It's The "WTF is This Tool For" Thread...
Old May 13, 2009 | 10:44 AM
DiaBando's Avatar
gistered User
I inherited by default, a zillion tools from my Father; 30 years ago. And some I've pushed around, looking for a screwdriver or something I easily recognize. So, now before, some day, I pass them along; I want to know their function.
Exibit A:
Old May 13, 2009 | 10:48 AM
Josh99CL's Avatar
Looks like some type of fancy clamp.
Old May 13, 2009 | 10:50 AM
DiaBando's Avatar
gistered User
Exhibit B:
Old May 13, 2009 | 10:55 AM
AMGala's Avatar
Lamborghini Aventador FTW
Exhibit B looks like an engine damper removal tool like the harmonic balancer
Old May 13, 2009 | 11:02 AM
tmnhs81's Avatar
B is a puller.
DiaBando's Avatar
gistered User
I've got several of these in several sizes.
Old May 13, 2009 | 11:05 AM
DiaBando's Avatar
gistered User
I must have atleast 60 plyer–of different sizes and types. I'm soaking a bag-full in WD40, to loosen them up.
Old May 13, 2009 | 11:10 AM
DiaBando's Avatar
gistered User
'A' looks like it would compress something big-given the clearance of the 'C' shape.
Old May 13, 2009 | 11:12 AM
DiaBando's Avatar
gistered User
Originally Posted by tmnhs81
B is a puller.
To pull what? Do you have an example on what it would be used?
Old May 13, 2009 | 11:26 AM
Shalooby's Avatar
Secret Agent
A is a valve spring compressor. It's used for your typical pushrod engine. The "cup" part goes on the bottom of the valve and the forks on top go on either side of the spring retainer. When the spring is compressed the retainer clips are removed then the whole valve / spring / retainer can be removed from the head.
word of caution - don't let it slip off while it's compressing the spring. Lots of excitement happens then.
Old May 13, 2009 | 11:28 AM
drdamian's Avatar
FOR SALE - BM
B" looks like something to open old fire hydrants
Old May 13, 2009 | 11:30 AM
Josh99CL's Avatar
Are these all supposed to be auto related tools or just random?
Old May 13, 2009 | 11:56 AM
DiaBando's Avatar
gistered User
Jeez, my dad was under more cars than I could count; everything from his '57
porche, Citroen, '55 Belaire, Simca, English Ford, he even bought a '65 Gryphon(?)-'til my mother screamed at him to get his money back, so, I'm assuming they're car related.
Old May 13, 2009 | 12:01 PM
JS + XES's Avatar
I drive a Subata.
Okay grandpa
Old May 13, 2009 | 12:19 PM
Blazin Si's Avatar
B kinda looks like an older version of a ball joint/tie rod separator.
edit - it might be a steering wheel puller.
Old May 13, 2009 | 12:23 PM
Costco's Avatar
Yup, A is a valve spring compressor.
And B is a jaw type puller, most likely for pulleys.
Old May 13, 2009 | 01:06 PM
DiaBando's Avatar
gistered User
Originally Posted by JS + TL
Okay grandpa
Not a gramps, yet. Late start on a 'family'; 28.
Old May 13, 2009 | 01:34 PM
tmnhs81's Avatar
I have used this tool to pull steering wheels and harmonic balancer.
Old May 13, 2009 | 03:18 PM
Bdog's Avatar
Not Registered
The first one looks like an old piston clamp or vise grips first design for an adjustable c clamp. The second one is definitely a pully puller.
Old May 13, 2009 | 09:15 PM
Gfaze's Avatar
S E L L
Exibit A:
Valve spring compressor.
Old May 13, 2009 | 10:09 PM
The Dougler's Avatar
Unofficial Goat
Cool thread topic. More exhibits please.
B is a puller, you could probably use it for more than 1 purpose. I.E. Steering wheel removal, pulling pulleys, and possibly some suspension parts.
Old May 14, 2009 | 12:23 AM
Gfaze's Avatar
S E L L
This one may stump most of you. :devilgrin
Old May 14, 2009 | 03:03 AM
Costco's Avatar
Ok the first two were obvious but WTF is that?
edit: okay I cheated by looking at the link for this one when I quoted you... but I still don't know why you can't just use a brush
Old May 14, 2009 | 03:17 AM
Costco's Avatar
Exclamation No cheating
Old May 14, 2009 | 07:05 AM
fsttyms1's Avatar
^ looks like a spring tool that grabs both intake and exhaust? For what?
Old May 14, 2009 | 08:12 AM
phee's Avatar
I got the Shifts
obviously a ninja star sharpener
Old May 14, 2009 | 08:23 AM
Costco's Avatar
damn you
Its so that you can remove and install two springs at once
Old May 14, 2009 | 11:52 AM
DiaBando's Avatar
gistered User
how about this:
Old May 14, 2009 | 11:59 AM
DiaBando's Avatar
gistered User
for threads?
Old May 14, 2009 | 12:08 PM
DiaBando's Avatar
gistered User
Labeled pocket size. Weird; plastic-but feels like dense cardboard.
Old May 14, 2009 | 12:10 PM
DiaBando's Avatar
gistered User
It's not an automotive tool-but interesting design.
Old May 14, 2009 | 12:13 PM
DiaBando's Avatar
gistered User
Front and back. Its an old rachet wrench. Very heavy.
Old May 14, 2009 | 12:31 PM
DiaBando's Avatar
gistered User
Originally Posted by I Go To Costco
Damn! just saw this in my Jegs catalog–on the crapper this AM!
Old May 14, 2009 | 12:55 PM
Hockeyman's Avatar
slobalt defender
easy one...
Old May 14, 2009 | 05:32 PM
Costco's Avatar
^idk
how about this:
it kinda looks like a REALLY old micrometer... its so you can measure thicknesses of various little parts. Does it have numbers and hash marks on the barrel?
for threads?
yup, tap an die set - in case you cross thread something and need to clean it up
Old May 14, 2009 | 05:43 PM
Costco's Avatar
this thread is fun, and so is this next tool
this one not so much
Old May 14, 2009 | 05:48 PM
iTimmy's Avatar
dɐɹɔ ǝɥʇ ʇɐɥʍ
^^^^ First one is a slide hammer, which has a million and one uses when working on various cars. The second one is a spindle liner upper thing when doing clutches/pressure plates.
Old May 14, 2009 | 05:49 PM
TommySalami's Avatar
E92
First one's for removing dents or pulling something right?
Old May 14, 2009 | 05:56 PM
Costco's Avatar
YOU just had to reply first, didn't you?
You know..... MAYBE if you ghetto rigged a suction cup onto it....
but no, its not for dents. It is a puller though. you thread one end into the stubborn part of choice, then if needed you thread another one into another spot. the handle part is like a big weight.... pull both back towards you fast at the same time, and out comes the stubborn part.
Old May 14, 2009 | 06:04 PM
Unofficial Goat
You can get different ends that screw on to make it more adaptable.
