Infiniti FX45: Car and Driver says it's faster than the ML55 and BMW X5 4.6is
Old 01-12-2003, 10:47 PM
Moderator Alumnus
gavriil's Avatar
Dynamic Styling, Aggressive Stance
By definition, crossover SUVs incorporate elements of passenger cars into sport utility vehicles. What is often lost in the transition, however, is a sense of style or personality. In creating the new FX45, its designers sought what they called a "cool fusion" – the blending of a substantial, SUV lower body with the sleek, elegant upper body more reminiscent of a classic sports car or sports GT.
"The FX45 draws on a foundation born of our G35 sport coupe and sport sedan and our experience with our popular QX4 SUV – elements of which come through the first time you set eyes on the FX45," said McNabb. "Thus the exterior is all about projecting a unique sense of agility and dynamic performance – along with a healthy dose of SUV versatility and the all-wheel drive flexibility to occasionally leave the paved world behind."
The exterior of the FX45 features a wide, aggressive stance with a long, sleek hood, sleek roof and a "taut canopy" greenhouse. The short front and rear overhangs provide SUV-level approach and departure angles, while also helping accentuate the long wheelbase, wide track and large tires (20-inch on V8-equipped models). The wide yet narrow headlights and taillights give the FX45 an "in-motion" look, with the taillights extending past the body slightly to help create aerodynamic downforce.
The FX45 exterior also features a large Infiniti signature grille, standard fog lights, xenon headlights and large, split dual tailpipes with chrome finishers. Special attention was also paid during the design process to surface quality, parts quality and in creating a sense of elegance and grace. A special palette of exterior colors (eight total) was chosen to highlight and, at times, contrast the aggressive nature of the FX45, ranging from a vivid Laser Red and signature Liquid Copper to a deep Beryllium 16 and cool Brilliant Silver.
"The look of the FX45 is athletic – a coiled spring rather than brute force," said McNabb. "It looks strong, capable and most of all, stunningly original."
Dominating Performance From Confidence-Inspiring Engines and Platform
The FX45's long 112.2-inch wheelbase and wide track (62.7-inches front, 64.6-inches rear) combine with standard 20-inch wheels and tires (optionally available on V6 models) to provide a stable foundation for on- or off-road driving – as well as a large interior for both passengers and cargo. The FX45 utilizes an enhanced version of the innovative FM (for Front Mid-ship) platform used on the G35 sport coupe and G35 sport sedan, which positions the engine behind the front axle.
This results in an optimized front-to-rear weight balance of 54:46 (V8 AWD), which factors in weight transfer during key handling maneuvers, such as entering and exiting corners. The FM platform's rigidity has been enhanced, for use specifically with the FX45, by increasing plate thickness of the front side members, side sills and rear wheel housing.
Two engines are available, starting with the high-performance power of the 4.5-liter DOHC V8. This advanced powerplant, also used in the Infiniti Q45 and M45 sedans, has been specially tuned for use in the FX45 and produces 315 horsepower (versus 340 hp in the Q45 and M45) and 329 lb-ft of torque (versus 333 lb-ft in the Q45 and M45).
The engine's advanced design includes titanium valves, modular cylinder heads, microfinished crankshaft, lightweight pistons, super-silent single stage cam drive chain and a hydraulically driven cooling fan to help optimize performance. In addition, the VK45DE is outfitted with a variable length air induction system and Continuously Variable Valve Timing Control System (CVTCS) to enhance the engine’s power delivery and operation efficiency.
Also offered is a 3.5-liter DOHC 24-valve V6 engine with aluminum-alloy block and heads and electronically controlled "drive-by-wire" throttle system. Both the standard all-wheel drive and optional rear-wheel drive V6 engine-equipped versions are designated as FX35 models.
Like the V8, the V6 has been specially tuned for use in the FX35, with a horsepower rating of 280 (versus 280 and 260 horsepower in the G35 coupe and sedan respectively). Torque is rated at 270 lb-ft (versus the G35 coupe and sedan’s 270/260 lb-ft).
A 5-speed automatic transmission with manual shift mode, designed for high torque capacity and light weight, is standard with both V8- and V6-equipped models
Infiniti’s advanced Vehicle Dynamic Control (VDC) system with Traction Control System is also standard on every 2003 FX45. Vehicle Dynamic Control adjusts brake pressure and engine torque automatically in understeer, oversteer or slippery road surface situations, helping the drivers keep their intended paths.
