Looks LIke Nissan handed the baton to Toyota in the Deadly Defect Relay
List of defect issues for the 2003 G35 coupe. First 6 are the most Serious:
Nature of Defect:
1. FUEL:FUEL LINES:HOSES:NON-METALLIC Recall Number: 02V245000
Dates Manufactured: JAN 2002 to JUL 2002
Number of Vehicles Affected: 18300
Date Owners Notified On: SEP 2002
Vehicle: 2003 Infiniti G35
Defect Description:
THE FUEL HOSE CONNECTION FOR THE OUTLET OF THE FUEL PUMP WHICH IS LOCATED AT THE TOP OF THE FUEL TANK MAY NOT HAVE BEEN PROPERLY ATTACHED WHEN THE VEHICLE WAS ASSEMBLED AND COULD COME LOOSE WHILE DRIVING OR WHEN STARTING THE ENGINE.
Consequence of Defect:
IF THE CONNECTION COMES LOOSE WHILE DRIVING, THE ENGINE WILL STOP RUNNING DUE TO LACK OF FUEL, INCREASING THE RISK OF A CRASH. ALSO, IF THE CONNECTION COMES LOOSE WHILE DRIVING OR ATTEMPTING TO START OR RESTART THE ENGINE, SOME FUEL WILL DISCHARGE FROM THE FUEL PUMP. IF THIS SHOULD OCCUR IN THE PRESENCE OF AN EXTERNAL IGNITION SOURCE, A FIRE COULD RESULT.
Nature of Defect:
2. EXTERIOR LIGHTING:HEADLIGHTS Recall Number: 02V331000
Dates Manufactured: N/A to N/A
Number of Vehicles Affected: 36000
Date Owners Notified On: JAN 2003
Defect Description:
SEDANS FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, -***244;LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT.-ö IN THE ASSEMBLY OF THE HEADLAMPS, IT IS NECESSARY TO HAVE A MEANS TO ADJUST THE HEADLAMPS. TAMPERPROOF CAPS TO PREVENT HORIZONTAL ADJUSTMENT OF THE HEADLAMPS ARE THEN INSTALLED. SOME OF THESE VEHICLES ARE MISSING THE TAMPERPROOF CAPS.
Nature of Defect:
3. SERVICE BRAKES, HYDRAULIC:SWITCHES:BRAKE LIGHT Recall Number: 03V200000
Dates Manufactured: AUG 2002 to MAR 2003
Number of Vehicles Affected: 60000
Date Owners Notified On: JUN 2003
Defect Description:
ON CERTAIN SEDAN AND COUPE MODEL VEHICLES, THE BRAKE STOP LAMP SWITCH MAY MALFUNCTION.
IF THIS OCCURS, THE BRAKE LAMPS WILL NOT ILLUMINATE WHEN THE BRAKE IS APPLIED, WHICH COULD RESULT IN A CRASH WITHOUT WARNING.
Nature of Defect:
4. ENGINE AND ENGINE COOLING Recall Number: 03V455000
Dates Manufactured: JAN 2002 to JUN 2002
Number of Vehicles Affected: 630000
Date Owners Notified On: N/A
Defect Description:
ON CERTAIN PASSENGER VEHICLES, THE CIRCUIT BOARD FOR THE CRANK POSITION SENSOR OR CAM POSITION SENSOR MAY HAVE AN IMPROPER SOLDER JOINT DUE TO SOLDER DEFORMATION CAUSED BY HEAT STRESS ACCELERATED BY THE EXISTENCE OF FLUX RESIDUE DURING THE SOLDERING PROCESS.
THIS COULD CAUSE THE "SERVICE ENGINE SOON" WARNING LIGHT TO COME ON, CREATE A NO START CONDITION, CAUSE REDUCED ENGINE POWER, OR CAUSE THE ENGINE TO STOP RUNNING WITHOUT WARNING DURING VEHICLE OPERATION, WHICH COULD RESULT IN A CRASH.
