultra ultra low frequency sub woofer jacked up on 'roids.
my .02
all this is theoretically possible w/ enough energy, you could detonate concussion bombs infront of a car with the same effect, this just might be a simpler way to do so.
Old Aug 15, 2008 | 10:34 AM
phee's Avatar
I got the Shifts
^^thats exactly what i was thinking (just my inner engineer) great post!
Old Aug 15, 2008 | 10:45 AM
Shoofin's Avatar
I can just as easily add all that crap to my car and make it seem like it all works...Everything he showed looks like things that can be removed very easily.
Regardless, of whether it really works or not, it looks like one of the stupidest creations I've ever laid eyes on. Give me the R8 without all the blacked out nonsense, and i'll be as happy as a pig in shit.
Old Aug 15, 2008 | 10:51 AM
Bdog's Avatar
Not Registered
Surprised they didn't put gull-wing doors on it!
Old Aug 15, 2008 | 11:52 AM
sol_da_man's Avatar
black on black 04 TL 6MT
or a flux capacitator...
Old Aug 15, 2008 | 01:15 PM
sho_nuff1997's Avatar
I disagree with unanimity
Awesome! The exterior is hot sex!
Old Aug 16, 2008 | 04:12 AM
is300eater's Avatar
I Shoot with a Camera
the with the sunglasses was annoying as hell... that sound he kept making in the first 30 seconds after he started talking I do like the exterior of the car... the exhaust was sick... but the gadgets just make it look cheap and I can do without all that shit
6 minutes of video? I would've much rather listen to 6 minutes of the exhaust instead of the two guys talk...
Old Aug 16, 2008 | 07:19 AM
ChrisQ1980's Avatar
hates the winter
I hope they realize they are still going to get pulled over.
Old Aug 16, 2008 | 09:37 AM
cltypeSLOW's Avatar
Don't Mess With Texas
overkill on so many levels. why the fuck do you need 2 garmin portable navi units stuck in the windshield.
Old Aug 16, 2008 | 11:08 AM
FiveLiterCheater's Avatar
All those gadgets....and the owner ends up getting pulled over for no front tag
Old Aug 16, 2008 | 07:08 PM
Meeyatch1's Avatar
LOL!! I was thinking the same thing....and when they do get pulled over, they could be in some deep sh*t for having what appears to be an active jammer strapped to the front of their car.
Old Aug 16, 2008 | 07:10 PM
Meeyatch1's Avatar
Oddly enough, this is the second R8 I have seen that is outfitted with so many goodies. I actually drove one after almost all of the Bull Run parts were added on, and the car is kind of odd to drive. If you have that hydraulically actuated SMG gearbox it is actually annoying in city driving. It shifts funny, and if you sit at a stoplight with your foot on the brake, in gear, after about 15 seconds the car just puts itself in neutral. Goofy stuff.
Old Aug 27, 2008 | 02:35 PM
godfather2's Avatar
Time to Climb
i prefer this rwd 500+ hp audi gt3: http://carscoop.blogspot.com/2008/08...th-500-hp.html
Old Aug 27, 2008 | 02:38 PM
is300eater's Avatar
that's crazy... and being RWD it would be a lot lighter too. I don't know if I'd drive around with that whale tail though...
Old Aug 27, 2008 | 03:08 PM
vas25tl's Avatar
The Box
Wow, the Audi gt3 is sick!
Old Aug 29, 2008 | 10:25 AM
hemhaw's Avatar
Drinking Beer In
CB Radio?
I din't know anyone still used it, let alone considered it "hi tech".
wreak
Oct 1, 2015 10:56 AM
suka4thong
Jun 4, 2004 08:32 AM
CraZee ZO6
Apr 14, 2004 02:00 PM
