Bugatti Veyron showing in the U.S.
Old Oct 2, 2005 | 08:08 PM
Beltfed's Avatar
Moderator Alumnus
Wheels by OZ
Old Oct 2, 2005 | 08:12 PM
S A CHO's Avatar
That was uncalled for...
Awesome......cant stand the front grille though, I think it shouldnt extend so far down....Love the rest of the car in every way, even the interior....
Old Oct 2, 2005 | 08:33 PM
andrew_gordon's Avatar
beautiful shots, beautiful car
Old Oct 2, 2005 | 09:20 PM
mclarenf3387's Avatar
<-- unimpressed
Old Oct 2, 2005 | 09:52 PM
njzprettyboy's Avatar
look at the cars in the background...prospective owners i guess
Old Oct 2, 2005 | 10:12 PM
Beltfed's Avatar
Moderator Alumnus
Nope, just part of the VAG showing........you'll also notice the Azure concept in the 3rd photo down.
Old Oct 2, 2005 | 11:13 PM
JaredGMS's Avatar
Meat stick
Originally Posted by mclarenf3387
<-- unimpressed
I know it's a beautiful car, but i don't think it's any nicer than alot of production cars
Old Oct 3, 2005 | 02:01 AM
m&b6speed's Avatar
buy my car
i'm with maclaren
hideous looking car, nice pics though
Old Oct 3, 2005 | 09:26 AM
bigman's Avatar
'Big Daddy Diggler'
Love the car, its fucking awesome. But it took so long to make that the front end styling seems very dated.
Old Oct 3, 2005 | 09:40 AM
jiggaman's Avatar
I spend 2 much time here
i dont think the colors on that car do it any justice, baby blue and pearl white on a 1000hp car just doesn't seem to work well
Old Oct 3, 2005 | 09:54 AM
Sdog2012's Avatar
We dont love these hoes
man that car is just unreal... i read it gets 5mpg so you'll pretty much have to drive gas station to gas station and put up with all the people that will be gawking at you at said gas stations
Old Oct 3, 2005 | 10:13 AM
knight rider's Avatar
Rooting for Acura
if you can afford the car....
Old Oct 3, 2005 | 10:07 PM
does the concpet look like the last one? cuz it seems like the last gen azure
Old Oct 3, 2005 | 10:23 PM
It is the same. They just refreshed the front end by making the headlights two circles.
RSA_Secure's Avatar
FIGHTING ILLINI
it looks better in black and red
Old Oct 3, 2005 | 10:53 PM
stangg172004's Avatar
_____ like a rabbit
fucking ugliest thing ever made, i want one!!!!
Old Oct 3, 2005 | 10:56 PM
_____ like a rabbit
cant wait till top gear get a go at this...
Old Oct 4, 2005 | 08:53 AM
Deity711's Avatar
Yes it is!
I thought the concept looked kind of dumb, but for some reason, in these pics, I admit I kind of like it. I'm a fan of that color combination. Really elegant.
Some more nice metal parked around it, too.
Old Oct 18, 2005 | 01:00 PM
Yumcha's Avatar
Press release...
(from Bugatti Press Release) The trials of the fastest road sports car in the world have been successfully completed. One of the most ambitious projects in automobile history is entering its production phase. The first Bugatti Veyron 16.4 cars, built mainly by hand, are already being completed and will be delivered to customers this year.
The sports car, capable of more than 400 km/h, is driven by a 16-cylinder mid-engine, that at 710 mm long is no larger than a conventional V12 unit, and due to its lightweight construction weighs only about 400 kilos. Its compact dimensions are due to the unique arrangement of its cylinder banks in a W configuration. Two VR8 blocks, each with a fifteen degree bank angle, are joined in the crankcase
to form one engine. Both eight cylinders are set at an angle of ninety degrees to each other and are aspirated by a total of four exhaust gas turbochargers. The engine delivers 1001 HP at 6,000 r.p.m. and provides a maximum torque of 1250 Newtonmetres at between 2,200 and 5,500 r.p.m.
To apply the power of the 64-valve unit to achieve satisfactory driving dynamics both in everyday traffic and on the racetrack, the Bugatti development team of Dr. Franz-Joseph Paefgen and Dr. Wolfgang Schreiber has realized a propulsion unit that is without parallel in its complexity. If the extreme engine power is a master stroke of genius, its conversion for road use is an equally tough challenge.
As Dr. Schreiber says “For 1000 HP propulsion power, the system demands approximately 2000 HP to be additionally generated as heat energy during combustion. Half in each case is dissipated in the exhaust gas and cooling water”.
