The Mini Needed More Doors, Seats, Pedals & Turbos: Fiesta ST
Old Jan 31, 2023 | 10:45 AM
  #841
Yeah, if they want to make it right, I'll let them put me in something & take care of it.
I think there is a reflash/fix for the cameras that could get done at the same time. The image quality is a bit grainy, be good to have that addressed under warranty.
Old Jan 31, 2023 | 02:42 PM
  #842
Added a quart & it's looking normal on the stick. Will keep an eye on it over the next few days & make sure it isn't going down.
If so, I'll put it on the dealer to make it right.
Old Apr 26, 2023 | 07:52 AM
  #843
Hit 30k this morning
Have a few things I need to make an appt for while it's still under warranty. But otherwise, she's just gas & go.
Old May 30, 2023 | 06:37 AM
  #844
Flummoxed by the MiniBus
Attempted to change the oil yesterday.
Got the undertray removed, pulled the front air dam so I could get around under it easier.
My little Pittsburgh low-pro 1.5t jack isn't going to cut it trying to lift this tank.
Got to the oil pan drain & the Hulk's roided out cousin must've changed the oil last. Felt like I was going to round off the plug. Gave up for the day. Going to order a couple Fumoto valves for it & the Exploder, and try again when they come in. Might have to put a vice grip on it & YOLO. It's such a small amount of space to get a wrench in here, between a crossmember & the front sway bar.
Left the air dam off, think it looks better, but may put it back since I think it might give some water/debris protection to the drive belt area of the engine.
Old May 30, 2023 | 10:16 AM
  #845
BreezyTL's Avatar
righty tighty, lefty loosy
Old May 30, 2023 | 10:28 AM
  #846
Yup. 12pt wrench, just not getting enough bite on the drain plug. Going to get a 6pt & try again once I get a Fumoto ordered.
Old May 30, 2023 | 10:38 AM
  #847
Old Jun 5, 2023 | 08:05 AM
  #848
Defeated the Expedition yesterday.
Took doubling up on wrenches to get enough torque to break the drain plug loose
Replaced with a Fumoto, so I never have to deal with that again. Just need to get some 3/8" tubing before the next oil change.
Oil filter was on really tight as well had to break out a channel lock to get enough leverage to get it loose.
Ford put a drain tray on the crossmember so oil from the filter doesn't leak everywhere, and a nice little slide for it to drain down. Except it goes the opposite direction of how it seems, and I now have a nearly 12" dia stain on my driveway
Still need to rotate the tires, but my little 1.5T low-pro jack wasn't going to get it done. Going to need o get a bigger jack, or bite the bullet & get a Quickjack.
Old Jun 5, 2023 | 08:40 AM
  #849
What's the drain pan?
Old Jun 5, 2023 | 08:51 AM
  #850
What?
Old Jun 5, 2023 | 09:32 AM
  #851
What?
The drain pan/tray thing you mentioned. Is that a service tool or what?
Old Jun 5, 2023 | 09:40 AM
  #852
Permanently attached to the crossmember, under the oil filter.
Has a 'slide', down the front of the crossmember, where you'd expect the oil to go as it drains from the filter as you spin it off.
Nope, there's another drain, on the back of the crossmember, that's nearly invisible until the oil starts running out of it.
Looking at it from below, you'd expect the oil to follow the red arrow, as you can see the bottom of that little slide from underneath.
Instead, it follows the green arrow to a stubby little drain & actually drains onto the mini 'skid plate' then down to the ground.
Old Jun 22, 2023 | 08:13 AM
  #853
There's an outstanding & suspended recall campaign for the backup cameras on Explorers/Aviators. Blue screen & unrecoverable without restarting the vehicle.
Got my first one today
It's already on my list, but now it's presentable as an issue.
Old Sep 18, 2023 | 08:06 AM
  #854
Dropped the Exploder off at the dealer Friday for a laundry list of recall & warranty work.
Wandered the lot while waiting on my ride, mightily tempted by an F150 there, but at the $62k sticker...
New F150 Lariat 3.5EB, 4x4, pretty loaded. Maybe if I had more equity in the Ex & could get closer to a wash on finance.
Old Sep 18, 2023 | 01:30 PM
  #855
PhilB81's Avatar
My dad had an F150 King Ranch edition, I think it was a 2018, whichever year they went to aluminum frame. He had a few gremlins here n there but nothing too bad. Reason he got rid of it is the ride. Unless it was a dead stop or the most pristine tarmac, the whole truck was constantly juddering. His old Silverado rode a lot better and the RAM he has now does too.
otherwise it was a pretty good truck, the 3.5L with 10 spd pulled really well and economy was reasonable for a large truck, towing was also excellent.
Old Sep 18, 2023 | 01:38 PM
  #856
2015 was the first year for the aluminum body. I had a 2016 XLT. Great truck, I had the 2.7TT 2wd. If it weren't for the incessant noise from the pano roof, I likely would've kept it.
The 23 Lariat I was peeking at on Friday, surprisingly, didn't have a sunroof at all, which is a big plus for me.
Old Sep 18, 2023 | 03:17 PM
  #857
PhilB81's Avatar
youre totally right, it must have been a 2015, possibly 2016, but I really think it was first year. He had the giant pano roof and 0 noise from it. It was a quieter place to be than the TL.
which wheels did you have? Maybe the issue was the large wheels the king ranch comes with (I mean rims, not tire). Another issue for us is the bed was higher than the Silverado by a couple of inches and the ramps for the ATV made it a steep climb.
Old Sep 18, 2023 | 03:32 PM
  #858
Mine had the 18" XLT Sport wheels.
I had it in a few times for the pano roof. Originally for rattles, which progressed to squeaks after the rattles were 'fixed'
It was a great truck, otherwise.
