The Definition of Acceleration.
'08 MX5 GT 6spd.
Pretty mind-blowing.
One top fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of stock cars at the Daytona 500.
It takes just 15/100ths of a second for all 6,000+ horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels.
Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture of nitro methane, the flame front temperature measures 7,050 deg F.
Nitro methane burns yellow... The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during a pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 deg F. The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph (well before half-track), the launch acceleration approaches 8G's.
Dragsters reach over 300 miles per hour before you have completed reading this sentence.
Top fuel engines turn approximately 540 revolutions from light to light! Including the burnout, the engine must only survive 900 revolutions under load.
The redline is actually quite high at 9,500 rpm.
Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second.
The current top fuel dragster elapsed time record is 4.428 seconds for the quarter mile ( 11/12/06, Tony Schumacher, at Pomona , CA ). The top speed record is 336.15 mph as measured over the last 66' of the run (05/25/05 Tony Schumacher, at Hebron , OH ).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter 'twin-turbo' powered Corvette Z06. Over a mile up the road, a top fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and pass the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment.
The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course.
...... and that my friend, is ACCELERATION!
<iframe width="420" height="315" src="http://www.youtube.com/embed/CGw6my-RDxQ" frameborder="0" allowfullscreen></iframe>
The following 5 users liked this post by MarbleGT:
justnspace (01-26-2012),
knight rider (01-26-2012),
On The Run (01-26-2012),
PortlandRL (01-27-2012),
ttribe (01-26-2012)
'08 MX5 GT 6spd.
If you have never seen Top Fuel in person...I suggest you do so. It might be a little "redneckish" but nothing...NOTHING can prepare you for how loud these things are.
Your eyeballs will jiggle in their sockets...literally. Your vision gets blurry when they pass.
Your Friendly Canadian
Received 1,485 Likes
Love the way the tires deform and the body twists under all that power
Would be awesome to work for a drag team like that one day.
"After halfway, the engine is dieseling from compression"
"Top fuel engines turn approximately 540 revolutions from light to light! Including the burnout"
I had to look the term "dieseling" up, but these facts just amazed me. Before today I thought F1 engines were the most complex racing engines in the world!!
Thanks for posting this, Marble, now I really want to see this in person!!
dV/dt or Force/Mass.
That's pretty cool shit. 44 Amps is a lot!
Evil Mazda Driver
Did anybody see Richard Hammond giving Renault's F1 car a go? I think he mentioned something in that saying that the engine in an F1 car is so tight that, when cold it's essentially a solid block of metal and it has to be started correctly to prevent self-destruction.
hANDYcaptd (01-27-2012)
IBankMouse
06-13-2020 12:53 PM
mlody
12-04-2019 02:11 PM
emailnatec
29
09-28-2018 04:27 PM
jterp7
3G MDX (2014-2020)
02-03-2016 08:34 PM
DerrickW
11-15-2015 05:52 PM
