civicdrivr's golfcart and Z8 - 5 thread
Old 12-14-2013, 10:43 AM
  #4121
Majofo's Avatar
Received 11,842 Likes on 8,573 Posts
Originally Posted by 03tLsNBP
Source: myself and two colleagues, 4+ years each in Mechanical Engineering field
23 years old - 5 years.. Are you claiming school as Mechanical Engineering field
Old 12-14-2013, 10:58 AM
  #4122
MechEng
03tLsNBP's Avatar
Well sort of. Any Mechanics of Solids or Machine Design textbook will explain what I said. Plus all the failure analysis I did for various projects in classes or internships, and my current job.
I know other fields are not like this, but MEs actually come out of school with some useful knowledge
Old 12-14-2013, 12:30 PM
  #4123
Yumcha's Avatar
Received 22,861 Likes on 14,005 Posts
Sorry to hear, Morgan.
At least you owe nothing out of your pocket...well, not really, there is the time involved. :bored
civicdrivr (12-17-2013)
Old 12-14-2013, 12:32 PM
  #4124
Oderint dum metuant.
chill_dog's Avatar
Now that all of that's out, looking forward to where you go next with the car.
Old 12-14-2013, 02:41 PM
  #4125
Undying Dreams's Avatar
Received 3,824 Likes on 2,847 Posts
Damn Morgan, keeping the car is new to me, glad you are though, and I'm happy you're happy driving it still.
Old 12-17-2013, 02:58 PM
  #4126
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,394 Likes on 4,939 Posts
did not expect that....so quickly.
Story of my life....
I'm sure this will lead to awesome new things for you and the car. I'm sure you haven't seen, but I ended up getting an S2000 as a weekend car. Watched some comparison vids on youtube between it and the FRS and thought of you.
Love,
J.
Congrats on the S!!!
Hopefully down the road you can try something difference, like a motor swap.
Thats actually one of the options. I have OCD though, so it has to be done right - ex: The electronic power steering must be retained (CAN system). AC must be retained (CAN system). Gauge cluster functionality must be retained (CAN system). There's a lot of stuff that I want to work that ties into the CAN system, which is a MAJOR headache to accomplish - but I believe it can be done and I'm pressing on one of the companies that I plan to go with for engine management to assist in the solution (they already have a full standalone for the FA20 that is CAN capable).
Originally Posted by swoosh
so when do we expect a rebuilt and boost?
That's another option. Might cost about the same as a swap when all is said and done as I'd be overbuilding the engine and fueling system.
Originally Posted by JS + MS3
Is this a known problem for this engine?
Seems to be a weak link.
^^^That's what I gathered. I wonder if there's any difference to the BRZ motor? More robust?
Same motor - FA20.
Originally Posted by Costco
Apparently the new Forester XT comes with a 2.0T, a turbocharged version of the FA20 in the GT86 twins. But if there are any differences between the N/A variant.
The FB20 and FA20 are about as similar as a C32A and a C32B (re: not at all).
Those connecting rods buckled under compression, not tension. The amount of tension on a connecting rod is nothing compared to the compression it sees. The elongation of the wrist pin hole is not a clear indicator of tension, because the same thing could happen under too much compression. There is also no "necking" on the rod, meaning the rod would have gotten thinner at the break point. It looks like it just sheared/buckled under compression.
My theory is that after the connecting rod buckled. The piston was free to shoot back out and hit the valves (you can see the imprints on the piston head). The piston was then was blasted back in towards the broken rod and crankshaft, shattering the connecting point for the rod on the bottom of the piston, and finally cracking the piston head outwards.
Simply put, you put too much boost through an engine that was clearly not designed for it. There's a reason people swap in forged internals before going forced induction.
Now this doesn't change what happened, but I wanted to bring this to your attention so you don't go around telling everyone you "stretched" a connecting rod. Good luck with the car. Hope everything works out in the end
I appreciate the response, and as I said, I am definitely not an engineer.
I do have a few quick notes:
-The rod sheared; it did not bend or buckle - I really wish I got a p
-The engine saw 9psi only only 9psi (data logged). The FA20 has been able to support a sustained 18psi without popping.
-This particular engine has shown issues on that same cylinder, prior to boost (I know, I know, why did I boost it then.....)
Ultimately, I really appreciate your engineering point of few on this. I wish I had the entire motor here so I could take it apart and photograph it bit by bit, but I don't have that option.
Originally Posted by fuzzy02CLS
We're good for something
It was a rough 1.5 weeks for me. My brother let me borrow his car the first two days, then the following week I'd have to drop him off at work at 730a (he had just started a new job when this happened), then I'd go into work 3 hours early, skip lunch, leave at 4pm to pick him up, drop him off at his house and then go back to work for a few more hours. It was rough, and he helped me out big time during that period.