Old Sep 19, 2023 | 08:07 AM
  #859
Topped up the Burban this morning, forgot how thirsty the 6.2 is....14.8 mpg
Love the truck, hate the cost. Makes me look forward to getting the Exploder back sooner than not.
Old Oct 23, 2023 | 10:09 AM
  #860
SA texted me on Tuesday last week, still 6 cars ahead of me for getting it in front of their transmission guy.
Everything else is done, hoping they wrap it up this week.
Old Oct 23, 2023 | 10:12 AM
  #861
rockstar143's Avatar
15 mpg is almost like a hybrid!
Old Oct 23, 2023 | 10:13 AM
  #862
Also, rolled over 50k on the Expedition last Tuesday.
Got 16.6 on the last tank in the Denali. But that's pussyfooting it everywhere & keeping it under 70 on the highway.
Old Oct 25, 2023 | 07:54 AM
  #863
Dealer called yesterday & all items for repair are complete.
Plan is to go pick it up tomorrow after work. Downside to not getting a loaner, I have to get a ride to work, then a ride to the dealer, so I don't end up with 2 trucks at the office. Luckily 1 coworker lives about a mile from me & my boss lives a couple miles from the dealer.
Just have to hope that all of it is actually fixed, since my B2B warranty expires in about 1k miles or in mid-Dec, not sure if a recheck on a warranty fix is still covered after exceeding mileage/time.
Powertrain, I've got 5yr/50k I believe.
Old Oct 25, 2023 | 09:20 PM
  #864
civicdrivr's Avatar
I would assume the repairs themselves have a 1yr 12k mile warranty.
Old Oct 26, 2023 | 09:16 AM
  #865
^ That's what I'm reading as well & will be sure to inquire about it when I pick it up tonight.
Old Oct 26, 2023 | 10:24 AM
  #866
I would turn off traction control and really go light that thing up...
if it's gonna break, make sure it's within the next month.
Old Oct 26, 2023 | 10:32 AM
  #867
It's not too far off from needing a set of tires.
Old Oct 27, 2023 | 08:55 AM
  #868
Other than a brief inop with the power liftgate [working now] everything seems to be back to normal.
6 page RO
Old Nov 15, 2023 | 09:41 AM
  #869
Exploder needed an oil change.
My little Pittsburgh low-pro floor jack didn't have enough range to even lift a wheel off the ground.
Borrowed a high-lift jack from my FIL. guess it needs oil added to it. It got to put tension on the jack point & wouldn't go any further.
Was going to order a new jack, was looking at the 'all-terrain' jack from somewhere like Harbor Freight. Would work great on my unevenly textured driveway.
Had this video pop up in my YT feed & decided to give it a shot. I'm out about $50 in materials & it works great.
Other than nearly driving off the endo of it It got the front high enough to slide under on a creeper with no issue, and the 'tail' swings out of the way to allow side access.
Video built his with 2x8, but after measuring the 275 tires on the MiniBus, I went with a 2x10. Would've gone with 2x12, but it would've doubled the cost & added a lot of weight to lug around.
Old Nov 15, 2023 | 10:19 AM
  #870
PhilB81's Avatar
Pretty neat ramp! I like the swing away.
when I had my Jeep, I could lift it from the axles, so my little hydraulic jack was enough.
Old Nov 15, 2023 | 11:15 AM
  #871
LOL...or get a thick ass jack pad that will get it done.
or don't use a creeper and change the oil without even lifting it.
Old Nov 15, 2023 | 12:15 PM
  #872
That's what I did on the MiniBus, it's just tall enough to shimmy under (with the air dam removed) and get it done.
Wasn't gonna happen with the Exploder.
Old Nov 15, 2023 | 12:22 PM
  #873
BreezyTL's Avatar
Might have to make the modification for the swinging section. The wood lo-pro ramps are nice but they are extremely heavy to lug around...
Old Nov 15, 2023 | 01:29 PM
  #874
I built them with a hinge that has a removable pin, so I have the option to split them. They've hefty, but not terrible to carry.
Old Nov 30, 2023 | 11:49 AM
  #875
New 'tool' inbound.
Along with the ramps I built, I'm giving a pair of these a shot. Always been a challenge to jack the car up, then find somewhere to put a jackstand. Nearly dropped the Malibu due to an iffy spot.
If they work well, I'll leave 1 in each of our trucks, which will be better than the hand-crank scissor jack & will order another pair to have a set of 4 to get at all 4 corners.
Had a $50 GC from work, so I'm only out $90 for a pair.
https://www.amazon.com/gp/product/B003ULZGFU/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B003ULZGFU/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Old Dec 1, 2023 | 12:52 PM
  #876
that's damn cool.
too bad I only own 1 vehicle it'll fit under.
Old Dec 1, 2023 | 02:13 PM
  #877
Will know next week how well they work with the Fords.
Strategically lifting the Midget with a regular jack & getting these under it would definitely give some extra working from from below.
Old Dec 18, 2023 | 10:28 AM
  #878
Went down to our ranch in S TX last week for a hunting trip. Towed my dad's Mule down there, about 400 miles each way.
The Exploder handled the towing really well, apart from the 8mpg [really windy] on the outbound & 9mpg on the return trip. Spent a lot of time in 8th gear, with all the drag from the Mule.
The stock Pirellis are definitely not a gravel/dirt tire.
Old Dec 18, 2023 | 11:01 AM
  #879
PhilB81's Avatar
Wow nice! Did you get anything?
Old Dec 18, 2023 | 11:12 AM
  #880
No, nothing for me. Saw a lot, but all too young to take. Better to give them a year or two to grow & repopulate.
https://acurazine.com/forums/ramblin.../#post16918786