The ATTESA E-TS (Advanced Total Traction Engineering System for All Electronic Torque Split) all-wheel drive system utilized on FX45 uses an advanced torque split control strategy that automatically transfers optimum torque to the wheels according to road and driving conditions. It provides outstanding cornering capability similar to a sports car due to optimum torque distribution for front and rear (0:100 up to 50:50). The system also provides high starting traction performance and smooth, stable acceleration, especially in snow-covered or off-road situations with the driver-selectable Auto/Lock AWD mode providing maximum traction.
FX45's dynamic handling is a result of its advanced 4-wheel independent suspension with extensive use of aluminum-alloy components to reduce unsprung weight and incorporate special "High Frequency Control" shock absorber technology with a Rebound Spring for responsive yet comfortable ride and firm, tight handling. The front suspension utilizes an independent front strut design, while the rear features a multi-link design. Large diameter stabilizer bars are utilized front and rear (front only on V6 RWD model).
Helping enhance ground clearance and all-terrain drivability are the FX45's standard 8.0JJx20
8-spoke aluminum-alloy wheels and 265/50R20 all-season tires (optionally available with V6 models). Standard on V6-equipped FX35s are 8.0JJx18 7-spoke aluminum-alloy wheels and 265/60R18 all-season tires.
Standard braking system components include 4-wheel ventilated disc brakes, Brake Assist (BA) and Electronic Brake force Distribution (EBD). Responsive steering is provided by an engine-speed-sensitive power rack-and-pinion steering system.
Also available on FX45 models with the Intelligent Cruise Control System is a special feature of the standard Brake Assist System – Preview Braking. Brake Assist with Preview Function is designed to improve brake response. Whereas normally braking is activated only when the driver recognizes the need and moves his or her foot to activate the brake pedal, the Preview Function utilizes the ICC sensors to identify sudden braking situations (by sensing the vehicle ahead in the same lane and the distance and relative speed from it) and "pre-pressurizes" the Brake Assist system before the driver steps on the brake pedal. This helps maximize braking response and performance by reducing the normal brake system activation time lag.
A High Tech Interior Accentuated with Luxurious Comfort
The five-passenger interior of the FX45 provides a blend of the comfort and amenities of a luxury car with an array of high tech features for the driver and passengers. The designers created three separate "zones" -– each personalized for the specific needs of the persons using it.
The "driver zone" maximizes driving excitement through the creation of a cockpit-like feel with driver-oriented controls, 8-way power-adjustable seat with memory function, driver-dedicated automatic air conditioning, information display monitor (6.3-inch standard, 7.0-inch with the Technology Package) and a three-spoke, leather-wrapped steering wheel with power tilt (standard on V8 models, moves in tandem with the instrument cluster) and telescope, integrated cruise and available steering wheel-mounted audio system controls.
The "comfort zone," designed to maximize comfort for the front passenger, includes a 4-way power-adjustable seat, passenger adjustable armrest and individual air conditioning control. The "play zone" offers rear seat passengers such available features as a DVD player with wireless headphones, personal reading lamps, center armrest with tray and storage, dual seatback pockets for storing DVDs and magazines, reclining seats and rear B-pillar mounted air conditioning vents for enhanced cooling performance.
Every FX45 model also offers exceptional utility, including a large cargo area with easy cargo accessibility, flip-down rear seats with quick-release levers conveniently located in the cargo area, three underfloor storage compartments and a lightweight, steel-reinforced composite rear cargo door with electromagnetic opener switch and automatic back door closure assist system.
A number of special high tech features are also available in the Technology Package, including an advanced DVD-based Infiniti Navigation System, Intelligent Key with keyless entry and engine start system and RearView Monitor. The RearView Monitor projects a view of what's behind the FX45 onto the navigation system monitor using a small camera mounted near the rear license plate (the system operates only when reverse gear is selected). Also available is Infiniti's Intelligent Cruise Control System, which uses the brakes, throttle and laser sensors, to maintain a set distance between the FX45 and a vehicle in front of it.
The Infiniti Mobile Entertainment System features a DVD player with 6.3-inch roof-mounted rear LCD screen. An AM/FM/cassette/6-CD audio system with six speakers is standard, while a 300-watt digital Bose“ premium audio system with 11 speakers is also available.
Other interior amenities include an Infiniti signature analog clock, driver and passenger one-touch up/down power windows (front and rear on V8 model) and door locks, to name just a few.
Four unique leather-appointed interior color combinations are offered: Graphite, Willow, Willow/Black two-tone and the signature Brick/Black two-tone. The Willow interior is also available in cloth.
High Level of Safety
From a safety standpoint, every FX45 model comes with standard dual-stage front supplemental air bags with seat belt sensors, front seat side-impact supplemental air bags and front and rear seat curtain side-impact supplemental air bags.
Also standard are seat belts with pretensioners and load limiters and the LATCH (Lower Anchors and Tethers for CHildren) child seat anchors and tether system.
The G35, the new FX45's SUV-enhanced Zone Body FM platform with front and rear crushable zone is designed to help protect occupants during crash impacts and vehicle body deformation in a collision by efficiently absorbing crash energy. In frontal collisions the crushable body construction is designed to help reduce the deceleration g-force of the cabin.
In a high-speed frontal collision, the crushable zone crumples while the engine drops under the floor. This effectively expands the crushable zone, reducing deceleration g-force and simultaneously helping minimize cabin deformation, especially in the leg area.
In offset impacts, the strong body construction is helps decrease the amount of cabin deformation. Other features also contributing to improved occupant safety, include the breakaway brake pedal and a breakaway construction of the propeller shaft (connected with the engine-drop function) and the double-wall construction of the bulkhead.
Models and Packages
The fully equipped FX45 is offered in three engine/drive configurations: the V8-powered AWD FX45, the V6-powered AWD FX35 and the V6-powered FX35 with optional rear-wheel drive.
In addition to the long list of equipment on the V6 FX35, the FX45 includes additional standard equipment, including sport suspension tuning, leather seating and trim, heated front seats, driver's seat memory system with two settings, 20-inch tires and unique aluminum-alloy wheels.
It also offers power tilt and telescope steering wheel, power driver's seat lumbar support, heated outside mirrors with memory system, auto up and down feature on all windows, aluminum pedals (accelerator, brake and footrest) and a unique V8 engine cover.
A number of optional packages are also available. The V6 Premium Package includes leather seating surfaces, heated front seats, driver's memory seat and power lumbar support, power tilt and telescopic steering wheel, heated outside mirrors, sunroof, 300-watt 11-speaker Bose audio system, HomeLink“ Universal Transceiver, auto on-off headlights, steering wheel audio controls and cargo net.
The V8 Premium Package includes sunroof, Bose audio system, HomeLink Universal Transceiver, auto on-off headlights, steering wheel audio controls and cargo net.
The Sport Package (available only on V6 models) includes all of the V6 Premium Package equipment plus 20-inch wheels and tires, the sport-tuned suspension and aluminum pedals.
For buyers looking for the ultimate in advanced equipment, the Technology Package adds (in addition to all Premium and Sport Package features) the Infiniti Navigation System, Intelligent Cruise Control, Mobile Entertainment System (DVD-based), RearView Monitor System, Tire Pressure Monitor System and Intelligent Key.
The Intelligent Key is a new generation keyless system that eliminates the need to use the key fob when locking, unlocking and starting the engine. The key fob, which incorporates a circuit board, emergency key and transponder, can be carried in the driver’s pocket, briefcase or purse. To unlock or lock the door, the driver pushes a request switch on the door handle (driver’s, passenger’s or tailgate). The transponder checks the Intelligent Key unit for the correct identification and unlocks or locks the doors.
To start the engine, the driver pushes the ignition knob into the steering column. If the identification is correct, the knob can be turned to start the engine. The knob is rotated back to the ACC position to stop the engine. The engine can also be started conventionally by inserting the emergency key into the ignition slot.
The Intelligent Key has the same functions as current remote entry systems, including panic alarm and selective unlock mode and answer back.
"The FX45 epitomizes the new Infiniti, with dramatic styling, unmatched handling and performance, advanced technology features and the go-anywhere, do-anything utility of all-wheel drive and flexible cargo space," said McNabb. "There are a growing number of premium crossover SUVs on the marketplace today, but none that come close in any dimension to the FX45. It's the SUV that a sports car manufacturer should have built."
Old 01-12-2003, 11:02 PM
Happy CL-S Pilot
Nashua_Night_Hawk's Avatar
A kick ass truck from Nissan... I think this a class higer than MDX!!
