L.A. Auto Show (Acura Related)
#41
The Creator
Originally posted by Shawn S
I think we need to DELETE this thread and start a NEW ONE when the official info is released and photos are linked.
Too much BS here to look through.
Shawn S
Shawn S
25 minutes till briefing.
#42
Moderator Alumnus
Originally posted by soopa
i agree...
i agree...
Cool idea on the new thread ...
#44
The Creator
Originally posted by Scorpius
Alas... thereis no v8 for the NSX... ths whole thing is a farse. At mist it'll be a 3.5 - 3.8 V6.
the V8 wont be here until the NEW NSX is here in '04.
that means the completely redesigned NSX.
this is just a facelifted NSX to boost interest in anticipation for the NEW car.
Acura does this with all their models.
Refreshing facelift 1-2 years before major change.
#45
Cost Drivers!!!!
#47
The sizzle in the Steak
Sorta like the '03 CL
#49
Happy CL-S Pilot
2002 NSX press release has been released....
http://www.hondanews.com/Forms/corp/*ws4d-db-query-Show.ws4d?*ws4d-db-query-Show***001786***-wieck_media***-***corp(directory)***.ws4d?corp/results(r)_text.html
2003 CL press release to follow
#50
2003 Acura 3.2 CL Luxury Performance Coupe Adds All-New 6-Speed Manual Transmission
LOS ANGELES, Jan. 4 /PRNewswire/ -- Enhancing its appeal to upscale
driving enthusiasts, the Acura 2003 3.2 CL luxury performance coupe will offer
in March 2002 an all-new, close-ratio 6-speed manual transmission to
complement its powerful 6-cylinder VTEC(TM) engine and high performance
chassis. In addition, the 2003 3.2 CL features more aggressive styling and an
array of interior enhancements including an optional OnStar(R) communications
service.
"For performance enthusiasts, the addition of a manual transmission makes
driving this powerful and responsive sport coupe even more rewarding," said
Dick Colliver, executive vice president, sales. "We have given the CL the
performance attributes driving enthusiasts demand, a powerful engine, ultra
responsive handling and cutting edge technology, combined with the latest
luxury appointments and safety features."
For 2003, the CL Type-S model comes with either the new 6-speed manual
transmission or a 5-speed Sequential SportShift(TM) automatic transmission.
The 3.2 CL model comes exclusively with the 5-speed Sequential SportShift
The CL Type-S model's all-new, close-ratio 6-speed transmission is
lightweight and compact and delivers smooth, responsive shifting. This manual
transmission features the latest in Acura technology including:
* A shifter linkage designed for short strokes and constructed of large
diameter cable for more direct shifting feel
* Close gear ratios to provide responsive engine control
* A self-adjusting clutch to ensure a consistent pedal engage point
throughout the life of the clutch
* Brass multi-cone synchronizers to reduce shifting load
* New transmission refinements for reduced shift shock
* Dual-mass flywheel for improved NVH performance
In addition, to give drivers more precise control of the car when
cornering, the CL Type-S with 6-speed manual transmission comes with a new
limited slip differential. Unlike many limited slip differentials, the CL
Type-S uses a set of gears to direct the appropriate amount of torque to the
right and left driving wheels by sensing wheel spin. If the inside tire loses
traction and starts to spin as the car negotiates a tight turn, the
differential redirects torque to the outer tire. This transfer helps keep the
inside wheel from spinning, allows the driver to apply throttle sooner through
turns, helps maintain a more neutral handling balance and results in an
extremely responsive steering feel.
All 2003 CL models are powered by 3.2 liter, 24-valve, all aluminum, V-6
engines featuring the patented VTEC(TM) (Variable Valve Timing and Lift
Electronic Control) system. The 3.2 CL's engine produces 225 horsepower and
216 lb-ft of torque, providing quick acceleration and effortless cruising.
The CL Type-S delivers 260 horsepower at 6100 rpm, and 232 lb-ft of
torque between 3500 and 5500 rpm due to the addition of several elements
including a high volume, dual-stage induction system, a low-restriction
dual-outlet exhaust and an increased compression ratio. Platinum-tipped spark
plugs and other long-life components allow the 3.2 CL to run for 105,000 miles
before the first engine tune up. EPA fuel mileage for the 3.2 CL and the CL
Type-S with 5-speed automatic transmission is 19 mph city and 29 mph highway.
Estimated fuel mileage for the CL Type-S with 6-speed manual transmission is
19 mph city and 28 mph highway.
To convey the sleek, aggressive look of a high-performance coupe, the 2003
3.2 CL has received styling updates inside and out. In front, the grille
receives a body-colored surround and a more aggressive air intake in the
bumper lower, while in the rear, the CL gets a new tail light lens with a
clear upper portion and a sporty exhaust pipe finisher. Both the 3.2 CL's
16-inch wheels and the CL Type-S model's 17-inch wheels have been restyled to
portray a lightweight, high performance image.
