Do you use the e-brake in your automatics?
#41
Originally Posted by S A CHO
You can do it any which way you like. I've always stopped in Neutral for a second to see if the brake is grabbing sufficiently, then just slide it into Park.
#43
Originally Posted by Trackruner228
I put it in Neutral set the E-brake let the car grab it then shift it to park.
Even in my manual cars.... and I always shift into gear first, then let go of the parking brake. Automatic or stick, the lever gets out of gear without much effort.
#45
'Big Daddy Diggler'
I always use the parking brake. What i do is stop while in drive, engage the parking brake, slip the tranny into neutral, let go of the regular brakes, the car will sit on the parking brake, i then slip the car into park. By doing that, the car never sits on the tranny. even sometimes when a parking brake is fully engaged, it will sit on the tranny especially for those with loose parking brakes.
#46
That was uncalled for...
Originally Posted by JJaber06
Always...i just hate the feeling of letting go of the brake and having all the weight jolt forward *shivers*
It wasn't the cars fault, only the operators...I tried telling her to use it but nothing sank into her head, hence she is now the ex-girlfriend
#49
I do it all the time, its the way I was taught. My wife doesn't, and it drives me nuts. I just cringe when she puts it in P then lets of the foot brake before engaging e-brake. No matter how many times I tell her, she forgets.
#52
I never shift into or out of Park unless the hand brake is applied, and only shift to Park from Neutral. Never directly from a drive gear. I'll come to a stop, shift to N, set the hand brake, release foot brake. When the car settles I shift to Park. You don't need to have your foot on the brake to do this.
I do the same even if I'm backing into a space, shift to N from Reverse then the same procedure as above.
When leaving - Start car, step on brake, shift into drive gear (D or R), release hand brake, release foot brake.
#53
Back in a TL again.
Someone told me MB or Bmw locks up all four brakes when you go in to park
And i always use the "parking brake" started out on a manual its programed habit for me.
#56
E92
#57
Back in a TL again.
Originally Posted by TommySalami
My dad's bmw jerks a bit when he puts it in park, so I'm guessing they don't have that, and his car is an '08
true i guess its here
#59
Originally Posted by AZuser
I always use the e-brake, incline or not.
Oh, and is there a difference in how it's done? That is, is it better to:
A) with car stopped and brake depressed, set e-brake and then put car into park
or
B) with car stopped and brake depressed, put car into park and then set e-brake.
I usually do B, but will once in a while do A if it's a very steep hill. Of course, I usually try to avoid hills to begin with.
or
C) with car stopped, brake depressed, put in nuetral, set e-brake and then put car into park.
#63
Here's a spin...Does it matter how hard you hold the brake pedal down? Or as long as it's pushed? I mean I use to push it all the way down to the floor, but I think it may be the same as just tapping it...
And when you put it into Park...Do you go fast? Or do you slowly go through the gears?
#64
Registered but harmless
Received 1,106 Likes
Mechanical systems also need to be adjusted-- otherwise, the parking brake won't work and the handbrake lever/pedal will feel loose. If the parking brake pedal goes all the way to the floor, or the lever goes all the way up, the parking brake and/or cable needs adjustment.
I shift quickly into Park after putting on the parking brakes.
#65
Received 2,329 Likes
Always, since day one.
I'm glad S A CHO brought up the parking prawl and included a photo...
I can't believe so many people DONT use the PARKING brake.
#67
Do you guys do this, even at short stops? (Ex: Gas station, waiting for someone, etc)
#70
s
BMWs don't lock the regular brakes but use an electic motor to operate an otherwise standard parking brake set-up. This set-up is only on E65/66(745 and 750I/LI) and E70(New X5)
I believe it was on the 745 and up and s500 and up I dont know just what i heard from someone...
Pham Alvan
03-16-2016 09:17 AM
guyvelella
09-30-2015 11:02 PM
Joe Avesyan
09-29-2015 03:57 PM
