F430 Pics......
Old Jun 9, 2005 | 09:29 AM
  #41
bigman's Avatar
'Big Daddy Diggler'
Dare i say that i rather have this car then an enzo. I know the enzo is a better car and in a different league. But I think this car looks better.
Old Jun 9, 2005 | 11:53 AM
  #42
soccerman0000's Avatar
Hey, what is the knob on the steering wheel in the 5th pic, the red switch looking thing on the bottom right... any ideas?
Old Jun 9, 2005 | 11:59 AM
  #43
srika's Avatar
Moderator Alumnus
Originally Posted by moda_way
Um... there is a problem if you get into a ferrari and even have a thought of A/C.
It has a gas pedal, brake and steering wheel. Nothing else needed. Go fast with windows down... cool air.
umm... I said no hate - it was just a casual observation from the pics. Trust me if I was sitting inside the car, the design of the A/C controls would be the absolute LAST thing on my mind... you're preaching to the choir.
srika
Old Jun 9, 2005 | 12:03 PM
  #44
GIBSON6594's Avatar
My Garage
Not crazy about the Enzo styling
  #45
phipark's Avatar
Not Asian
Weak
j/k
Old Jun 9, 2005 | 12:04 PM
  #46
N/M found the answer to my question, if anyone else was wondering the same thing, here ya go!
Its mood is programmable, along with the car's suspension settings and stability and traction controls, thanks to the manettino, a dial on the steering wheel meant to evoke the more complicated steering-wheel controls on Scuderia Ferrari's F1 racing cars. When the manettino is set to Race, the F430 whips off shifts with brutal speed and buttons down its suspension to the max. Other settings include Ice, Low Grip, Sport, and the hotshoe's favorite, Everything Shut Off, which makes entry to the sideways motoring club an option coming out of just about every corner. The rest of the time, traction control systems, working with Ferrari's race-derived electronic differential, work imperceptibly, but with feverish speed, to keep the car and the would-be hero behind the wheel squarely on the black stuff.
That's pretty sweet IMO
  #47
srika's Avatar
Moderator Alumnus
quote from:
http://car.kak.net/modules.php?op=mo...878596f365d931
Just like in Formula 1, the F430 driver can change the set-up of his car using the innovative selector set on the steering wheel. The manettino is a rotary switch that has been adopted directly from racing, where the driver's total commitment to driving requires maximum efficiency and speed in controlling the car's various functions. This switch quickly and simply controls the electronics governing suspension settings, the CST stability and traction control, E-Diff and the change speed of the F1 transmission, as well as the integration between each of these individual functions. The position of the manettino is an example of the rationalisation studies that went into the layout of all the controls inside the car.
The manettino enables car settings to be changed to suit the personal preferences of the driver, road surface conditions and available grip. The settings available to the driver have been concentrated in five different strategies. These, in ascending order according the level of performance (grip), are:
ICE: performance is significantly restricted (maximum intervention by the stability and traction control) for maximum stability - indispensable for driving in very slippery conditions (snow or ice). The car reacts smoothly to driving inputs. The automatic gear-changing mode is selected which prevents gear changes at high revs and reduces the possibility of the rear wheels locking up on downchanges, even on ice.
LOW GRIP: this position ensures stability both on dry and wet surfaces. It is therefore recommended for surfaces with poor grip (rain), gritty roads or particularly broken or undulating tarmac. In this configuration, unlike ICE, the driver can still use the F1 paddle shift. The adaptive suspension setting is optimised to provide a very comfortable ride without impeding the handling balance, and the stability and traction control remains in the ICE configuration.
SPORT: this is the standard setting that strikes the best balance between stability and performance. Ideal for the open road, this position provides an optimum compromise for maximum performance and safety. Compared to the previous settings, SPORT adopts a more sporting configuration for the adaptive suspension to maximise performance, handling and stability at high speeds. The CST also goes up a level, giving the driver greater freedom, without excessively reigning in the engine.
RACE: this setting must be used only on the race track. Gear changing is even faster to minimise gear shifting times. CST intervention is reduced to a minimum (the engine management only cuts the engine when absolutely necessary). The damping also goes up one level.
CST: activates or deactivates the stability and traction control. With the manettino set to off, the driver has full control over the car's reactions. The only driver aids that remain active are those that cannot be overridden such as ABS and EBD (electronic brake distribution). With the CST de-activated, the electronic differential has a specific calibration which permits the car's incredible levels of handling and roadholding when free of stability controls. Gear shift speeds and damper settings are the same as in RACE. Over and above the significant technological breakthrough that the manettino represents, the approach to the new F430 underlines the importance given to exploiting the potential of the vehicle while maintaining ease of use under all conditions without jeopardising safety and stability. This has led to a new way of conceiving the car, which is not only based on the use of new technical features (eg. electronic differential, stability and traction control, and adaptive damping) but also on the improvement of Ferrari's tried and tested technologies (F1 gearbox, advanced engine control) and the optimisation of their integration. The adoption of stability and traction control (CST) together with the electronic differential has made the car even more stable, easier and safer to drive without affecting its handling and the excellent feedback the chassis gives the driver. The system ensures maximum safety in all driving conditions (from extreme track use to town driving) and on all road surfaces (rain or dry, or even ice). The CST intervenes in a smooth, unobtrusive way only as and when needed, without taking the driver's mind off what he or she is doing.
Old Jun 9, 2005 | 12:07 PM
  #48
joedokes28's Avatar
Originally Posted by Minch00
One day..........one day..........
Probably not...
Old Jun 9, 2005 | 08:56 PM
  #49
aaronnn's Avatar
yeah.. they are beautiful. i saw one at the local movie theater the other day and took pics.. if youre wondering which theater its the Edgewater Multiplex on River Road. pretty close to the next Acurazine Jersey Meet.
this was before i was going to go watch star wars 3... which was sold out and ended up watching the Longest Yard. which wasnt too bad though,
Old Jun 9, 2005 | 11:06 PM
  #50
Lister00169's Avatar
Yes, he did that
I think I would have a heart attack if I took it to 200 mph+.
Old Jun 9, 2005 | 11:10 PM
  #51
savage's Avatar
Engineer
i saw a yellow one all wrapped up on a flatbed while my plane was taxi'ing at LAX... it must have just come off a cargo plane for italy... even with the wrapping and protecting crap on it the car looks hot...
Old Jun 9, 2005 | 11:22 PM
  #52
stangg172004's Avatar
_____ like a rabbit
I've seen two just parked blocks away from my house, red and yellow
this is my work of art, i call it "wall-o-drool"
Old Jun 9, 2005 | 11:37 PM
  #53
darrinb's Avatar
///M POWER
in miami in front of this bar we went to parken in front was a red f430 and a red enzo, looked sick right next to each other
Old Jun 10, 2005 | 05:29 AM
  #54
moda_way's Avatar
srika
Not hating.... just stating the obvious.
Old Jun 10, 2005 | 05:48 AM
  #55
Osamu's Avatar
ok, i got it figured out. i'm gonna start putting 10 bucks a day into a jar, and when i turn 75, i'll be able to afford one
NICE..........
Old Jun 10, 2005 | 08:40 AM
  #56
TLofNYC's Avatar
Registered Abuser
In miami you see ferrari's and lambo's like you see pick-up trucks in the mid-west.
Old Jun 10, 2005 | 12:14 PM
  #57
jandj2204's Avatar
MuayThai scrappa
Werd..Porcsh911's Lambo's ans Ferrari's are the majority..Ford windstars and haundai sonatas are the minority. Damn, I want to move down there.
Old Jun 10, 2005 | 12:19 PM
  #58
srika's Avatar
Moderator Alumnus
no I meant I was not hating on the F430 with my post... nobody could hate on this car.. it's impossible...
Old Jun 10, 2005 | 12:29 PM
  #59
kurt_bradley's Avatar
Originally Posted by 98CLChick
You think I'm worth that much?!
I don't know you in person, but people seem to think quite highly of you. You are rather attractive though.
Old Jun 10, 2005 | 12:31 PM
  #60
Crazy Bimmer's Avatar
please dont feed the animals.
Old Jun 10, 2005 | 12:48 PM
  #61
Huh? What do you mean?
Old Jun 10, 2005 | 05:33 PM
  #62
YuppieCL's Avatar
Moderator Alumnus
wtf is up w ur avatar anyway?
Old Jun 10, 2005 | 05:43 PM
  #63
jandj2204's Avatar
MuayThai scrappa
The F430 owns the 360
Old Jun 10, 2005 | 06:05 PM
  #64
mclarenf3387's Avatar
Meh, doesn't count, thats a manfacturer car.
THeres also a Yellow Gallardo running around EdgeWater.
Let me guess, thats the theater right next to the Promenade
Old Jun 11, 2005 | 11:42 AM
  #65
It's a vid cap that was made into an avatar. It is from the Top Gear episode where they compared the Ferrari 360 CS and the Porsche GT3RS.
If you understood the glory that is the 360 CS, you'd understand the significance of that little button and it's connection to his smile in the other picture.
Old Jun 11, 2005 | 12:05 PM
  #66
Not you.
He was talking to Jesal.
Old Jun 11, 2005 | 12:46 PM
  #67
dallison's Avatar
registered pw
If you didnt talk you would be.
zing
Old Jun 11, 2005 | 10:18 PM
  #68
aaronnn's Avatar
haha yeah, its the theater next to promenade. why doesnt a manufacturer car count? its still a ferrari.
yeah i saw the Yellow Gallardo filling up gas at exxon across from Target/Barnes&Nobles parking lot.. also saw it again at fort lee parked outside of Food Emporium on Lemoine Ave.
Also a black Lotus Elise is always parked on Main St. of fort lee every now and then.
Old Jun 11, 2005 | 10:38 PM
  #69
Not you.
Gotcha.
Jun 18, 2009 02:43 PM
F-C
Motorsports News
21
Jun 15, 2009 04:03 PM
dom
Aug 6, 2006 11:07 PM
srika
Mar 27, 2006 10:07 AM