Old 12-17-2013, 03:07 PM
  #4127
Yumcha's Avatar
^ Damn. Given the luck you've had lately, I think you are due...buy a lottery ticket? Maybe you'll be almost as rich as BoostedJack/Altegris soon!
Old 12-17-2013, 03:16 PM
  #4128
civicdrivr's Avatar
The jackpot is ~$600m....
Old 12-17-2013, 03:19 PM
  #4129
rockstar143's Avatar
Received 19,994 Likes on 14,502 Posts
586 Million...
I'd LITERALLY be happy with the amount you rounded that up. Forever.
and thanks, man. I'm very happy with it.
J.
Old 12-17-2013, 03:21 PM
  #4130
Majofo's Avatar
Some dumbshit like potroast is going to win it, buy a supra and die.
Old 12-17-2013, 03:22 PM
  #4131
Yumcha's Avatar
If you win $600M...can you buy me a Pagani Zonda?
Old 12-17-2013, 07:08 PM
  #4132
civicdrivr's Avatar
How about this - I will buy myself a Zonda and wear a twig costume when I drive it.
The following 2 users liked this post by civicdrivr:
Catfisha (12-18-2013), ttribe (12-17-2013)
Old 12-18-2013, 12:38 PM
  #4133
Jedi Apprentice
DoC-JoneS's Avatar
Long story bro. Sorry to hear about your boost related sadness.
civicdrivr (12-18-2013)
Old 12-18-2013, 01:36 PM
  #4134
Yumcha's Avatar
Meanie.
Old 12-26-2013, 05:15 PM
  #4135
I drive a Subata.
JS + XES's Avatar
Received 2,603 Likes on 1,571 Posts
Is there any particular reason why you went with that supercharger? I've been lurking on ft86 forum, there's like 20 brands that make pretty good turbocharger/supercharger kits for FRS/BRZ.
Crazy.
I'm interested in AVO turbo kit. It's like $3800. Seems pretty good for what it is.
Old 12-26-2013, 05:38 PM
  #4136
ttribe's Avatar
Received 5,934 Likes on 2,927 Posts
Crazy.
Just be ready for when the engine loses a rod.
The following 2 users liked this post by ttribe:
civicdrivr (12-27-2013), CLtotheTL32 (12-26-2013)
Old 12-26-2013, 05:45 PM
  #4137
Yumcha's Avatar
Well, if that happens for Kimchi here, there's DEFINITELY no resale value...
Old 12-26-2013, 05:47 PM
  #4138
I drive a Subata.
JS + XES's Avatar
I've been driving a modified Zoom Zoom Boom for the past 4 years.
Obviously, I'm ready.
Old 12-26-2013, 05:49 PM
  #4139
ttribe's Avatar
Won't matter. He'll kill the resale value with a ghetto tint job.
Yumcha (12-26-2013)
Old 12-26-2013, 05:50 PM
  #4140
Yumcha's Avatar
That's what happens when he paid $34.50 for the tint job.
Old 12-26-2013, 05:54 PM
  #4141
I drive a Subata.
JS + XES's Avatar
That's for sure. I need to get it tinted soon. Rims are coming off this Saturday morning.
Old 12-26-2013, 11:18 PM
  #4142
Coal
05TLdcc's Avatar
What about the lift?
The following 4 users liked this post by 05TLdcc:
civicdrivr (12-27-2013), crazyasiantl (12-27-2013), Slpr04UA6 (12-29-2013), ttribe (12-27-2013)
Old 12-27-2013, 09:52 AM
  #4143
civicdrivr's Avatar
Crazy.
Vortech makes a solid kit. They've been around for years as well. The new Kraftwerks Rotrex unit is nice though.
I didn't want to go turbo due to stress. The centrifugal supercharger slowly builds boost and rpms increase, while the AVO kit (which I honestly really liked) builds boost low and puts a lot of stress on the internals. There have been some talk here and there about the oil pump in this engine being variable rate depending on RPM; which, if true, could be problematic when additional stress is introduced at lower rpms.
Then again, looking at the motor the wrong way could be problematic as well
There might be a few people in the Mojave that are interested in a Mazdaspeed 3 rally car.
05TLdcc (12-28-2013)
Old 01-01-2014, 10:43 PM
  #4144
civicdrivr's Avatar
So, I washed it for the first time since "The Incident". The taillight has had condensation in it since Thanksgiving and I was tired of dealing with the dealership for replacements. So I went a different direction.
I ordered the Tom's clear USDM tails back in November, they were sitting around waiting for me to get off my ass to install, which I finally did last Sunday.
Here they are in action compared to stock.
In order of appearance - brake light; turn signal and brake light; turn signal, brake light and running light; turn signal and running light; running light.
