Balljoints
Old Jul 28, 2009 | 11:49 PM
Gnate's Avatar
Custom User Title
Balljoints
Could my balljoints being shot to shit lead to lots of play in my steering wheel and loud noises everytime I go over bumps??
Old Jul 28, 2009 | 11:56 PM
teranfon's Avatar
Moderator Alumnus
What type of vehicle is it?
Terry
Old Jul 29, 2009 | 12:00 AM
Gnate's Avatar
Custom User Title
97 CL, i just thought it would be a good enough general question.
Old Jul 29, 2009 | 12:09 AM
teranfon's Avatar
Moderator Alumnus
Clunking, perhaps. In fact I seem to recall reading somewhere that 1997 Acuras (can't recall type) had a recall to correct the lower balljoints.
The play in the steering wheel is most likely something else. I would check the steering box first to determine if this is the problem.
Terry
Old Jul 29, 2009 | 12:12 AM
Gnate's Avatar
Custom User Title
The clunking only started after I had polyurethane bushings installed. But other members with the same setup said they had no thumping/squeaking problems.
Old Jul 29, 2009 | 12:57 AM
v6cord2k5's Avatar
seizure force field!
Faulty install perhaps?
Old Jul 29, 2009 | 01:02 AM
Gnate's Avatar
Custom User Title
It has to be, but they keep telling me with any polyurethane bushing there will be squeaking, i'm gonna make them take it for a spin tomorrow!
Old Jul 29, 2009 | 02:50 AM
Costco's Avatar
are they aftermarket, and are they grease-able bushings? Check to see if it has a nipple around it somewhere, then see if they can grease it up with marine grease....
and bad ball joints can cause the clunking.
Old Jul 29, 2009 | 07:35 AM
dallison's Avatar
registered pw
but, since you were in the area i would double check tightness on everything.
Old Jul 30, 2009 | 11:44 PM
SodaLuvr's Avatar
Get a prybar and pry up against the ball joints. There should be zero play.
Make sure you raise the car before doing this test though.
Old Jul 31, 2009 | 12:57 AM
Gnate's Avatar
Custom User Title
It could also be my steering rack i've been told
Old Jul 31, 2009 | 12:59 AM
SodaLuvr's Avatar
Didn't even read the original post...oops.
Play in the steering can also be caused by problems with the tie-rod ends. Grab the tire at the 9 and 3 positions (with the tire off the ground) and try to rock it from side-to-side. If there's any play, look for loose outer or inner tie-rod ends.
Old Jul 31, 2009 | 09:07 AM
hANDYcaptd's Avatar
It's the Halladay season!
But since it started after the bushings installed, I'd check if they're greased and tightened. Mine did the same this. Clunking noise. Then check tie rod ends like SodaLuvr said. And while you have it jacked up, check ball joints in the same way, except grab tires at 12 and 6 positions.
Old Jul 31, 2009 | 09:57 AM
SodaLuvr's Avatar
Rocking your tires at the 12 and 6 positions will tell if your wheel bearings have any play. While it is an important inspection, it will not tell you the condition of your ball joints. To check your ball joints, you really need to use a prybar and pry against the ball joints to check for any play. Also, you should use a flashlight and examine every bushing carefully for any cracks.
YL Al
Nov 23, 2009 05:50 PM
Acura2g
Sep 26, 2009 11:14 PM
VoLLy
Jul 28, 2009 01:22 PM
acuratl_2nr
1G CL Problems & Fixes
Dec 25, 2007 01:57 PM
NitiNiteZ
Sep 14, 2005 04:36 AM
