How much does air weigh?
Stupid question....
Say you have a wheel thats 24lbs and a tire thats 26lbs, how much will that weigh once its mounted together with say 32psi of air?
GEEZER
I got Nitrogen in my tires.
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
Photography Nerd
I get a custom blend in my tires:
Nitrogen 78.084 %
Oxygen 20.9476 %
Argon 0.934 %
Carbon Dioxide 0.0314 %
Neon 0.001818 %
Methane 0.0002 %
Helium 0.000524 %
Krypton 0.000114 %
Hydrogen 0.00005 %
Xenon 0.0000087 %
Nitrogen 78.084 %
Oxygen 20.9476 %
Argon 0.934 %
Neon 0.001818 %
Methane 0.0002 %
Helium 0.000524 %
Krypton 0.000114 %
Hydrogen 0.00005 %
Xenon 0.0000087 %
Go Giants
![Explode](https://acurazine.com/forums/images/smilies/explode.gif)
My WAG ?? not much to really make a difference...
and temperature... and the molar mass of air... use the ideal gas law...
Wsteven would probably be able to help figure it out...
Google turns up this: http://www.madsci.org/posts/archives...5256.Ch.r.html
Originally Posted by Dan Martin
You'd need to know the inside volume of the tire to figure that out...
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
Main reason i ask is that i just sold my DPE wheels and they weighed 60lbs ![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
How can that be? Tire was 27lbs so no way my rim was close to 33lbs?
good thing my new wheels are only 18 lbs without tire
![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
Photography Nerd
Umm dude those things were huge ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
BTW, at 60 degrees F "air" weights about 7.636lbs per cubic foot.
Or something.
Math is hard!
Or something.
Math is hard!
Fahrvergnügen'd
I think you might have got your decimals mixed up... At sea level, its about 0.08 pounds per cubic foot.
Seriously, weighing air is an entirely theoretical exercise in futility if you ask me
good thing my new wheels are only 18 lbs without tire![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
DPE's are supposed to be light...i'm guessing they're around 23-25lbs for 19"
Registered but harmless
Received 1,107 Likes
Also, remember that those wheel balancing weights are made of LEAD, so they will add some weight (but I don't think it would be more than 5 lbs.)
I think you might have got your decimals mixed up... At sea level, it's about 0.08 pounds per cubic foot.
Jesal, PM Wstevens... he does this kinda shit for a living... and since he's part of the 335 club, I'm sure he'll help out
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Received 1,080 Likes
Main reason i ask is that i just sold my DPE wheels and they weighed 600lbs ![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
Were you standing on the scale?
AZ Community Team
Received 7,771 Likes
Originally Posted by 1killercls
I got Nitrogen in my tires. ![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
Cool. I've heard Nitrogen is the shizzle.
How much does Nitrogen weigh (in tires at 32psi)?
Photography Nerd
15 lbs of unsprung weight will make a big difference in handling.
Regions Leader
Regions Leader
I use it in mine simply because its available...
from http://en.wikipedia.org/wiki/Tire:
Aircraft tires are usually inflated with nitrogen gas in order to minimize the expansion and contraction due to the extreme changes in temperature experienced during flight. Dry nitrogen expands at the same rate as other dry atmospheric gases, but common compressed air sources may contain some moisture, which would increase the expansion rate with temperature. Aircraft tires generally operate at high pressures, up to 200 psi (13.8 bar) for airliners and higher for business jets.
Aircraft tires also include heat fuses, which melt when a certain temperature is reached. Tires often overheat if maximum braking is applied during a rejected takeoff or an emergency landing. The fuses provide a safer failure mode, since the tire will no longer explode when overheated, but deflate in a controlled way, thus minimizing damage to aircraft or injury to people on the ground.
The main purpose of requiring that an inert gas, such as nitrogen, be used instead of air, for inflation of tires on certain transport category airplanes is prompted by at least three cases in which the oxygen in air-filled tires combined with volatile gases given off by a severely overheated tire and exploded upon reaching autoignition temperature. The use of an inert gas for tire inflation will eliminate the possibility of a tire explosion. Federal Aviation Administration 14 CFR Part 25 [Docket No. 26147; Notice No. 90-7] RIN 2120-AD37 Use of Nitrogen or Other Inert Gas for Tire Inflation in Lieu of Air
PS: VERY funny album
![](http://cover6.cduniverse.com/MuzeAudioArt/Large/16/275716.jpg)
Where do you guys get nitrogen fills at? Or is there some sort of machine and tank I can buy and do it myself?
what's your screen name again????
Biggie_B
02-26-2017 11:14 AM
rcs86
08-02-2016 06:52 PM
