Fuel problems? Please help.
Old May 7, 2010 | 02:00 PM
jemarshall64's Avatar
6th Gear
I have a 91 Acura Integra. I am having a problem that I believe has to do with the fuel. Occasionally it will just die, usually just when idling, but has now started doing it while driving. It just idles down like it has run out of fuel, after a little while it will fire right back up, like nothing is wrong. I had another vehicle do this to me and it turned out to be the fuel pump, so I changed it out about 2 weeks ago. After changing it didn’t die on me for awhile, but has started dyeing again, and getting more frequent. I was thinking maybe it would be the fuel pump relay, but have read somewhere that the relay also controls the cranking/starting circuit, which it will crank overright after it dies, but will not start, so I am unsure if it is or not. Anyone else have any ideas that I could check before going any further? Thanks.
Old May 7, 2010 | 02:02 PM
Sly Raskal's Avatar
Loose spark plug wires?
Old May 7, 2010 | 03:17 PM
dallison's Avatar
registered pw
What rpm does it idle at?
Old May 7, 2010 | 04:41 PM
6th Gear
It idles between 6 to 700 rpms.
Plugwires are good, just did a tune up last week before driving from norther oregon to southern california, and this was a problem before the tune up, and is still ongoing.
Old May 7, 2010 | 04:52 PM
Sly Raskal's Avatar
idling at 600? isn't that kinda low?
Old May 7, 2010 | 04:56 PM
fsttyms1's Avatar
could be a faulty TPS, not sure, but does the integra have an external fuel filter?
Old May 7, 2010 | 05:07 PM
6th Gear
6 to 700 is where it is supposed to be for a manual transmission. Yes it has an external filter. Changed it when I did the tune up.
Old May 7, 2010 | 05:08 PM
6th Gear
not reciving any check engine lights or codes from the car.
Old May 7, 2010 | 07:15 PM
teranfon's Avatar
Moderator Alumnus
From what you're describing, it may be the Mass Air sensor. Do you know where it's located on the car?
Terry
Old May 7, 2010 | 07:24 PM
dallison's Avatar
registered pw
do you think there is something in the fuel tank? you said the issue went away and then came back. Also, have you changed the fuel filter lately?
Old May 7, 2010 | 07:29 PM
Sly Raskal's Avatar
Really? all of my cars have idled at 700-750.
Old May 7, 2010 | 08:30 PM
6th Gear
yes, changed fuel filter last week, also had the tank out 2 weeks ago to change the fuel pump, was perfictly clean inside. Will look into the Mass air sensor, yes I know where and what it is, really knowledgeable about cars, just current location has me low on tools and available time/space to work on it. Thank you all for the time and info so far.
Old May 7, 2010 | 09:22 PM
teranfon's Avatar
Moderator Alumnus
OK. See if you can get the car to run. If you can, tap the mass air sensor with a screwdriver handle or something similar and see if the car dies.
Terry
Old May 7, 2010 | 10:19 PM
6th Gear
ok, car runs fine, this is an intermittant problem, when it shuts down, it will start back up again, sometime within a min or two, somtimes about 10 min. Looked at the car and it does not have an air flow sensor, it's older than that.
Old May 7, 2010 | 10:59 PM
teranfon's Avatar
Moderator Alumnus
Doesn't have one? I thought it would. I still think is sounds sensor related. Are you sure that it's a '91? Hopefully someone with more experience with that particular car can chime in.
Terry
Old May 8, 2010 | 05:27 AM
dallison's Avatar
registered pw
Terry
esp since it is warmed up and shuts off.
My old 87 escort gt had an ignition control module that went bad. It would only shut off when warm and once it cooled down i could restart it.
Old May 8, 2010 | 06:10 AM
fsttyms1's Avatar
i have seen plenty TPS sensors failing that dont throw codes. I dont know what the values are supposed to be for the teg but see if you can find then and test with a ohm meter.
Also like terry said, check the MAP sensor (its what hondas use instead of MAF's)
Old May 9, 2010 | 08:07 PM
Gs Dewd's Avatar
406 with 2 kits
The fuel pump will be a seperate relay. It could be faulty. Relays only control 1 circuit( the reason why they exist in in the first place). Also could be a bad wire or loose connection. Does sound more like a fuel issue due to it petering out instead of shutting off quickly.
Old May 9, 2010 | 09:38 PM
phee's Avatar
I got the Shifts
sounds like a main relay. its common on the accords
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
gator90065
Oct 8, 2015 10:14 AM
Gary Matthews
2G CL Problems & Fixes
Sep 11, 2015 01:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