I also ordered these JDM 86 replica headlights in December, but after installing the taillights, I'm thinking about going with the BRZ headlights instead as they have a similar light tube look that the tails do.
Thoughts?
The following 4 users liked this post by civicdrivr:
00TL-P3.2 (01-02-2014), Catfisha (01-02-2014), rockstar143 (01-02-2014), shrykhar (01-02-2014)
Old 01-01-2014, 10:56 PM
  #4145
MEKO's Avatar
Received 2,321 Likes on 1,600 Posts
Wow came out better than I've expected.
I love it, especially the running light.
Yup would match perfectly with BRZ headlights
civicdrivr (01-02-2014)
Old 01-01-2014, 11:22 PM
  #4146
CLtotheTL32's Avatar
Received 9,507 Likes on 6,176 Posts
Holy shit those tails are hawt
Old 01-01-2014, 11:44 PM
  #4147
Majofo's Avatar
tails are the tits..
Old 01-02-2014, 12:17 AM
  #4148
Yumcha's Avatar
Very nice.
Old 01-02-2014, 12:28 AM
  #4149
I drive a Subata.
JS + XES's Avatar
Woah! I thought those tailights are solid red outside!?
That looks really good on your color! I'm going to get a solid red one for mine. Quoted 450 shipped from one of the vendors at ft86.
Looks awesome!
Old 01-02-2014, 12:29 AM
  #4150
Your Friendly Canadian
Aman's Avatar
Received 1,485 Likes on 1,049 Posts
Love the tails. If I were you I'd throw in LED license plate bulbs, just to complete the rear end lighting.
Is there a significant performance/output difference between the replica 86 and the BRZ headlights?
Old 01-02-2014, 08:03 AM
  #4151
CCColtsicehockey's Avatar
Received 3,792 Likes on 2,556 Posts
Love the taillights. Glad to see you back moding the car again. Come down to NC for a trip.
Old 01-02-2014, 08:30 AM
  #4152
civicdrivr's Avatar
Looks awesome!
Thanks! They have the clear lens and the red lens. Both look great. I got mine from FTEightsix (one of the vendors); I highly recommend them.
The video was very dark, so the brightness of the license plate bulbs wasn't accurate, but I do want to swap them for LEDs.
Performance wise, the BRZ headlights are better. For one, they are HID from the factory and use the same bixenon projectors that are used in the RX350; which, after a lens swap, are an amazing projector (I have a pair that were going into the CL). The replicas are halogen and made to be plug and play with the FR-S - so my plan was to swap the RX350 bixenons into them. And since they aren't exact replicas (the housing is all chrome vs certain areas being black), my plan was to paint them while they were open.
But, take a look at the light tube in the BRZ headlights. It's a perfect match to the Tom's tails, so I'm going to sell the replicas and source a set of BRZ lights. Unfortunately, it won't be an immediate thing as the BRZ lights are still expensive
I'm hoping to make the drive down Saturday morning, as long as I'm no longer sick...
Old 01-02-2014, 08:35 AM
  #4153
chill_dog's Avatar
Tails look great!
Old 01-02-2014, 10:56 AM
  #4154
2024 Honda Civic Type R
RPhilMan1's Avatar
Received 1,475 Likes on 932 Posts
I really like the lights. Nice upgrade!
Old 01-02-2014, 11:57 AM
  #4155
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
Morgi, I love them lights....
I local guy has the same lights and I was hoping you would go that route but I didnt know if that was the ricer in me talking and I guess it wasnt
Looks SICK brothaa
Old 01-02-2014, 01:46 PM
  #4156
Turd Polisher
TylerT's Avatar
Received 3,017 Likes on 1,515 Posts
Wow, what a difference those tails made - nice choice.
What's next?
Old 01-02-2014, 02:40 PM
  #4157
civicdrivr's Avatar
Looks SICK brothaa
They probably are ricey, but I'm embracing my inner ricer.
What's next?
I've got another mod that I need to stop being lazy and install....
Old 01-02-2014, 02:44 PM
  #4158
ttribe's Avatar
Will it, also, result in the destruction of the engine? If so, I encourage you to do it sooner, rather than later.
civicdrivr (01-02-2014), CLtotheTL32 (01-02-2014)
Old 01-02-2014, 02:53 PM
  #4159
Looks great, Morgan. Solid choice.
Now that you're not going to need the 2 oem fishtanks, you think about cutting them open or having Bruce cut them open to see about oem tail modding potential?
Old 01-02-2014, 03:11 PM
  #4160
civicdrivr's Avatar
I've thought about it. But I need to come up with a solid design plan before proceeding.
Quick Reply: civicdrivr's golfcart and Z8 - 5 thread