Where are the performance numbers?
Old 01-12-2003, 11:07 PM
oonowindoo's Avatar
Received 4,273 Likes on 3,050 Posts
faster than X5 4.6???
i heard that shit is using M5's engine...
that FX45 would smoke M5's engine in its dream ONLY
Old 01-12-2003, 11:19 PM
Moderator Alumnus
gavriil's Avatar
The 4.6 is not using the M5's engine. The engine in the M5 is 4.9 liters large.
Old 01-12-2003, 11:21 PM
Gilgamesh's Avatar
It's not the M5's engine, the M5 has a 5.0 litre V8 good for 394 ponies. The 4.6 litre in the X5 has less power.
Also, power is not everything, gearing, and weight,as evidenced by our shitty 4th and 5th in the autos.
Old 01-12-2003, 11:22 PM
Moderator Alumnus
gavriil's Avatar
Dont have the exact numbers yet.
Old 01-12-2003, 11:24 PM
Gilgamesh's Avatar
Damnit, I got beaten to the punch!!! :p
Old 01-12-2003, 11:37 PM
Go Cowboys.. woo hoo :)
gholdin's Avatar
6.3 secs 0-60mph
1/4 mile around 15 secs at 93 mph
.87G!!! on the skipad
will stop from 70 in 160ft !!
sheesh... not bad for a 4500 lbs SUV...
Old 01-12-2003, 11:42 PM
AcuraFan's Avatar
I don't care how fast it is...I still think it's ugly. Heck, the Murano looks better than that. However, I'd still take an MDX over either of them any day.
Old 01-12-2003, 11:50 PM
allmotor_2000's Avatar
I sat in it today... looks pretty nice actually - low roofline though!
Old 01-12-2003, 11:55 PM
Crazy Bimmer's Avatar
woohoo... my brother was looking for a new SUV... im soo gonna sell him this thing!!
Old 01-13-2003, 12:02 AM
sswany's Avatar
Just went to the LA Auto Show today and saw one in person. Very cool looking. I love the interior. And they're impressively fast.
Old 01-13-2003, 12:10 AM
Moderator Alumnus
Beltfed's Avatar
Have fun in the MDX, now that's an entertaining ride......seriously, the MDX has soccer mom written all over it (sorry MDX fans/owners).
Also the exposed underbody from the rear looks like total shit on the MDX.
Thanks....I'll take this
Best photo
[IMG] [/IMG]
Old 01-13-2003, 12:21 AM
AcuraFan's Avatar
Eh, it looks like the lovechild of a (I dunno...) RX300 and a station wagon...more wagon than SUV. Sorry, I don't see the appeal.
Old 01-13-2003, 12:34 AM
Moderator Alumnus
Beltfed's Avatar
On the road, nobody is going to confuse the FX with an RX300......that you can count on.
Old 01-13-2003, 12:46 AM
SilverBulletCLS_RENAMED's Avatar
In my opinion...
if Infiniti hadn't stretched out the headlights so much it wouldn't have look half bad.
Old 01-13-2003, 12:47 AM
KavexTrax's Avatar
why do i get the feeling that in the "best photo," Beltfed dreams of a minigun popping out of that heavily tinted FX 45.
Old 01-13-2003, 12:56 AM
Moderator Alumnus
Beltfed's Avatar
You're a mind reader, but actually.......I have dreams of a GE minigun popping out of any cool vehicle.
Also, the FX45 should "not" be shown in that brown exterior color in gavriil's first post......that color is disgusting.
Old 01-13-2003, 06:33 AM
Changin bulbs since '73
Loseit's Avatar
that thing is gor-geouso!!! although...i wish they had the big weheels from the concept!! i want 1.
Old 01-13-2003, 07:46 AM
hemants's Avatar
I'm looking forward to driving the FX45 but if it's anything like a truck, no thank you.
I'm hoping it'll have the feel of the Volvo V70R or Audi Allroad.
We shall see.
Old 01-13-2003, 09:24 AM
Member
goldn1's Avatar
anyone driven the v6 in the murano? although the v8 in the infiniti would be nice, currently looking at the nissan for the wife...
Old 01-13-2003, 10:53 AM
RandyMax's Avatar
The FX is faster than both the X5 4.6is and the ML 55 AMG, according to Car and Driver. The X5 and ML both runs 0-60 at 6.5 seconds. The FX does it in 6.3.