Nature of Defect:
5. FUEL SYSTEM, GASOLINE Recall Number: 05V555000
Dates Manufactured: NOV 2001 to OCT 2003
Number of Vehicles Affected: 192659
Defect Description:
ON CERTAIN PASSENGER AND SPORT UTILITY VEHICLES, THE FUEL FILLER HOSE MAY CRACK AND RESULT IN FUEL LEAKAGE FROM THE HOSE WHILE REFUELING.
FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE COULD RESULT IN A FIRE.
Corrective Action:
DEALERS WILL REPLACE THE FUEL FILLER HOSE. RECALL BEGAN ON FEBRUARY 27, 2006, FOR NISSAN OWNERS, AND ON MARCH 13, 2006, FOR INFINITI OWNERS. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261 OR INFINITI AT 1-800-662-6200.
Nature of Defect:
6. EXTERIOR LIGHTING Recall Number: 06E060000
Number of Vehicles Affected: 87745
Defect Description:
CERTAIN AAI MOTORSPORTS COMBINATION LAMPS SOLD AS REPLACEMENT LAMPS FOR USE ON THE ABOVE LIST PASSENGER VEHICLES. COMBINATION LAMPS NOT EQUIPPED WITH AMBER SIDE REFLECTORS FAIL TO CONFORM WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, -***244;LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT.-ö
LACK OF AMBER SIDE REFLECTORS IN THE LAMPS WILL DECREASE LIGHTING VISIBILITY TO OTHER DRIVERS AND MAY POSSIBLY RESULT IN A VEHICLE CRASH
Here are staggering 77 TSB Bulletins
Component Description:
1. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 06004
Bulletin Date: MAR 2006
Summary:
MALFUNCTION INDICATOR LAMP WITH DIAGNOSTIC TROUBLE CODE U1000 OR U1010 STORED IN ENGINE CONTROL UNIT. 2002 - 2006 INFINITI VEHICLES WITH CAN COMMUNICATION. ( NHTSA ITEM NUMBER - 10019293 )
2. SERVICE BRAKES, AIR:ANTILOCK:WHEEL SPEED SENSOR Bulletin Number: 03056A
Bulletin Date: NOV 2005
Summary:
ESSENTIAL TOOL J-45741-INF ABS ACTIVE WHEEL SENSOR CHECKER. ( NHTSA ITEM NUMBER - 10006124 )
3. POWER TRAIN:AXLE ASSEMBLY Bulletin Number: 05002
Summary:
CLICKING NOISE FROM REAR AXLES. ( NHTSA ITEM NUMBER - 10017773 )
4. SEATS Bulletin Number: 02080
Bulletin Date: JUL 2005
Summary:
DRIVER'S SEAT NOISE AND/OR ROCKS BACK AND FORTH. ( NHTSA ITEM NUMBER - 10016401 )
5. POWER TRAIN:AXLE ASSEMBLY Bulletin Number: 05002
Summary:
CLICKING NOISE IS COMING FROM THE LEFT AND/OR RIGHT REAR AXLE WHEN ACCELERATING FROM A STOP. ( NHTSA ITEM NUMBER - 10016567 )
6. STRUCTURE:BODY Bulletin Number: 05034
Bulletin Date: JUN 2005
Summary:
NOISE FROM REAR DOOR WITH WINDOW ALL THE WAY UP. ( NHTSA ITEM NUMBER - 10015415 )
7. ELECTRICAL SYSTEM:WIRING Bulletin Number: 04020
Bulletin Date: MAR 2005
Summary:
TRAILER LIGHT WIRING. TO INCLUDE INFINITI 2006 M35/M45. ( NHTSA ITEM NUMBER - 10012880 )
8. STEERING Bulletin Number: 03028A
Bulletin Date: SEP 2004
Summary:
STEERING DRIFT TO THE RIGHT. ( NHTSA ITEM NUMBER - 10005686 )
