Jay Leno's latest - Corvette C6RS
i wonder what it could do on higher octane fuel. i hope a lot more, but im not familiar with this e85 stuff and how much it dampers performance.
ive seen 600+hp 2.4L 4cyl RSX's so for 8.2 L of displacement it seems weak.
A naturally aspirated 2.4L producing 600hp? WTF gas is it using nitromethane? I don't think so. It's some (forced induction) turbo setup your talking about. And the RSX can't even come close to putting down 600hp to the pavement. Or are you going to drive it around the streets with 10" wide drag slicks on the front? Then do huge burnouts every time you want to race/get on the gas? Now on the other hand the Corvette isn't even stressed at 600hp; and it CAN put down 600hp to the pavement and use it without looking like a clown mobile with wheels/tires sticking out of it's fenders.
Perhaps if you mentioned a 2.4L engine naturally aspirated producing 600hp on e85 it'd be worth mentioning... since it's not; it's kinda silly to bring up don't you think?
I mean do you really think they couldn't slap two turbos on that engine with methane/water/propane injection and push it to 1500hp easy? But it wasn't the point of the build; that seems to be the part you're missing here.
well....e85 is between 100-105 octane...so it's on good gas....those numbers are jaw dropping at first, considering it's a custom-built forged motor... we all know there's plenty more left in it.
It may have a high octane, but it's not really good gas as it uses almost twice as much per tank as regular gas.
# While diesel contains around 140,000 British thermal units (Btu) per gallon, and gasoline 115,000 Btu, denatured ethanol contains only 78,000 Btu per gallon; these numbers translate into low fuel mileage.
# For example, CU tested a new Chevy Tahoe and found that in highway driving (on 85 percent ethanol), gas mileage decreased from 21 to 15 mpg; in city driving, it dropped from 9 to 7.
http://www.ncpa.org/sub/dpd/index.php?Article_ID=13652
http://www.consumerreports.org/cro/c...anol_ov1_1.htm
Originally Posted by parshooter
Hey Jay, instead of trying to save the planet by using E85 fuel in one of your hundreds of cars, why don't you donate the $100,000 + you spent on that vette to a worthwhile cause
Leno, and more specifically, his wife Mavis are responsible for literally millions in charitable donations to a variety of causes...Let the man have his vette...
There's alot of asian in
Originally Posted by Bdog
Wonder what his mpg is, since E85 sucks? Also, don't like the body kit in front of the rear wheel, it just looks out-of-place... engine looks hot though!
Originally Posted by SiGGy
Wow, I like the widebody work they did. Looks like a nice car. I wonder where he makes his gas though.
600 HP naturally aspirated is weak?
Press release from GM...
LAS VEGAS – “Tonight Show” host Jay Leno’s predilection for performance cars is no secret, but many fellow enthusiasts may not know that he is keenly interested in alternative fuels. To prove that red-blooded power mixes easily with a touch of green, Leno partnered with Pratt & Miller – the engineering company that builds and campaigns C6.R Corvettes – to develop a modified Corvette Z06 that is capable of running on E85 ethanol. It was unveiled at the 2007 SEMA Show.
More than merely a conversion of the stock LS7 engine to E85 capability, Leno’s alternative-fuel supercar is powered by a custom, 8.2L (500-cubic-inch) all-aluminum small-block V-8 that pumps out approximately 600 horsepower and 585 lb.-ft. of torque.
“The C6RS is the result of an idea we hatched to prove that high-performance cars and alternative fuel technology weren’t diametrically opposed concepts,” said Leno. “I love the idea of having 600 horsepower at my disposal, but using a homegrown alternative to gasoline.”
The engine is built around a custom aluminum cylinder block that was CNC-milled from a single block of billet aluminum. And while the cylinder heads, intake system and dry-sump oiling system are stock LS7 components, the engine – which has larger bore and stroke dimensions than the 7.0L (427-cubic-inch) LS7 – uses a one-off reciprocating assembly, including a forged steel crankshaft, forged rods and forged pistons. Katech Engines, the company that builds engines for the Corvette C6.R racing program, developed the engine.
The fuel system and engine control computer were modified to accommodate E85, and spent gases exit through a Corsa exhaust system. Supporting the 600-horse engine’s power is a blueprinted and strengthened T-56 six-speed transmission and a high-performance Centerforce dual-friction clutch.
C6.R inspiration
On the outside, Leno’s bad and black C6RS emulates the styling of C6.R racecars, with wider front and rear fenders and a wider rear fascia with an integrated spoiler on top and a racing-style diffuser at the bottom (the diffuser incorporates an LED-lit backup lamp). A C6.R-style waterfall hood front fender louvers, rockers and lower grille opening further define this special Corvette – and all of the car’s front-end panels are made of carbon-fiber, including custom brake air ducts routed through the front fenders. With all of its body modifications, Leno’s C6RS is 1.6 inches wider than stock.
The C6.R’s – and production Corvette’s – aerodynamically styled bodywork is designed to slice efficiently through the wind, which helps enhance fuel mileage.
The race-ready look of the car is enhanced with a quartet of BBS wheels that feature racing-type locking center hubs. The forged aluminum 18-inch front wheels and 19-inch rear wheels ride on Michelin P295/30ZR18 and P345/30ZR19 tires, respectively.
Adding authenticity to the car’s custom bodywork was the involvement of Pratt & Miller. The company took on the task of crafting Leno’s Corvette into a street-going replica of the racecars, which included installing or fabricating a host of unique components, including:
• A custom DeWitt high-capacity radiator with dual cooling fans
• A carbon-fiber ram-air induction system
• Carbon-fiber inner fender panels that vent hot air from the engine compartment
• Brembo brakes with six-piston mono-block calipers in front and four-piston rear calipers
• Dyna-Mat used throughout the cabin and chassis to reduce interior noise
While the exterior and drivetrain were inspired by the racetrack, the C6RS’s cabin exudes luxury, with premium touches and enhancements from Genuine Corvette Accessories that include a two-tone shift knob and boot; leather-covered console armrest, parking brake handle and boot; an interior trim kit, racing-style pedal covers and more.
With its 600 horses on tap and domestically produced E85 fuel in the tank, Jay Leno’s alternative-fueled C6RS is an all-American supercar that proves high performance and environmental consciousness go together like the Corvette and checkered flags.
C6.R inspiration
like i said...i dont know anything about e85, so if you do and say its a great challenge to get 600 hp out of 8.2 L on that gas then sweet.
Originally Posted by fdl
So do you know of a natural aspirated 2.4L RSX producing 600 HP? Or anywhere even close to that?
not trying to start an e-war here lol. i was just stating my opinion whether its wrong or not.
nope, didnt say that i did either. 600 hp out of a 2.4 L on the street is crazy, boosted or not. thats all i was trying to say. i just figured with that much displacement there would have been more power thats all. think about the S2k HP/liter displacement numbers...... 2.0L with 240hp!
I have one word for you.
Torque.
mlody
Dec 4, 2019 02:11 PM
Sep 25, 2015 06:14 PM
ostrich
Sep 11, 2015 04:28 PM
yap. rsx-400hp 200ft/lbs.
