C/D: 2011 Audi Q5 2.0T Quattro - Short Take Road Test
You'll Never Walk Alone
http://www.caranddriver.com/reviews/...take_road_test
Fairly interesting test result....
ENGINE TYPE: turbocharged and intercooled DOHC 16-valve inline-4, aluminum block and head, direct fuel injection
Displacement: 121 cu in, 1984 cc
Power (SAE net): 211 bhp @ 4300 rpm
Torque (SAE net): 258 lb-ft @ 1500 rpm
TRANSMISSION: 8-speed automatic with manumatic shifting
DIMENSIONS:
Wheelbase: 110.5 in Length: 182.2 in
Width: 74.0 in Height: 65.1 in
Curb weight: 4095 lb
C/D TEST RESULTS:
Zero to 60 mph: 7.0 sec
Zero to 100 mph: 20.0 sec
Zero to 120 mph: 35.5 sec
Street start, 5–60 mph: 7.7 sec
Standing ¼-mile: 15.5 sec @ 90 mph
Top speed (governor limited): 128 mph
Braking, 70–0 mph: 167 ft
Roadholding, 300-ft-dia skidpad: 0.85 g
FUEL ECONOMY:
EPA city/highway driving: 20/27 mpg
C/D observed: 19 mpg
Now check out the numbers for the Q5 3.2 V6:
Displacement: 195 cu in, 3197cc
Power (SAE net): 270 bhp @ 6500 rpm
Torque (SAE net): 243 lb-ft @ 3000 rpm
TRANSMISSION: 6-speed automatic with manumatic shifting
DIMENSIONS:
Curb weight: 4346 lb
C/D TEST RESULTS:
Zero to 60 mph: 6.5 sec
Zero to 100 mph: 17.5 sec
Street start, 5–60 mph: 7.1 sec
Standing ¼-mile: 15.1 sec @ 94 mph
Top speed (governor limited): 129 mph
FUEL ECONOMY:
EPA city/highway driving: 18/23 mpg
C/D observed: 21 mpg
What's up with that?
The 2.0T model has turbo, 2 more forward gears, a much newer engine, 250 less pounds, much smaller engine, and it still consumes more fuel than the V6 model with an old engine. Icing on the cake...the V6 is even faster......did I mention about the smoothness of the V6 and its lack-free characteristic?
DIMENSIONS:
C/D TEST RESULTS:
FUEL ECONOMY:
DIMENSIONS:
C/D TEST RESULTS:
FUEL ECONOMY:
I drive a Subata.
hmm...... not sure if i fully understand your position on this issue, but 3.2 is about $6k more expensive than 2.0T. so the 3.2 SHOULD be better than the 2.0T, right?
and what makes you think this 2.0 turbo engine from audi is not smooth? i drive my gf's 2010 a4 avant with the same engine almost everyday, and it's surprisingly very smooth. my car is 2010 mazdaspeed3, and it has the 2.0 turbo engine as well, but in terms of smoothness, audi>>>>>mazda.
For normal driving the V6 probably has to work less to achieve the same results. Id like to the V6 with the 8 speed to see its increases.
I was just surprised at the real world mpg. With all the hype on downsizing engines + turbo, I would imagine the 2.0T would get way better mpg than the V6, especially since both tests were done in a testing environment.
I didn't say the 2.0T engine is not smooth. I know that it's very smooth for a 4-banger. It's just that, if Audi can make a 4 cylinder that smooth, how smooth do you think its V6 would be?
Hmm..my understanding is that the I4 model is a base model. I just checked out Audi.ca and compared the V6 Premium model and I4 Premium model. The V6 one has some extra standard features. Perhaps that's why the V6 is 250lb heavier (extra V6 weight + features)?
mada51589
05-03-2022 08:54 PM
09-15-2015 06:44 PM
ostrich
09-11-2015 04:28 PM
