Auto Start/Stop Discussion Thread
Old Jun 27, 2017 | 07:49 AM
  #41
KaMLuNg's Avatar
Originally Posted by Sarlacc
When I pull into intersections I always keep my wheels straight for safety, I don't turn until I'm clear.
i do the same... just in case someone rear ends me, it doesn't push me into oncoming traffic...
Old Jun 27, 2017 | 09:05 AM
  #42
Originally Posted by fsttyms1
The single hardest moments for an engine/bearings are the shock at startup
Not sure on others, but the Fords with auto s/s, they say to let sit at least 15-20 minutes before draining the oil. Guess it must do something to hold oil in the block, rather than immediately draining to the pan
Old Jun 27, 2017 | 10:54 AM
  #43
It takes a while for the oil to drain down into the pan after a stop. I agree for long duration stops though.
Originally Posted by Costco
I mentioned above that the Prius and other hybrids do not have a starter. They (Atkinson cycle) also operate different than most automotive combustion engines (Otto cycle). I don't know what the difference is in regards to wear and tear, but without a doubt it is higher than otherwise. Whether it is an issue or not, I don't know either.
It could be one of those things that is a new issue entirely, or maybe not at all. I am sure the manufacturers designed things with the start stop in mind, but...
There's no difference between atkinson and otto for start/stop behavior. It's basically a variable cylinder volume and valve timing mechanism.
Hybrids dont use the starter to get the motor spinning, They use the electric motor attached between the trans and engine to get the motor spinning before there is any combustion detonation like during a start up, which also gets the oil pump spinning and lubricating.
One can do this with an uprated starter motor too.
Old Jun 27, 2017 | 11:44 AM
  #44
JT4's Avatar
JT4
CTSV,TL, Audi Q7 & A5SB
Originally Posted by kurtatx
Correct. In Dynamic mode, Engine Start/Stop is disabled. I just can't bring myself to drive in dynamic all the time.
I can....
Old Jun 27, 2017 | 01:01 PM
  #45
Originally Posted by JT4
I can....
Not sure the similarity, but I'd definitely drive my truck in Sport, if I could get it to go into 6th gear at a lower speed.
Old Jun 27, 2017 | 01:24 PM
  #46
JT4's Avatar
JT4
Dynamic puts the trans in sport and tightens up the steering..
Old Jun 27, 2017 | 01:43 PM
  #47
kurtatx's Avatar
Azine Jabroni
On the A4, the transmission doesn't go into 7 in Dynamic
Old Jun 27, 2017 | 01:57 PM
  #48
Jeep doesn't go past 6th in sport mode, it's very clear that the sport mode is a definite afterthought that's not really meant to be used all that much. Super jerky and weird throttle response, transmission shift pattern is odd, etc...
S2000, on the other hand, is permanently in sport mode all the time and will go into whatever gear I want whenever I damn well please.
Old Jun 27, 2017 | 02:49 PM
  #49
^ That is one thing I much prefer with the F150 over the Flex. In the Flex, Sport (shift below D on the trans) it locks out 6th gear & shifts a little later & will hold a gear of throttle if you're being a bit more aggressive.
In the truck, it sharpens the throttle response & doesn't lock out any gears, but you have to be doing something like 65mph to get 6th gear..
Old Jun 27, 2017 | 05:39 PM
  #50
Saintor's Avatar
In my commute, more annoying than anything. When it stops, most of the time it will restart within 5-8s. Hate it. This is why, combined with throttle response, I use S mode most of the time,
Old Jun 27, 2017 | 05:42 PM
  #51
kurtatx's Avatar
Azine Jabroni
5-8 seconds? What?
Old Jun 27, 2017 | 06:27 PM
  #52
oonowindoo's Avatar
I asked the dealer to permanently disabled mine in my F30 335 (when BMW somehow set the default as Always On in 2013)
I manually turned mine off in my 4 series when i picked up the car from the dealer on Day 1. i think the only time i used it was i accidentally pressed the Eco button.
My issue with auto start/stop is the engine and starter wear is not worth saving $20 every year on gas...
Car manuf. does it to comply with EPA regulations and that is all there is to it.
Old Jun 27, 2017 | 06:28 PM
  #53
oonowindoo's Avatar
5-8 seconds? What?
His start/stop is to put it in Park and manually turn off the car and turn it back on at the light.
Old Jun 27, 2017 | 06:35 PM
  #54
kurtatx's Avatar
Azine Jabroni
Who else but Saintor?
Old Jun 27, 2017 | 06:36 PM
  #55
Saintor's Avatar
5-8 seconds? What?
What, WHAT?
What part didn't you get in "When it stops, most of the time it will restart within 5-8s."
Old Jun 27, 2017 | 06:38 PM
  #56
kurtatx's Avatar
Azine Jabroni
Originally Posted by Saintor
What, WHAT?
The part where we're talking about the response time it takes to restart the vehicle, you imbecile.
