:drool:
Old Sep 16, 2005 | 10:37 AM
FastAcura's Avatar
I
:drool:
Price: $--,---
Miles Per Gallon: --/-- mpg
Curb Weight: ---- lbs
Layout: Front-Engine/RWD
Transmission: 5-Speed Manu-Matic
Engine
Type: Twin-Turbo V12
Displacement: 6233 cc
Horsepower: 730 bhp @ 5100 rpm
Torque: 812 lb-ft @ 2100 rpm
Redline: ---- rpm
Performance
0-60 mph: 3.9 sec
0-100 mph: --.- sec
Quarter Mile: --.- sec @ --- mph
Skidpad: .--g
Top Speed: 217 mph (limited)
Braking, 60-0 mph: --- ft
Slalom Speed: --.- mph
Source: Brabus
The world's fastest four-door coupe comes from Brabus and celebrates its world premiere at the 2005 Frankfurt Motor Show IAA. This automobile, built in small-series production based on the Mercedes CLS model series, is powered by a 730-hp 6.3-liter twelve-cylinder twin-turbo engine, that was implanted with almost surgical precision into the engine bay of the four-door. The performance speaks for itself: 0 – 100 km/h in 4.0 seconds, 0 – 200 km/h in 10.5 seconds, 0 – 300 km/h in 29.5 seconds are just as outstanding as the electronically limited top speed of 350 km/h.
At the heart of this new high-performance automobile lies the V12 twin-turbo engine from the SL 600. Brabus fits the engine with a special crankshaft, increases the cylinder bore and installs forged pistons, resulting in a displacement increase to 6,233 ccm. Further modifications include the optimization of the mixture flow in the intake and outlet manifolds of both cylinder heads as well as the installation of sport camshafts.
In addition the Brabus powerplant engineers equip the engine with custom-developed larger turbochargers, more efficient intercoolers and a stainless-steel high-performance exhaust system with low back pressure metal catalysts and four tailpipes. Newly programmed engine electronics coordinate all new components perfectly and contribute not only to maximum power yield but also to meeting all current legal emission limits.
After the engine conversion, now also available for all Mercedes-Benz 600 und 65 models with twin-turbo V12, the Brabus S V12 S Biturbo engine becomes the most powerful TـV- tested engine from Germany: The engines puts out its maximum power of 730 hp / 537 kW at 5,100 rpm. Peak torque is 1,320 Nm, limited electronically to 1,100 Nm, available from a low 2,100 rpm.
Power is transferred to the rear wheels via a modified five-speed automatic transmission and the Brabus locking differential.
The Brabus Rocket engine and the entire drivetrain is operated with high-performance lubricants from technology partner Aral. Brabus Naturally it is essential that the unique performance the world's fastest four-door coupe is capable of can be safely controlled at all times. To do so Brabus has developed two special suspensions for the Rocket: The comfort version features air suspension with automatic ride leveling. The sport version comes with a height-adjustable coil-over suspension and gas-pressure shocks with six different settings for bound and rebound on front and rear axle.
Maximum size and state-of-the-art materials characterize the Brabus high-performance brake system of the Rocket. The front axle is fitted with vented ceramics discs in size 375 x 36 mm and 12-piston aluminum fixed calipers. The rear axle features steel discs in size 355 x 28 mm and 6-piston aluminum fixed calipers to round out the powerful and fade- resistant brake system.
The giant brakes and the enormous performance necessitate the use multi-piece Brabus Monoblock S light-alloy wheels with 19-inch diameter. The Brabus technology partners Pirelli and Yokohama provide the high-performance tires suitable for these highs speeds. The optimal tire/wheel combination for the Brabus Rocket are 8.5Jx19 wheels in front with 255/35 ZR 19 tires and 10Jx19 with 285/30 ZR 19 on the rear axle.
The Brabus designers custom-developed a front apron for the Rocket with large air inlets for optimal cooling of oil and water radiators. The shape of the front spoiler and of all other Brabus aerodynamic-enhancement parts was fine-tuned in the wind tunnel. Not only did Brabus succeed in reducing lift on the front axle, but also in optimizing aerodynamic drag.
The aerodynamic counterpart to the front spoiler in the rear is the Brabus rear spoiler lip which emphasizes the rounded design of the rear. But that's not all: In combination with the new front apron the spoiler lip reduces aerodynamic lift, thus further improving directional stability.
Integrated entrance lights are the dominant feature of the Brabus door sills and the Brabus rear apron. Pushing a button on the keyless-entry remote or pulling on a door handle activates five LED lights on each side and in the rear. They illuminate the ground behind and on either side of the vehicle to further improve user-friendliness.
The Brabus rear apron is the perfect backdrop for the four tailpipes of the Brabus high- performance exhaust system. Its integrated diffuser also contributes to the refined Brabus aerodynamics concept for the Rocket.