All CL models come with a leather-trimmed interior. The center console on
the CL Type-S with manual transmission has been redesigned to accommodate the
new shifter mechanism, hand operated parking brake and a redesigned cup holder
with sliding shutter cover. Easy-to-read instruments are backlit for maximum
visibility and CL Type-S models feature sporty metallic-faced gauges.
One of the most fully-featured coupes available, the 3.2 CL luxury
performance coupe is equipped with a comprehensive list of features including
an Acura/Bose(R) Music System with in-dash 6-disc CD player, Automatic Climate
Control, a power moonroof and heated front seats. The DVD-based Acura
Satellite-Linked Navigation System, which includes over 3.7 million
points of interest and a 6-inch, color LCD display, is a factory-installed
option.
For 2003, the 3.2 CL receives several new safety, convenience and
technology features including the Lower Anchors and Tethers for Children
(LATCH) child seat restraint system and a dual-stage driver's front airbag.
Models equipped with the Acura Navigation System also include OnStar(R), a
24-hour, in-vehicle communications and assistance service that gives the
driver access to a vast array of available services -- from emergency roadside
assistance to route and location guidance and online concierge services.
All CL models are equipped with standard Xenon High Intensity Discharge
(HID) headlights for excellent nighttime visibility, Anti-lock Braking System
(ABS) and driver's and front passenger's airbags with a dual stage inflation
system.
The CL Type-S with Sequential SportShift automatic transmission adds a
unique Vehicle Stability Assist (VSA) system that monitors wheel speed and
lateral (cornering) stability to seamlessly integrate traction control,
anti-lock braking and stability control functions. This innovative VSA System
is designed to assist the driver in maintaining control during acceleration,
cornering and sudden collision-avoidance maneuvers by applying brake force to
the right or left front wheel as necessary, and managing the throttle and fuel
injection systems.
Like all Acura models, the CL is covered by a comprehensive
4-year/50,000 mile bumper-to-bumper limited warranty. Additional ownership
benefits include Acura Total Luxury Care (TLC), which provides free 24-hour
roadside assistance, concierge service and trip routing.
service.
option.
system.
injection systems.
#51
The Creator
here ya go:
2003 3.2 CL Luxury Performance Coupe - Summary of Changes
ascii | MSWord
Torrance, Calif. 01/04/2002 -- For the 2003 model year, Acura's goals for the 3.2 CL were to:
Increase performance
Update styling for a sleeker, more aggressive look
In support of those goals, the 2003 3.2 CL has received the following enhancements:
Powertrain
While it continues to come with a 5-speed Sequential SportShift automatic transmission, the CL Type-S now offers a new close ratio 6-speed manual transmission as well. Models with the new manual transmission also feature:
o Helical limited slip differential
o Curb weight of 3446 lbs. (compared to 3510 lbs. for the CL Type-S with automatic transmission)
o Multi-cone synchronizers
o Self-adjusting clutch with dual-mass flywheel
o Short-throw shift linkage
Chassis
CL Type-S with manual transmission replaces the VSA found in the CL Type-S with automatic transmission with new helical limited slip differential
New 6-spoke 16 inch wheels (3.2 CL)
New 6-spoke 17 inch wheels (CL Type-S)
CL Type-S with manual transmission adds two hydraulic engine mount dampers to counter engine movement
Body
Front Styling
o Revised grille with body-colored surround
o Revised headlights with black accents
Rear Styling
o Revised taillight lenses with clear upper portion
o New exhaust finishers
Safety/Convenience
OnStar(R) is standard equipment on CL models equipped with the Acura Satellite-Linked Navigation System
Lower Anchors and Tethers for Children (LATCH) System added on outboard rear seats for child safety seat attachment
Driver's Dual Stage Supplemental Restraint System (SRS)
Auto-up driver's side window
Interior Styling
CL Type-S
o Models with black interiors receive titanium-look trim on doors and center console
o In models with 6-speed manual transmission, center console redesigned to accommodate manual shifter and hand-operated parking brake
o Perforated leather door inserts
ascii | MSWord
Powertrain
Chassis
Body
Front Styling
Rear Styling
Safety/Convenience
Interior Styling
CL Type-S
#52
Looks like they are all swapable...
Front Styling
Rear Styling
Can't wait to check them out, I am all about some new tail lights and grill...
Front Styling
Rear Styling
#53
Moderator Alumnus
OH MY !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
http://www.hondanews.com/Forms/corp/...s(r)_text.html
rockyboy
01-25-2016 06:00 PM
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
