C/D investigation into the NISMO 370Z crash
http://www.caranddriver.com/features...ng_lap-feature
Very interesting read. the 335I reference validates the car and bimmer nick Seriously its a big safety issue, and a WARNING to 370Z owners who plan on tracking their cars:
1. custom fab brake cooling ducts
1. change your stock performance brake pads
2. Upgrade your fluid.
Serious R&D engineering goof up in Japan.
do they hit the tracks?
you have to admit that nissan did some ghey job on this one. Did you read the article at all?
come on now..
They matter-of-factly reported that the Z’s stock brake pads were designed primarily for low noise and low dust, and not for racetrack situations. It’s our view, however—and we don’t think we’re alone—that the NISMO Z, an even sportier version of a sports car, should be equipped with brakes competent enough to survive a few hot laps. And it’s worth noting that we’ve never experienced such hellacious brake degradation in the history of our Lightning Lap events.
Dude, there are countless guys on 370Z.com that track their cars daily, not to mention the hundreds of other car mags that tested this car on track and ONLY C/D ever had this happen. Doesn't that seem weird to you?
No, it doesn't seem weird to me.
Why does it seem weird to you anyway? You think C/D did this on purpose?
Nissan gave them NISMO 370Z to do the LLap, and this happend.
What's so weird about it?
Well, I just think its ridiculous to make a blanket claim that all 370Z's have sub-standard brake pads because there was one particular incident with one particular car. I also think that had there been any kind of driver error incolved, it might be convenient for C/D to do a little "blame the car" routine, especially considering that this appears to be far from a common occurence....
^ I still don't know why you are trying to defend Nissan on this one because clearly it was Nissan's fault of not getting the right brake system on the high end trim of its sports car.
If you had just said that NISMO 370Z was probably a lemon, then I would have perfectly understood that. However, you seem like you are just trying to defend Nissan no matter what. I wonder why.
C&D stated themselves that a better fluid would not prevent brake fade this severe, nor would upgraded pads.
The car needs slotted or drilled rotors and then it would preform better. Or even cooling ducts.
I'm interested in meeting all of those people that are said to be "tracking" their car daily. Is that their job or....? :P
Nissan's only strong point last decade was their sportscars/supercars, the Z and GT-R. The rest of their lineup is a bunch of ho-hum save maybe the Maxima.
And if there are quality issues with the two cars they got right....I've just really begun to lose faith in the Japanese brands.
Actually a TON of people have had issues with the newer style brakes. They are having issues with soft rotors, to early failure on the track. Reason why many are replacing the rotors and pads very early in life.
I loved my Brembos on my NISMO 350Z, never failed the few times with the stock pads, but I upgraded them later to better pads, lines and fluid.
Brembo equipment usually has more tendency to not do stuff like this, reason why the 350z never had issues like this on the Brembo equipped cars.
Go ahead. You will see many upgrading their brakes due to rotors being too soft, and pads fading early. The car overheats easy, and has rear diff failures. The 370z has many issues that will cause it to fail on the track. I have been a Z enthusiast for a very long tine and owned Z's myself with my most recent 07 NISMO 350Z.
www.the370z.com
www.the370z.com
One quick search. Here is an example of autox doing it to the pads, and autox isn't near the torture a track does.
http://www.the370z.com/track-autocro...ds-auto-x.html
Well, obviously most people that track their cars usually do small things like upgrade the fluid and the lines. Some even switch to racing pads. My point is that C/D is trying to make the claim that the 370Z is somehow far inferior to every other road car out there. If this issue was as they say it is, why hasn't any other car jounalist brought this up?
Here is a post from an avid member of 370Z.com who tracks his car very often. Interesting what he had to say about the brakes his first time out in the car:
http://www.the370z.com/members-370z-...z-journal.html
As I said, if these failures were endemic to all Z-cars due to bad engineering by Nissan, wouldn't more people have been raising the issue all along? Wouldn't other car mags that have tested this car just as hard as C/D noticed this fatal design flaw?
The reason I am defending Nissan here is that my car has the exact same brakes and I have had no trouble whatsoever. The Akebonos are strong and relatively fade-free for a stock setup; certainly more than you will ever need on the street.
