Fuel Injector Cleaner???
Old Mar 22, 2007 | 08:12 PM
gdubb's Avatar
Mazda3 and Honda Civic in
Got a buddy that has an 05 WRX with around 20k miles and has only used good gas stations, he also uses a octane booster quite a bit as well. The car is not reaching full boost and seems to be sputtering quite a bit as well. He is thinking the injectors might be a little clogged, do those OTC injector cleaners actually work?
Old Mar 22, 2007 | 10:16 PM
sbuswell's Avatar
I need 2 more gears
gumout regane is the only OTC product I've had success with. BG44K is great also, but expensive and you have to order it online.
Old Mar 22, 2007 | 10:32 PM
gdubb's Avatar
thanks for the response
Old Mar 23, 2007 | 09:39 AM
TSXey's Avatar
Nick
Hard to say from your brief description of the symptoms, but I would check the plugs for misfiring. Pull out the plugs, examine for deposits and visual indicators, I would just install a new set unless they're already quite new ...maybe gap them down a tad lower, I don't know how Subies are, in many turbo cars a tighter gap & colder range plug by one step works much better than stock plugs at elevated boost.
I've used BG44K and it's excellent ...so much so that I never even tried anything else, but I have heard of a couple other good ones too. I'm sticking with the proven product. A local Nissan dealer here stocks BG44K in the parts department so you might find it locally if you call/look around.
Old Mar 24, 2007 | 07:43 AM
NHKSpec's Avatar
7th Gear
Thumbs up
B&G44K, I've used it for over 20+ years and it's great for the same problem that your friend's having.
Old Mar 24, 2007 | 09:18 AM
sbuswell's Avatar
I need 2 more gears
Gumout regane is the best OTC product IMO, BG44K is great as I originally stated. You will notice a nice difference in engine smoothness, acceleration and even sound after using it. You engine will pur like a kitten. Regane has very similiar effects and is much cheaper. I have tried them all and I always go back to 1 of these 2.
Old Mar 24, 2007 | 02:31 PM
gdubb's Avatar
THanks guys! How much is that BGK44?
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