9. STRUCTURE:BODY Bulletin Number: 03052
Summary:
SQUEAK AND RATTLE REPAIR. COUPE ONLY. ( NHTSA ITEM NUMBER - 10003435 )
10. VISIBILITY:REARVIEW MIRRORS/DEVICES Bulletin Number: 04046
Summary:
RATTLE NOISE FROM REAR VIEW MIRROR HARNESS COVER. ( NHTSA ITEM NUMBER - 10009749 )
11. STRUCTURE:BODY Bulletin Number: 04035
Bulletin Date: AUG 2004
Summary:
RATTLE NOISE FROM REAR SIDE WINDOW FINISHER. ( NHTSA ITEM NUMBER - 10009175 )
12. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM) Bulletin Number: 04042
Summary:
NAVIGATION SYSTEM IS INOPERATIVE AND THE DISPLAY SHOWS DISC ERROR OR DVD-ROM VERSION IS NOT CORRECT. ( NHTSA ITEM NUMBER - 10009182 )
13. VISIBILITY:POWER WINDOW DEVICES AND CONTROLS Bulletin Number: 04033
Bulletin Date: JUL 2004
Summary:
WINDOW REGULATOR MOTOR RESET PROCEDURE. ( NHTSA ITEM NUMBER - 10009364 )
14. VISIBILITY:SUN ROOF ASSEMBLY Bulletin Number: 04024
Bulletin Date: MAY 2004
Summary:
SUNROOF LID SQUEAK/CREAK NOISE. ( NHTSA ITEM NUMBER - 10007679 )
15. INTERIOR LIGHTING Bulletin Number: 04019
Bulletin Date: APR 2004
Summary:
VANITY MIRROR MIRROR BULB REPLACEMENT. ( NHTSA ITEM NUMBER - 10007728 )
16. ELECTRICAL SYSTEM:WIRING Bulletin Number: 04020
Summary:
APPROPRIATE HOOKUP POINTS FOR CONNECTING A TRAILER LIGHTS WIRING HARNESS TO THE VEHICLE. ( NHTSA ITEM NUMBER - 10007727 )
17. ELECTRICAL SYSTEM Bulletin Number: 03055
Bulletin Date: FEB 2004
Summary:
BUZZ SOUND FROM METER CLUSTER AFTER IGNITION KEY IS TURNED OFF / TURN SIGNAL AND WARNING CHIME DO NOT SOUND. THIS REPLACES ITB03-055 DATED 8/20/03. ( NHTSA ITEM NUMBER - 10003514 )
18. SERVICE BRAKES, HYDRAULIC Bulletin Number: 03069A
Bulletin Date: JAN 2004
Summary:
REDUCTION OF FRONT BRAKE NOISE WHEN BRAKING IN REVERSE. THIS BULLETIN REPLACES ITB03-069. ( NHTSA ITEM NUMBER - 10005216 )
19. STRUCTURE:BODY Bulletin Number: 03050A
Summary:
SQUEAK AND RATTLE REPAIR. SEDAN ONLY. ( NHTSA ITEM NUMBER - 10005687 )
20. STRUCTURE:BODY Bulletin Number: 03052A
Summary:
SQUEAK AND RATTLE REPAIR. COUPE ONLY. ( NHTSA ITEM NUMBER - 10005688 )
21. EQUIPMENT Bulletin Number: 04001
Summary:
REMOTE KEYLESS ENTRY REPLACEMENT PARTS. ( NHTSA ITEM NUMBER - 10005194 )
22. STRUCTURE:BODY: DOOR Bulletin Number: 03071
Bulletin Date: DEC 2003
Summary:
RATTLE OR CREAK NOISE FROM TOP OF DOOR WINDOW FRAME. ( NHTSA ITEM NUMBER - 10005263 )
23. INTERIOR LIGHTING Bulletin Number: 03065
Bulletin Date: NOV 2003
Summary:
CLOCK BULB REPLACEMENT. VARIOUS MODELS INCLUDING 2004 I35. ( NHTSA ITEM NUMBER - 10004598 )
24. VISIBILITY:GLASS, SIDE/REAR Bulletin Number: 03058B
Bulletin Date: OCT 2003
Summary:
POP OR TICK NOISE FROM FRONT DOOR WINDOW GLASS. ( NHTSA ITEM NUMBER - 10004562 )
25. VISIBILITY:SUN ROOF ASSEMBLY Bulletin Number: 03060
Summary:
SUNROOF INOPERATIVE. 2004 FX35/FX45 INCLUDED. ( NHTSA ITEM NUMBER - 10003951 )
26. EQUIPMENT:ELECTRICAL:AIR CONDITIONER Bulletin Number: 02056A
Bulletin Date: SEP 2003
Summary:
NOISE FROM ENGINE AREA WITH AIR CONITIONER ON. ( NHTSA ITEM NUMBER - 10003595 )
27. ELECTRICAL SYSTEM Bulletin Number: 03020B
Summary:
MALFUNCTION INDICATOR LAMP (MIL) ON DIAGNOSTIC TROUBLE CODE (DTC) P0442 (EVAP SMALL LEAK) AND/OR P0456 (EVAP VERY SMALL LEAK) STORED IN SELF DIAGNOSIS RESULTS. ( NHTSA ITEM NUMBER - 10003916 )
28. VISIBILITY:GLASS, SIDE/REAR Bulletin Number: 03058A
Summary:
POP OR TICK NOISE FROM FRONT DOOR WINDOW GLASS. ( NHTSA ITEM NUMBER - 10003913 )
29. SEAT BELTS:FRONT Bulletin Number: ITB99016B
Bulletin Date: AUG 2003
Summary:
FRONT SEAT BELT LATCH PLATE RETAINING BUTTON MISSING. VARIOUS MODELS INCLUDING THE 2004 G35. ( NHTSA ITEM NUMBER - 10003519 )
30. STRUCTURE:FRAME AND MEMBERS Bulletin Number: 03017A
Bulletin Date: JUL 2003
Summary:
REAR PARCEL SHELF BUZZ OR RATTLE. ( NHTSA ITEM NUMBER - 10003437 )
31. STRUCTURE:FRAME AND MEMBERS Bulletin Number: 03023A
Summary:
RATTLE FROM THE REAR PARCEL SHELF. COUPE. ( NHTSA ITEM NUMBER - 10003457 )
32. SEATS:MID/REAR ASSEMBLY Bulletin Number: 03046
Summary:
A CREAK / SQUEAK NOISE FROM REAR SEAT AREA. ( NHTSA ITEM NUMBER - 10002937 )
33. STRUCTURE:BODY Bulletin Number: 03050
Summary:
SQUEAK AND RATTLE REPAIR. SEDAN ONLY. ( NHTSA ITEM NUMBER - 10003454 )
34. EQUIPMENT:ELECTRICAL:AIR CONDITIONER Bulletin Number: 03045
Summary:
NOISE FROM ENGINE AREA OR AIR CONDITIONER NOT COLD DUE TO BROKEN DRIVE BELT. ( NHTSA ITEM NUMBER - 10002936 )
35. ELECTRICAL SYSTEM Bulletin Number: 03020A
Bulletin Date: JUN 2003
Summary:
MALFUNCTION INDICATOR LAMP (MIL) ON DIAGNOSTIC TROUBLE CODE (DTC) P0442 (EVAP SMALL LEAK) AND/OR P0456 (EVAP VERY SMALL LEAK) STORED IN SELF DIAGNOSIS RESULTS. ( NHTSA ITEM NUMBER - 10003351 )
36. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM) Bulletin Number: 03026
Summary:
NAVIGATION SYSTEM STUCK ON PLEASE WAIT SCREEN. ( NHTSA ITEM NUMBER - 10003335 )
37. SEATS:FRONT ASSEMBLY:SEAT HEATER/COOLER Bulletin Number: 061003
Summary:
SEAT HEATER HARNESS VOLUNTARY SERVICE CAMPAIGN REPAIR INSTRUCTIONS MODIFICATION. ( NHTSA ITEM NUMBER - 10002087 )
38. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 03020
Bulletin Date: APR 2003
Summary:
MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0442 (EVAP SMALL LEAK) AND/OR P0456 (EVAP VERY SMALL LEAK) STORED IN SELF DIAGNOSIS RESULTS. ( NHTSA ITEM NUMBER - 10002202 )
39. STRUCTURE:FRAME AND MEMBERS Bulletin Number: 03023
Summary:
RATTLE FROM THE REAR PARCEL SHELF. COUPE. ( NHTSA ITEM NUMBER - 10001445 )
40. VISIBILITY:GLASS, SIDE/REAR Bulletin Number: 03021
Summary:
GREASE MARK OR STREAK ON INSIDE OF DOOR GLASS. ( NHTSA ITEM NUMBER - 10001677 )
41. STEERING Bulletin Number: 03028
Summary:
STEERING DRIFT TO THE RIGHT. ( NHTSA ITEM NUMBER - 10001676 )
42. ELECTRICAL SYSTEM Bulletin Number: 03007A
Bulletin Date: MAR 2003
Summary:
VOLUNTARY SERVICE CAMPAIGN AUDIO FINISHER CIRCUIT BOARD. ( NHTSA ITEM NUMBER - 10001253 )
43. STRUCTURE:FRAME AND MEMBERS Bulletin Number: 03017
Summary:
REAR PARCEL SHELF BUZZ OR RATTLE. ( NHTSA ITEM NUMBER - 10001256 )
44. SEATS Bulletin Number: 03018
Summary:
DRIVER'S SEAT COMFORT IMPROVEMENT. ( NHTSA ITEM NUMBER - 10001258 )
45. ELECTRICAL SYSTEM Bulletin Number: 03007
Bulletin Date: FEB 2003
Summary:
VOLUNTARY SERVICE CAMPAIGN AUDIO FINISHER CIRCUIT BOARD. ( NHTSA ITEM NUMBER - 10001246 )
46. ELECTRICAL SYSTEM Bulletin Number: 03014
Summary:
SLIP AND VDC OFF LIGHTS ON WITH C1145 YAW RATE SENSOR STORED. ( NHTSA ITEM NUMBER - 10001249 )
47. ELECTRICAL SYSTEM Bulletin Number: ITB03007
Summary:
VOLUNTARY SERVICE CAMPAIGN AUDIO FINISHER CIRCUIT BOARD. ( NHTSA ITEM NUMBER - 10001162 )
48. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 02074A
Bulletin Date: JAN 2003
Summary:
AUTOMATIC TRANSMISSION HARSH SHIFT WITH DIAGNOSTIC TROUBLE CODE (DTC) P1710 AND P1716 STORED. ( NHTSA ITEM NUMBER - 10000971 )
49. POWER TRAIN:MANUAL TRANSMISSION Bulletin Number: 03003
Summary:
MANUAL TRANSMISSION SHIFT KNOB NOT STRAIGHT. ( NHTSA ITEM NUMBER - 10001026 )
50. SERVICE BRAKES, HYDRAULIC Bulletin Number: 03006
Summary:
SQUEAK OR SQUEAL NOISE COMING FROM REAR BRAKES. ( NHTSA ITEM NUMBER - 10000972 )
51. SERVICE BRAKES, HYDRAULIC Bulletin Number: 03006
Summary:
REAR BRAKE NOISE. ( NHTSA ITEM NUMBER - 10001181 )
52. STRUCTURE:BODY:ROOF AND PILLARS Bulletin Number: 03004
Summary:
HEADLINER SAGGING AT REAR OF SUNROOF. ( NHTSA ITEM NUMBER - 10001027 )
53. EXTERIOR LIGHTING:HEADLIGHTS Bulletin Number: 03001
Summary:
VOLUNTARY RECALL CAMPAIGN - HEADLAMP ADJUSTER CAP INSTALLATION. ( NHTSA ITEM NUMBER - 10001023 )
54. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 02074
Bulletin Date: DEC 2002
Summary:
AUTOMATIC TRANSMISSION HARSH SHIFT WITH DIAGNOSTIC TROUBLE CODE P1710 AND P1716 STORED. ( NHTSA ITEM NUMBER - 10000019 )
55. INTERIOR LIGHTING Bulletin Number: 02081
Summary:
INTERIOR COURTESTY LAMPS INOPERATIVE. ( NHTSA ITEM NUMBER - 10000795 )
56. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 02010A
Bulletin Date: NOV 2002
Summary:
ENGINE WILL NOT START. VEHICLE IMMOBILIZER SYSTEM/NISSAN ANTI-THEFT SYSTEM (IVIS/NATS). ( NHTSA ITEM NUMBER - 10000406 )
57. WHEELS Bulletin Number: 02073
Summary:
TITANIUM FINISH ALUMINUM WHEELS. ( NHTSA ITEM NUMBER - 10000411 )
58. EQUIPMENT:ELECTRICAL Bulletin Number: 02072
Summary:
AMBIENT TEMPERATURE SENSOR DISPLAY INACCURATE. ( NHTSA ITEM NUMBER - 10000410 )
59. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 02064
Bulletin Date: OCT 2002
Summary:
REPLACEMENT AUTOMATIC TRANSMISSION REQUESTS NEW STYLE AUTOMATIC TRANSMISSION FLUID FILLER TUBE. ( NHTSA ITEM NUMBER - 10000213 )
60. SEAT BELTS:FRONT:BUCKLE ASSEMBLY Bulletin Number: 02067
Summary:
FRONT SEAT BELT BUCKLE BRACKET CAUSING CLICKING NOISE. ( NHTSA ITEM NUMBER - 10000212 )
61. EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC. Bulletin Number: 02062
Summary:
AUDIO MATRIX. ( NHTSA ITEM NUMBER - 10000215 )
62. ENGINE AND ENGINE COOLING:ENGINE:GASOLINE Bulletin Number: ITB02056
Summary:
INFORMATION REGARDING A BUZZ OR GROWL TYPE NOISE FROM THE ENGINE AREA WITH THE AIR CONDITIONER ON WHICH GOES AWAY WHEN THE AIR CONDITIONER IS OFF. ( NHTSA ITEM NUMBER - 635644 )
63. EQUIPMENT:ELECTRICAL:AIR CONDITIONER Bulletin Number: 02056
Summary:
BUZZ OR GROWL TYPE NOISE FROM ENGINE AREA WITH AIR CONDITIONER ON. ( NHTSA ITEM NUMBER - 10000216 )
64. ELECTRICAL SYSTEM:BATTERY Bulletin Number: ITB02055
Summary:
INFORMATION ON COUPE BATTERY SERVICE PRECAUTIONS. ( NHTSA ITEM NUMBER - 635643 )
65. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 02054
Bulletin Date: SEP 2002
Summary:
MALFUNCTION INDICATOR LIGHT (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P0442 (EVAP SMALL LEAK) STORED IN THE ELECTRONIC CONTROL MODULE (ECM). ( NHTSA ITEM NUMBER - 10000130 )
66. STRUCTURE:BODY Bulletin Number: 02060
Summary:
CREAK NOISE FROM FRONT END. ( NHTSA ITEM NUMBER - 10000132 )
67. SUSPENSION Bulletin Number: ITB02060
Summary:
SOME VEHICLES MAY EXHIBIT A CREAK NOISE FROM THE FRONT END WHILE DRIVNG OVER ROAD DIPS, RAIN CHANNELS, STREET INTERSECTIONS AND / OR DRIVEWAYS. ( NHTSA ITEM NUMBER - 635647 )
68. STRUCTURE Bulletin Number: 02028A
Summary:
CREAK OR RATTLE NOISE FROM THE BASE OF THE WINDSHIELD. ( NHTSA ITEM NUMBER - 10000129 )
69. STRUCTURE:BODY: DOOR Bulletin Number: 02057
Summary:
POP OR CLUNK NOISE FROM FRONT DOOR AND / OR WINDOW. ( NHTSA ITEM NUMBER - 10000131 )
70. VISIBILITY:WINDSHIELD Bulletin Number: ITB02028A
Summary:
INFORMATION PERTAINING TO A SQUEAK, CREAK, OR RATTLE NOISE COMING FROM THE CENTER OF THE DASH OR BOTTOM OF THE WINDSHIELD WHILE DRIVING. ( NHTSA ITEM NUMBER - 635640 )
71. STRUCTURE:BODY: DOOR Bulletin Number: ITB02057