To do this, the Bugatti engine has two water circuits. The larger of the two with 40 liters of cooling water has three coolers in the front section of the car, to keep the engine at operating temperature. The second circuit, called the low-temperature system, has a separate water pump and contains 15 liters of cooling water. These are used to cool, by up to 130 degrees, the charged air, heated during compression in the turbochargers, in two heat exchangers mounted on the engine. The cooled, charged air then passes through two “air manifolds” into the combustion chamber, which it then leaves as exhaust gas at approximately 1,000 degrees. It then passes through the turbines of the exhaust gas turbochargers. This causes the exhaust gas to expand, so that it is cooled by up to about 150 degrees, is then cleaned in the catalyzer and exhausted.
In addition to its unique compactness, the high performance of the power unit is the centrepoint of the development. Lightweight materials are used that not only result in a low power-to-weight ratio but also particularly provide the spontaneous response of the moving engine-internal masses. In addition
to piston rods of titanium, the so called “easy runners”, the eight-stage oil pump integrated into the crankcase for dry sump lubrication has light aluminum gears. Because the arrangement of the 16 cylinders ensures extremely quiet running, only a small flywheel is needed. The use of motor sport technology is evident not only from the plasma-coated running faces of the cylinders but also by the use of high-strength steel for the shafts and gears in the aluminum crankcase.
Unique in engine design is the integration of knock and misfiring detection in an ion current system. Because the multiplicity of cylinders means very quiet running and ensures that the velocity difference will be extremely small in the event of a cylinder misfire, cylinder-selective detection by measuring rough running is not reliable enough. Therefore, Bugatti Ion Current Sensing (BIS) is used. The ion
current flowing at each spark plug at the timepoint of ignition is monitored by a separate evaluation sensor system. The data obtained is passed to both engine control units. If knocking combustion or a misfire is detected, the associated control unit immediately initiates countermeasures, such as retardation of the ignition timepoint, shutdown of the cylinder or reduction of the charge pressure. According to the head of Bugatti Unit Development Gregor Gries, “The aim of our technology is to generate the maximum performance from the engine in a stable, clean manner”.
The power generated in the engine is transferred to the flange-mounted direct manual gearbox (DSG). The torque and speed is then transmitted, through the gearing of seven forward and one reverse gear, via a universal drive to the front axle gearbox and via a second universal drive, along the right side of the engine to the rear axle gearbox. Both the DSG and both axle gearbox housings are of lightweight aluminum construction. The drive power is distributed to the front and rear axles by means of a Haldex coupling, an actively-controlled multi-disk, inter-axle lock directly connected to the front axle gearbox. The following front axle differential distributes the power to both front wheels. In the rear axle differential the power is distributed to the rear wheels via a bevel gear and a further differential. In addition, an actively-controlled, hydraulically-actuated, multi-disk differential lock is installed here. When necessary, it prevents speed differences between the rear wheels and ensures optimum directional stability when accelerating and when cornering under load. All load distribution functions are completely automatic and are undetected by the driver.
The Bugatti marque has since earliest times been regarded as a central force in the advancement of automobile development by innovative solutions. A position deservedly maintained by the first high-performance sports car of the modern Bugatti.
Old Oct 18, 2005 | 01:01 PM
Yumcha's Avatar
And here's a nice driving impressions article (thanks, Stapler!):
http://www.channel4.com/4car/road-te.../veyron-2.html
Old Oct 18, 2005 | 01:11 PM
Scribesoft's Avatar
Aaaarrrggghhhh!
For anyone who's interested, I think there's an article in the November 2005 issue of "Automobile" magazine. Read it while at the dentist office yesterday. Very interesting technology. I'm very impressed with the car overall... Very unimpressed with the $$.
Old Oct 18, 2005 | 01:20 PM
phile's Avatar
Pinky all stinky
Color combo is :busted:
The interior is the epitome of VW's attention to detail when it comes to interiors.
Old Oct 18, 2005 | 01:23 PM
phile's Avatar
Pinky all stinky
Yes, that Impala owner is just waiting to upgrade!
Old Oct 18, 2005 | 01:51 PM
Moog-Type-S's Avatar
The sizzle in the Steak
Awesome car!
Far from ugly.
Old Oct 18, 2005 | 02:08 PM
Yumcha's Avatar
Originally Posted by Moog-Type-S
Awesome car!
Far from ugly.
Far from cheap too.
Old Oct 18, 2005 | 02:22 PM
Originally Posted by Yumchah
Far from cheap too.
Far from slow.
Old Oct 19, 2005 | 01:23 PM
invincible569's Avatar
Always loved Bugatti's! Its definitily unique to everything else you see!
