mercury topaz
Old Jun 2, 2005 | 03:07 AM
msdosp1mp's Avatar
not an acura, its a topaz
mercury topaz
hey guys, i know this is the acura forum and i know that i might get flamed, but most of yall are knowlageable mechanics. heres my problem. i have a 1991 mercury topaz and it wont start. now, the tempo/topaz car club of north america sucks really bad because they couldn't help me with my problem, so i'm going to pick ya'lls brains. i put the engine back together, from the head up. the timing is correct, i drained the fuel tank, i've cleaned the fuel injectors by hand, changed the spark plugs, gapped them, and the wires, with the rotor and the distributor cap. i've had to replace the fuel pump, and the battery, because this car sat so long. but, still, it won't start. does anyone here own a ford product and know about the pushrod 4 banger? any help appreciated
oh, and btw, i'm not a n00b, i work on cars, and mobile electronics, and eps cl is one of my best friends, so don't flame
thank you
Old Jun 2, 2005 | 09:38 AM
youngTL's Avatar
Registered Abuser of VTEC
thank you
Maybe it's not an engine issue at all? Does the starter click at all when you turn the key?
Old Jun 2, 2005 | 09:41 AM
Ken1997TL's Avatar
Perhaps there is no power going from your new battery to the starter.. worth checking.
Old Jun 2, 2005 | 09:43 AM
mrdeeno's Avatar
Is the rotor set right in the distrubitor? Worked on a friend's 91 eclipse that wouldn't start. Finally figured to move the rotor and tried to start at each point...after moving to the 3rd point it started. Before that we were just spraying gas into the cylinder but sparking the wrong cylinder.
Old Jun 2, 2005 | 02:10 PM
Loseit's Avatar
Changin bulbs since '73
are you firing in the right sequence?
Old Jun 2, 2005 | 06:30 PM
msdosp1mp's Avatar
the starter spins, the firing order is correct, and the rotor is set right
Old Jun 2, 2005 | 08:07 PM
bigman's Avatar
'Big Daddy Diggler'
have you checked all the electronics, and fuses.
Old Jun 2, 2005 | 08:08 PM
bigman's Avatar
'Big Daddy Diggler'
Also make sure that fuel is making it's way to the motor.
Old Jun 2, 2005 | 08:12 PM
1killercls's Avatar
GEEZER
what kind of shape are the Piston Return springs in?
Old Jun 2, 2005 | 10:00 PM
Liftedoff420's Avatar
maybe you should just push that POS over a cliff
"WE RIDE TOYOTAS AND HONDAS UP IN HERE, BUCKETS NIGGA, 86 NIGGA!!!!"
Old Jun 3, 2005 | 12:26 AM
teranfon's Avatar
Moderator Alumnus
Agreed
The majority of Ford products have a trunk safety switch for the fuel pump. This switch will often trip if hit in the rear AND if the car has been sitting. Should be a little red button somewhere along one of the inner trunk walls. If it hasn't been tripped then put of guage on the rails to make sure you are indeed getting fuel.
Terry
Old Jun 3, 2005 | 01:40 AM
msdosp1mp's Avatar
well, the cars got a new fuel pump and its getting gas to the motor, and the fuel pump switch is checked, and no, it was a 100 dollar car, i'm not going to push it off a cliff :P
Old Jun 4, 2005 | 03:56 PM
fast-tl's Avatar
I love cars!
I just found your thread, and we're in similar situations, but my $200 beater is a '89 Bonneville. What about the engine computer? Does the car evne attempt to start, or is it just turning over? any sensors unplugged? have you cleaned the intake of gunk using carb cleaner, and have you tried starting fluid?
Old Feb 8, 2022 | 08:04 PM
Your Huckleberry's Avatar
Elite
thank you
My second car was a 1991 Mercury Topaz!
Unfortunately...
Old Feb 8, 2022 | 09:47 PM
pttl's Avatar
My first Avatar....
Congratulations Huckleberry, you've resurrected a thread from 2005!
Old Feb 9, 2022 | 09:07 AM
Might be a necrothread record
kansaiwalker1
Jun 15, 2010 02:58 PM
kansaiwalker1
Jan 26, 2005 08:13 AM