My First Trackday Review - 2/28/09
Well, I am home safe with the Z after a beautiful day at the track. I purposely left the car completely stock for this first track event so I could get a good feeling for how the car behaves. The only thing I did have to change was the brake fluid, for safety reasons. I used the one thing my mechanic had available. Super BLUE, which isn't bad actually. I will divide the review into different sections to make it easier to read. As a disclaimer here, all my "ratings" are comparing the Z to other track worthy cars I've driven or been in around the track. (GT-R, GT3, STi, 350Z, etc...so a wide range.) I have a feeling some of you will find it a bit harsh, but then again, it is stock and the competition is rough.
Engine:
The engine in this car is a little hard to describe. Its not bad and its not weak, but it is a little lazy and it lacks punch in the bottom end. It vibrates a LOT at higher RPMs and it just doesn't feel all that refined. The exhaust is too quiet as well. I have to say I was racing in Advanced and everyone there had very fast cars with racing compounds; so I felt very slow today. I just need more power and more responsiveness from the engine. Definitely had to use all those revs to keep it in the power band. The fact that I didn't want to rev past 6k didn't help me much either (break in? lol) I didn't want to put 100% of the engine today, I'd say I used about 90% of it. So what it needs is a lighter flywheel, intake, exhaust and a supercharger. The other biggie was of course...engine oil temperature... what a pain in the ***, I didnt get more than 10 minutes into any of my 25 minute sessions because of overheating. I just took it back in and let it cool down, after all its still breaking in right? One thing that I think helped was to turn the heat on full blast... that apparently circulates the coolant through another radiator. I think it may have helped a bit, but it only delayed the inevitable. Oil cooler is going to be a huge mod for the 09 version of the car, maybe they will fix this ridiculous issue for '10. On the positive side...the engine is well matched to the transmission and it makes some nice power when it gets into the powerband at higher RPM. If you somehow manage to forget the vibration, it is a smooth engine. It delivers the power predictably and smoothly.
Rating 6/10.
Brakes:
OK, this one is going to help the overall average. The brakes on this car are much much better than I expected. As I said, the only thing I changed was the brake fluid so the setup was completely stock. There was no fading at all in any of the sessions. I could actually brake pretty late and the pedal was solid. The rotors held up and the brake pads were very good for stock street pads. Good job Nissan on this part. I am only going to change the pads and the brake lines here.
Rating 9/10
Engine:
Rating 6/10.
Brakes:
Rating 9/10
For that matter, the stock brakes will fade easily in ONE SESSION if he was actually driving it. That is all I will say.
The testing described in THIS article has nothing to do with tracking the car.
We wanted to test the fortitude of these upgraded brake pads for ourselves, so we arranged a back-to-back test of the base pads—like the ones on our Lightning Lap NISMO Z—and the new pads. We used two Sport-package 370Zs (which have the same brake hardware as the NISMO Z). To provide as much context as possible, we employed the same severe methodology from our 11-vehicle braking showdown [“The Power to Stop,” August 2008]. That consisted of a continuous battery of stops from 100 mph until the performance of the brakes degraded significantly. These 100-mph braking events were broken down into five-stop cycles; we began each cycle with a moderate, 0.5-g stop (that’s about half of the Z’s ultimate braking capability) and measured brake-pedal force and travel for evidence of fade. Four panic stops followed each cycle’s first moderate stop, and we recorded the distance it took the car to come to a standstill. We executed stops every 20 seconds (including the time to accelerate back to 100 mph) and repeated the five-stop cycles until the brakes succumbed to fade. That’s when the brakes get so hot that it causes a reduction in the friction between the pads and the rotors, which leads to longer stopping distances and increased pedal travel, as well as requiring more pedal force.
http://www.caranddriver.com/features...eature/gallery
From the article
"Our suspicion is that Nissan got a bit greedy in its quest for today’s all-important fuel-economy numbers and boosted the Z’s aerodynamics a little too far by cutting back on the amount of air directed through the wheel wells to cool the brakes. Key takeaway: If you intend to track a Z, don’t use the base pads, upgrade the brake fluid, and be sure to install brake-cooling ducts."
The guy who crashed in the lightening lap is the one walking with the cane:
From the article
From the article
Which is why I said 'THIS' (most recent) article. They didn't take the car on another track day. They simply performed a series of panic stops yet got the same results.
Agreed. One article/report doesn't make all this factual, although a bit worrisome. But you also have a G37 which may possibly be more effective at cooling the brakes. Either way, this wouldn't stop me from lusting after a 370.