Old 01-13-2003, 10:56 AM
RandyMax's Avatar
I am interested in the Murano too. Get to "sit" in a couple at the auto show, but haven't driven it yet.
I've been reading about it at Edmund's townhall and www.nissanmurano.org. You can go and check out what Murano owners think.
Old 01-13-2003, 11:00 AM
RandyMax's Avatar
I saw the FX at the auto show, and I actually liked the brown color shown in the pictures. And the brick colored leather looked and felt great too.
Old 01-13-2003, 11:02 AM
Cost Drivers!!!!
Zapata's Avatar
did they test the new MDX??
Old 01-13-2003, 11:06 AM
Shift_3.5 Auto
ThoroDredCLS's Avatar
I drove one a week after I bought my QX4. It has a better ride than a suv and I tested the SE AWD with manual-matic mode. Very nice ride with tons of gadgets and toys. If i would have waited i probably would have bought one, but i was so mad that my tranny died that I couldn't wait. Anyway, I was surprised at the power the murano had. Actually faster than a 03 mdx or felt faster. I didn't go all out on acceleration because it was too new and I had a sales rep in the car. Car and driver have the murano in mid-low 7s 0-60. They are pretty expensive for a 5 seater, and the price my dealer was asking was more than my qx4 w/navi. All and all nice car/suv and if you want a stylish family hauler and not a clunky suv-minivan-soccer mom looking vehicle then I would consider the murano. I don't like the nissan name just as I don't like honda, and I would rather step up to their premium brands like Acura or Infiniti and I would opt for a FX35 or if you have the funds, FX45. Better service and customer relations. I am looking into a FX35 or 45 when they arrive and qx4 is going bye-bye!
Old 01-13-2003, 11:11 AM
RandyMax's Avatar
No, but even with 260 hp it won't break 7 seconds (I guess it would probably be 7.5 or something like that). The FX, X5, and ML are all V8s with more than 300 hp.
Old 01-13-2003, 11:16 AM
1SICKLEX's Avatar
Car and Driver tested about 10 SUVs last month.
10. GMC Envoy
9. Land Rover
8.
7. Aviator
6. Volvo
5.
4.
3. MDX
2. Lexus GX 470
1. VW Tourag
Basically, they still liked the MDX, it was the 2nd cheapest (though 41k is $$$) towing capacity was the lowest and the interior was deemed cheap. They liked it's handling and space.
Old 01-13-2003, 11:28 AM
CL Type-S Owner
CLS_power's Avatar
What about PORSCHE CAYENNE - Zero to 62 mph 5.6 sec
Old 01-13-2003, 11:32 AM
RandyMax's Avatar
Sure, if you got an extra 30 grand lying around...
Old 01-13-2003, 11:54 AM
Moderator Alumnus
gavriil's Avatar
Old 01-13-2003, 11:55 AM
Moderator Alumnus
gavriil's Avatar
Originally posted by gholdin
6.3 secs 0-60mph
Holy moly. The skidpada and breaking are amazing.
Old 01-13-2003, 01:18 PM
Cost Drivers!!!!
Zapata's Avatar
One down side, reviewer said it didn't ride like a luxury SUV. The sporty suspension helped the handling but the ride suffers.
Old 01-13-2003, 01:32 PM
1SICKLEX's Avatar
Well to Infiniti's credit, it seems to be making raves on some internet forums. Though a SUV/Wagon thingee with 20" wheels, equaling no off road capacity makes no sense to me.
540 wagon/RS-6 wagon anyone?
Old 01-13-2003, 04:41 PM
Moderator Alumnus
gavriil's Avatar
Zapata, the 4.6is is also suffering from the same problem. That's not a justification, just and FYI.
Old 01-13-2003, 04:48 PM
Rep the 305
BIG POPPA's Avatar
Who honestly takes a luxury SUV offroading, unless its a Land Rover or sumthing, which is disgusting looking.
Old 01-13-2003, 06:00 PM
F23A4's Avatar
Received 1,666 Likes on 930 Posts
Sure! Would you mind loaning me $55-$60G!
peti1212
ILX
22
01-05-2022 05:14 PM
02-25-2020 09:57 AM
tonio
02-05-2019 05:43 PM
Quick Reply: Infiniti FX45: Car and Driver says it's faster than the ML55 and BMW X5 4.6is