Old Oct 19, 2005 | 01:55 PM
dom's Avatar
dom
<-- unimpressed
253 MPH doesn't impress you?
Old Oct 19, 2005 | 02:16 PM
jz-97-c7's Avatar
givin the business
beautiful car...that two tone doesn't do it for me, i'd love to see it in all black or silver
Old Oct 19, 2005 | 02:18 PM
Yumcha's Avatar
Nope. A jet goes faster.
Old Oct 19, 2005 | 02:30 PM
West6MT's Avatar
I think it looks good in black/red and black/yellow. Here is a pic of it in black and red that I got somewhere a while ago.
http://img190.imageshack.us/img190/9...eyron098fb.jpg
I have a few vids of the car driving on my comp,.....not too fast or anything its just testing etc,....inside view,.....no idea how to host them anywhere though,......sort of not worth it anyway.
Old Oct 19, 2005 | 03:29 PM
ludachrisvt's Avatar
Wants an M3 in
"you shoooow is ugly" *cackle*
Old Oct 19, 2005 | 04:27 PM
The McLarenF1 did 240 nearly a decade ago.
Has anyone even confirmed this speed yet or is it still just theoretical calculations
Old Oct 19, 2005 | 06:34 PM
West6MT's Avatar
I did read a few weeks ago that the Veyron did beat the Koenigsegg CCR's speed record that was set earlier this year. Link to the video http://www.koenigsegg.com/movies/index.asp
I forget where I was reading about the Veyron, but here is an article from Autoweek that does say the car will go 250mph. http://www.autoweek.com/article.cms?articleId=103261
If you go to the Bugattie website and go to the news section, you can read about how it broke the 400kph barrier,..which is 248MPH. Cant give you link because of how the website was set up.
Old Oct 19, 2005 | 06:43 PM
West6MT's Avatar
I agree the McLaren is an incredible car to achieve what it did so long ago. What makes the bugatti special is in how quickly it reaches its top speed. If you read the Autoweek article it describes how much faster the Veyron gets to 186mph compared to a Carerra GT,.no slouch of a car by any means (16sec vs 34 sec).
Old Oct 19, 2005 | 06:57 PM
From the autoweek article
Although the times are yet to be independently verified, Bugatti claims its new two-seater will hit 62 mph from a standstill in 2.5 seconds, 125 mph in 7.3 seconds, and amazingly, given it tips the scales at a rather portly 4300 pounds, 186 mph in just 16.8 seconds. The words “battering ram” come to mind.
And the Bugatti website provides no video. Or other source to confirm the speed. I couuld go to the TOV site, but I don't speak German, so that would get me nowhere.
I'll admit, the numbers ain't bad, but slap 4 turbos onto 16 cylinders and what do you expect? Plus the car is a pig at 4300lbs.
Old Oct 19, 2005 | 08:17 PM
West6MT's Avatar
Agreed,...I wasnt trying to dismiss what you were saying or anything,.dont think that. I am looking forward to actually seeing some video of this thing on the road in a road test situation. I do have a video of one of the test cars going around a track,..but its nothing too special,....sounds pretty cool.
I will see if I can dig up where I was reading about it actually being confirmed going over the McLaren/and Koenigseggs speed records.
What is TOV?
Old Oct 19, 2005 | 08:33 PM
What is TOV?
I understand
I have no doubt this car will eclipse all previous records, but not everything is about going fast in a straight line.
I like the video of the only Veyron (a single prototype at the time) nearly plowing into the wall on the back straight at Laguna Seca Bet the guy driving shit his pants
And I messed up, its the TUV. Its an independent testing company. They actually do have a site in english, but it doesn't seem like there is any info on their site about this.
Old Oct 19, 2005 | 08:55 PM
West6MT's Avatar
I understand
No info eh,....thats weird. You couldnt be more right about speed not just being a straight line thing. I think it will be interesting to see how fast the car is through corners,....how it does on a skidpad and all of that. It does weigh a lot, but I suppose the AWD and MASSIVE tires would help move that heavy load around. R&T needs to do a road test on it,....cause thats the only car mag I usually read in print form. Or something online,....with some vids would be good haha.
I think the McLaren F1 is so crazy because of what it accomplished so long ago. For me, I will always like the Bugatti EB110,......a car I liked as a kid growing up (have the R&T mag with it declared as the fastest car ,..at the time), and I still have the model up on my shelf along with my Mercedes CLK GTR racers. I do like this new Bugatti as well though,....haha,..how could you not.
MetalGearTypeS
Aug 29, 2016 08:28 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
ROWDY621
Sep 30, 2015 03:20 PM
San Yasin
Sep 29, 2015 10:52 AM
adreano17
Sep 29, 2015 08:48 AM
