Hardest Cars to Work On
For those who work on cars for a living, what was the hardest car you've worked on?
Hopefully, this isn't a rehash of an old topic but I had my SAAB serviced. It is a 2004 SAAB 9-5 AERO.
I had an alternator exchanged. The technician said it was very difficult. They had to cut the exhaust to dismount the engine and lower it to get at the alternator.
What everyone's opinion is on the hardest make/model of car to work on. Was it a bad design?
Conversely, what's the easiest car to work on? Certain brand/model of car?
1980 BMW 320
I've never hated working on a car as much as that piece of shit. It belonged to my best friend and it was very difficult and temperamental.
AZ Community Team
^ my brother had a 1980 320i E21, I worked on a few times. Fairly straightforward BMW, easy compared to his 1988 M6.
Worst car for me to work on? Porsche 928, easy extremely cramped engine bay. Electrical nightmare, belonged to a friend of mine. He's a gluten for punishment, he's owned two 928's.
Hardest I've worked on - MR2 Turbo. I'm not a mechanic, but tinker here and there.
Anything made by VW.
Even changing the air filter on a 1.8T motor required the removal of half the engine. (half sarcasm, half true)
Someday, an RS6 Avant+
Getting at the spark plugs in my Subaru is a pain in the @$$. Boxer motors make it impossible unless you raise the car, remove the front wheels, AND have a good angle joint on your socket wrench.
Whats up with RDX owners?
Worst:
Best:
Best:
Aman (10-22-2014)
Chapter Leader
(Northeast Florida)
(Northeast Florida)
I think you mean glutton.
AZ Community Team
Fawkatitle.com
Audi S4's that damn v6t or the v8 version of them are crammed!
My 2012 Maxima, to change rear spark plugs I have to remove complete intake system and manifold off. A/C and alternator removal requires the radiator/fans to come out.
The STIs aren't that easy either to work on since its a boxer engine.
What's also fucking dumb is some '90s VWs required a manifold removal too... but on a 4-cylinder. Or at least it was in the way. Nice job turning 5-minute job into an hour+
1. remove upper strut brace
2. remove actuator bracket
3. remove and install plugs while laying on engine
Subaru
support front of car on jack stands
remove splash shield from bottom of front
start on either side and reach up and remove and install plugs one at a time
I never had to remove the strut brace on my CL, and I had the factory braces and the Neuspeed brace. I did have to remove the imrc motor and bracket though.
As far as Subaru goes, that depends on the Subaru. Some require you to lift the engine slightly.
much easer if you do imho, and it only takes a few moments
civicdrivr (10-17-2014)
Under hood, not very different at all. The biggest difference is the base CL/TL don't have the IMRC system, so you don't have the actuator mounted to the rear valve cover.
Haven't worked on as many cars as you guys have but I remember trying to change the battery on this thing after I dropped the SC on top of it.
Not Registered
Land Rover Discovery
Coils are behind the engine on top of transmission against the fire wall. Have to take the whole top of the engine off to change plugs. Everything about them sucked to work on.... and everything anyone's every heard about them is true! I had to change coils and plugs 3 times in 2 years at $800 a pop!
If you installed the S/C, why didn't you just do a battery relocation? I know you saw that becoming an issue...
As far as difficult cars to work on, The Ford Ranger V6 is not so simple. It may not be the most difficult in every aspect, but things that should be straight forward are awkward - like changing the spark plugs. The engineers of that Ford should be shot.
I never said it wouldn't work, I said it would be easier without the bar in the way and it is cause you do not have work around it.
iWhine S/C 6MT TL
I had to replace my battery as well with the blower in the way. I removed the intake silicone elbow and the 4x bolts that hold the super charger elbow to unit. Start to finish was about 20 mins.
Your Friendly Canadian
Received 1,491 Likes
Yep... and the Passat W8. VW seems to like fitting huge engines into small bays. Even my 1.8T Passat has a bunch of plastic that makes doing anything a PITA.
Heck, I have to remove the coolant overflow tank just to get at the oil filter.
I wonder what working on a Cayman is like, considering that car doesn't technically have a hood. Do you have to do everything from underneath the car?
And this is what you see when you open the hood of the 991 911:
