Exhaust Gurus please chime in
Old Jan 11, 2011 | 01:07 PM
Eoanou's Avatar
'10 Hyundai Genesis Coupe
I ordered an exhaust, which I thought was 2.5", in fact, it was advertised as 2.5", but it turns out it's only 60mm. It's a dual exhaust with an x-pipe.
The problem is I ordered a pipe that connects from the header, refered to hereinafter as "downpipe", to the test-pipe which is 2.5". So we have a 2.5" downpipe and testpipe which leads to a 2.36" or 60mm exhaust and this what happens when they line up.
No Flash
Flash
As you can see a bottleneck has developed. I don't believe this will bode well. It will, in my opinion, negate any of the increased flow made by the down-pipe and test-pipe as it will just bottle neck once it reaches the cat back exhaust. Moreover I think it'll cause turbulence in the exhaust creating a rasp when the throttle is blipped.
Am I wrong, I am by no means an exhaust expert, but I was really angry when my exhaust only measured out to 60mm. What do you guys think, will I be alright? Will the downpipe still increase power despite the bottle neck? If I had 2.5" would I see improved power?
Old Jan 11, 2011 | 01:18 PM
TheMirror's Avatar
Disinformation Terminator
Looks like a mismatch to me, have you communicated with the manufacturer yet?
Need better pics too, if possible.
Old Jan 11, 2011 | 01:56 PM
Eoanou's Avatar
The mismatch is because I lined up the test pipe with the x-pipe of the exahust, so you see the disparity in diameter between the 2.5" testpipe and the 60mm exhaust. The 2.5" test pipe is on top, and behind it is the x-pipe so you see how the x-pipe comes in a bit.
joflewbyu2
Oct 8, 2015 11:16 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
jmaxima03
Sep 27, 2015 10:22 AM
prbori
Sep 27, 2015 01:37 AM
ivan06106
Sep 26, 2015 04:38 PM