Summary:
INFORMATION ON DIAGNOSING POP OR CLUNK NOISE FROM FRONT DOOR AND / OR WINDOW. ( NHTSA ITEM NUMBER - 635646 )
72. OTHER Bulletin Number: ITB02054
Summary:
THIS BULLETIN PROVIDES SERVICE INFORMATION FOR MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0442 (EVAP SMALL LEAK) STORED. ( NHTSA ITEM NUMBER - 635642 )
73. STRUCTURE:BODY: DOOR Bulletin Number: ITB02021A
Bulletin Date: JUL 2002
Summary:
CONCERNS WITH RATTLE OR BUZZ NOISE FROM FRONT DOOR PANEL(S). ( NHTSA ITEM NUMBER - 635047 )
74. POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM) Bulletin Number: ITB02017
Bulletin Date: APR 2002
Summary:
SUBJECT REGRDING TRANSMISSION CONTROL MODULE (TCM) INITIALIZATION AFTER TRANSMISSION REPLACEMENT. ( NHTSA ITEM NUMBER - 632216 )
75. STRUCTURE:BODY: DOOR Bulletin Number: ITB02021
Summary:
SUBJECT REGARDING RATTLE OR BUZZ NOISE FROM FRONT DOOR PANEL(S). ( NHTSA ITEM NUMBER - 631189 )
76. VISIBILITY:WINDSHIELD Bulletin Number: ITB02028
Summary:
SOME VEHICLES MAY EXHIBIT A SQUEAK, CREAK OR RATTLE NOISE COMING FROM THE BASE OF THE WINDSHIELD. ( NHTSA ITEM NUMBER - 635057 )
77. POWER TRAIN Bulletin Number: ITB02019
Summary:
CONCERNS WITH TACHOMETER NEEDLE ON WRONG SIDE OF STOP PIN. ( NHTSA ITEM NUMBER - 631192 )
__________________
Nature of Defect:
Defect Description:
Nature of Defect:
Defect Description:
Nature of Defect:
Defect Description:
Nature of Defect:
Defect Description:
Nature of Defect:
Defect Description:
Corrective Action:
Nature of Defect:
Defect Description:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
Summary:
__________________
Engine could stop, turn signals may be dim, fuel hose may leak, and the brake lamps may not light.
I drove that car in high school and it wasn't so bad. Heck I don't even think the toyota problems are THAT bad, but they treated them the same way ford treated the switchfire thing. That is the thing that bothers me. It looks like Nissan fessed up to big problems fairly quickly.
So how about more than a one liner.
OP: How many deaths has the myriad of problems with this Nissan had?
OP: The whole point of your thread title was to state that all cars have issues, and Nissan's G35, one particular model in one particular year, had a lot of issues.
OP: Toyota hid their issue since 1999, and the NHTSA has recorded quite a few instances of sudden acceleration with their cars.
OP: What was your point again? Dim witted what? Never mind.
Jamus22
06-11-2023 10:08 AM
SidhuSaaB
05-30-2020 12:40 AM
10003514, 2002, baton, code, dtc, g35, honda, infiniti, initialization, nissan, nissan45741inf, p1716, pathfinder, po442, tcm, troubleshooting
