Just bought an Acura Integra 1994! Have some problems.
Old Jul 16, 2008 | 10:45 PM
Eband27's Avatar
Hey guys. I just bought myself an acura integra 1994 RS 5 speed as a second car, winter beater and delivery car.
I got it for 1000$, very cheap. It has rust here and there.
But the problem right now, the shift is VERY stiff, very hard to shift... the car was not being driven for 2 months. What could be the problem? The clutch is ok.. when its in gear, it goes fine.
Old Jul 17, 2008 | 12:33 AM
Blazing GT's Avatar
garbage
Old Jul 17, 2008 | 04:01 AM
Costco's Avatar
Try topping off the tranny fluid. The linkage could also be slightly seized since the car sat there for a while.... by using it as a winter beater car I assume you live in a snowy area during fall/winter? Not too sure how Canada's climate works. If topping it off doesn't work, try draining it then filling it up again.... if it isn't black as coffee or have tons of metal shavings in it, then try getting a new shift linkage.
Great price though. Integras are the some of the best fun for your money cars you can get out there.
Old Jul 17, 2008 | 06:47 AM
GreenMonster's Avatar
Originally Posted by Blazing GT
garbage
Who pissed in your Cheerios this morning ???
If you don't have anything nice to say, don't say anything at all...
Old Jul 17, 2008 | 07:23 AM
NSXNEXT's Avatar
Time for a tranny fluid change.
Old Jul 17, 2008 | 08:11 AM
1killercls's Avatar
GEEZER
I would burn it.
Old Jul 17, 2008 | 08:39 AM
Loseit's Avatar
Changin bulbs since '73
^^^ Apparently, someone pissed in Killer's cheerio's as well
Old Jul 17, 2008 | 08:45 AM
TzarChasm's Avatar
Of course, he has them that way every morning. You don't think he is this ornery by accident do you?
Old Jul 17, 2008 | 08:47 AM
RMATIC09's Avatar
maybe you can put wd40 on the gears
Old Jul 17, 2008 | 09:12 AM
fsttyms1's Avatar
Check under the hood for stuff in the way of the shifter cables (Like a rodents nest). Maybe they need some lubrication? Can you work them back and forth for awhile to free them up any?
Old Jul 17, 2008 | 09:21 AM
Eband27's Avatar
lol. I'll make the oil change and tranny oil change at the same time. The car has 270.000 km on it, but it was driven by an old guy.. Should i get the sycromesh from gm, redline or just the honda manual tranny oil?
Ill have to check the cable, see if i can squirt some oil on it :-)
O, btw, my first car is an 1997 Acura 2.2cl :P
i like the integra, very quick, but now the shift is ruinning everything
Old Jul 17, 2008 | 09:33 AM
gocubsgo55's Avatar
101 years of heartache...
One of 2 things, but probably the 1st as some have said:
1. Drain and replace the tranny fluid
2. Loosen the shifter bearings a little, but this usually is an issue when someone has installed a new shifter, ie. short shifters.
Old Jul 17, 2008 | 11:09 AM
ChrisQ1980's Avatar
hates the winter
Clutch master cyl is probably low on fluid or bad. It's a common problem on those cars. Join www.team-integra.net for an overwhelming out of info.
Old Jul 17, 2008 | 11:25 AM
1killercls's Avatar
GEEZER
Old Jul 17, 2008 | 12:11 PM
Trackruner228's Avatar
Old Jul 17, 2008 | 01:02 PM
JS + XES's Avatar
I drive a Subata.
garbage
the fuck?
Old Jul 17, 2008 | 01:04 PM
JS + XES's Avatar
I drive a Subata.
this is my answer as well
Old Jul 17, 2008 | 02:18 PM
vwong's Avatar
n00b
You can't check the shift cable because there is none. Integra (DB and DC chassis) uses shift linkages. Unlike shift cables found in Preludes, Accords, or TSXs, there are 2 metal linkages that connect the bottom of the shifter and the tranny. Other than the tranny fluid change as suggested by others, I would recommend checking the linkages to make sure they're not bent, and not interfered with other things.
Old Jul 17, 2008 | 02:53 PM
The Dougler's Avatar
Unofficial Goat
this about sums up where the OP is from
OP: Get the GM fluid it works really well, but as other said check out the clutch master and slave cylinders.
Old Jul 17, 2008 | 05:13 PM
Costco's Avatar
Yeah, chances are the linkage is seized... I can only imagine what being buried underneath two feet of snow for a few months would do to my car...
I used to have a 95 LS sedan and I used the Pennzoil Synchromesh. Its the same just minus the friction modifiers. It made the shifts like butter and it got rid of most of the grinds - still grinded a bit in reverse but less than before. I highly recommend it.
Old Jul 17, 2008 | 06:14 PM
dallison's Avatar
registered pw
Originally Posted by 1killercls
I would burn it.
we should burn florida.
and nice price for a 94
Zonian22
Nov 14, 2015 01:20 PM
nanos
Nov 12, 2015 08:41 PM
BobbyGraham388
Oct 22, 2015 05:05 PM
Trplezero
Sep 3, 2015 10:25 PM
Zonian22
Sep 2, 2015 08:19 AM