The interior of the Brabus Rocket also meets the highest expectations of the distinguishing customers of one of the world's most exclusive automobiles. Soft and breathable Brabus Mastik leather and Alcantara are part of the exclusive BRABUS ambiance as is the ergonomically shaped Brabus sport steering wheel and the speedometer with 360-km/h scale.
Old Sep 16, 2005 | 10:39 AM
BEETROOT's Avatar
Yeehaw
Old Sep 16, 2005 | 10:42 AM
danny25's Avatar
I'm down with the engine, but those wheel need a chrome lip or something. Too much black.
Old Sep 16, 2005 | 10:49 AM
RSA_Secure's Avatar
FIGHTING ILLINI
and with that much torque you are sure to sherd regular tires
Old Sep 16, 2005 | 10:58 AM
mattg's Avatar
sick and wrong
Old Sep 16, 2005 | 11:15 AM
G's Avatar
G
Bitten.
1100 NM of torque
Old Sep 16, 2005 | 11:31 AM
FastAcura's Avatar
I
Originally Posted by ATXCLS
1100 NM of torque
@ 2100 rpms
Old Sep 16, 2005 | 11:34 AM
srika's Avatar
Moderator Alumnus
more pix here
https://acurazine.com/forums/showthr...=155874&page=2
Old Sep 16, 2005 | 12:09 PM
jz-97-c7's Avatar
givin the business
so who exactly do i need to kill to get my hands on one??
Old Sep 16, 2005 | 01:09 PM
bigman's Avatar
'Big Daddy Diggler'
M Power who?
Old Sep 16, 2005 | 01:16 PM
dallison's Avatar
registered pw
a hot car even hotter
Old Sep 16, 2005 | 02:54 PM
Deity711's Avatar
Yes it is!
The black grill makes it look like there's no grill at all.
Old Sep 16, 2005 | 02:57 PM
srika's Avatar
Moderator Alumnus
this isn't a car anymore... it's a gawdamn locomotive...
Old Sep 16, 2005 | 02:58 PM
srika's Avatar
Moderator Alumnus
that's race-spec, yo.
Old Sep 16, 2005 | 03:21 PM
phipark's Avatar
Not Asian
Old Sep 16, 2005 | 03:24 PM
boku's Avatar
Scru U guyz, Im Goin Home
"The world's fastest four-door coupe"???
Old Sep 16, 2005 | 11:31 PM
babyblue's Avatar
Sold but not Forgotten...
Perfomance is right at par with the super cars eh....
730 hp / 812 Trq
Top Speed: 217 mph - Absolutely amazing..
Old Sep 17, 2005 | 06:23 AM
1killercls's Avatar
GEEZER
I would give up a testicle for that car.
Old Sep 17, 2005 | 08:02 AM
EmuMessenger's Avatar
Finally, a real Brabus around here.
Not enough HP and tourque for me, though.
Old Sep 17, 2005 | 08:07 AM
dark inspire's Avatar
El Presidente
oh man Brabus > *benz tuner
Old Sep 17, 2005 | 08:12 AM
CGTSX2004's Avatar
damn...
Old Sep 17, 2005 | 06:57 PM
ediddy's Avatar
ediddy
I'll take two wait let me reach in my sock and get the money out
Old Sep 17, 2005 | 09:10 PM
Bareback's Avatar
TL = Tranny Lubrication
That's just sweet.
Old Sep 17, 2005 | 09:55 PM
S A CHO's Avatar
That was uncalled for...
Drool x2!
Old Sep 18, 2005 | 08:58 AM
Meeyatch1's Avatar
That car is beyond badass!!
Old Sep 18, 2005 | 10:46 AM
Chopsie's Avatar
Beware of leakage
Fucking hawtness.
Old Sep 18, 2005 | 11:04 AM
TSX 'R' US's Avatar
Old fart
... just
Old Sep 18, 2005 | 11:26 PM
sleeper's Avatar
superior performance and a sweet interior. not crazy about the exterior, though; i think it's downright ugly. back end seems squished. headlights are nasty. bumper looks too busy. looks just don't do it for me.
i'd still give my left nut to drive it just once.
Old Sep 18, 2005 | 11:42 PM
Shoofin's Avatar
Meh...That car only looks good from the side....From a straight front or rear shot, it looks like ass, IMHO
Old Sep 18, 2005 | 11:49 PM
FiftyFive's Avatar
Moderator Alumnus
fucking sex on wheels
Old Sep 19, 2005 | 01:03 AM
TranceFusion's Avatar
wow.. very nice!
Marc S
Apr 5, 2005 02:04 AM
stangg172004
Jan 30, 2005 01:08 PM