Old Jun 27, 2017 | 06:41 PM
  #57
Saintor's Avatar
I wrote, throttle response, as another reason to use S mode, totally different from the auto Start/Stop.
Easy on drugs, please.
Old Jun 27, 2017 | 07:26 PM
  #58
Sarlacc's Avatar
The Third Ball
with the x3 you can customize settings. So, default sport mode is stiffer suspension and more aggressive shifting. But I set it up so when I push the button for sport I just get the stiffer suspension. If I want the shifting, too, then I just flip the shifter to the left. I actually like how they implemented that.
Old Jun 27, 2017 | 07:28 PM
  #59
Sarlacc's Avatar
The Third Ball
do some research because my understanding is "sport" mode on the jeep is more for towing than actual sport driving. So how you set the shifter is different than what you think.
Old Jun 27, 2017 | 07:40 PM
  #60
RDX10's Avatar
Then perhaps they should have called it tow mode rather than sports mode? :idea:
Old Jun 28, 2017 | 09:27 AM
  #61
I think your flawless automobile is broken if that's the case. It should only turn back on if it needs the engine for something. Either that or you're only stopped for 5-8s.
Mine has a lifetime bumper to bumper warranty so IDGAF about the starter or engine failing at this point lol.
My guess is that this has been tested quite extensively before putting it into mainstream cars. I'd definitely buy that BMW doesn't care beyond the warranty period but other makes like Honda and such definitely do. If all those cars started to eat engines and starters as a result would really tarnish their rep and would likely result in a class action. Either way, the testing that goes into a lot of these things is insane and I wouldn't worry about it.
Huh? I think you're talking about the range select thing on the shift knob? Yeah that's not at all what most people think it is, all it does is set the max gear the trans can be in. I never use it because it's pretty worthless unless off road to aid with hill descent. The sport mode on the knob is a different story though, it changes the AWD to rear bias, makes the throttle super touchy, and holds gears far too long. It definitely works, just not well but that shouldn't really come as a surprise.
Old Jun 28, 2017 | 10:08 AM
  #62
Sarlacc's Avatar
The Third Ball
No, mine was only FWD so I didn't have any of that stuff.
But if I remember reading the forums correctly because I always thought the sport shift sucked, that when you move the shifter to the left and select gears, you're basically telling the jeep what range of gears you want it to use, as opposed to "driving auto-manually" So like if you blip it to 5...the jeep won't shift higher than 5th gear, and it was supposed to be used in conjunction with towing.
This was all when I had first got ours, so it was still 2014 and everything was still new.
Old Jun 28, 2017 | 10:14 AM
  #63
Yup, that's exactly what it does but for mine, it's mostly for off road use to make sure it doesn't go past a given gear when going downhill in order to maintain speed with engine braking. For that, it's quite useful. For everything else, it's pointless.
My dial looks like this, if you had FWD then you didn't have this dial:
Old Jun 28, 2017 | 11:14 AM
  #64
JT4's Avatar
JT4
Same here, if I want I can customize the settings by putting the Drive Select in "Individual" mode. So for example I can have a softer suspension, with more aggressive steering. And like you if I want more aggressive shifting I just pull back on the shifter. I find I use this more, my wife prefers the Auto setting..
Old Jun 28, 2017 | 11:44 AM
  #65
dallison's Avatar
registered pw
Originally Posted by RDX10
That's exactly what comes to mind with these systems. I can't be saving more than a few cents with this gimmick, I'm certain the cost of starter motor replacement would outweigh the savings.
I didn't even think about that, or I mean I didn't even think they would be STUPID enough to lock the steering column too. So your telling me that the engine turns off and the steering wheel locks at intersections in some cases? What a load of bull.
And don't forget the extra battery in some cases.
Old Jun 28, 2017 | 05:48 PM
  #66
Saintor's Avatar
Smile
That is correct.
you 1
kurtatzxyzzxz 0
Old Jun 30, 2017 | 09:52 AM
  #67
Booya4139's Avatar
i turn it off in the MDX each and every time i start the car. Annoying. I told my wife when she brings it in for service to just have it permanently disabled.
Old Jun 30, 2017 | 01:19 PM
  #68
oonowindoo's Avatar
It does not remember the last setting? that is what happened in 2013 BMWs... annoying as fuk. They changed it to remember the last setting in in 2014.
Old Jul 1, 2017 | 10:24 AM
  #69
Sarlacc's Avatar
The Third Ball
Its like my Durango...it defaults to ECO mode on start up, which I hate. And the 2015 and newer actually have memory, so once its off, its off.
But its 2nd nature now to turn the car on and turn off the ECO, I don't even think about it anymore.
Old Jul 1, 2017 | 02:22 PM
  #70
kurtatx's Avatar
Azine Jabroni
I don't know what ECO means in Durango terms but if my wife's CR-V started in ECO all the time I would be pretty disappointed.
Old Jul 1, 2017 | 02:43 PM
  #71
Sarlacc's Avatar
The Third Ball
less agressive shifting. Makes it feel sluggish.
Old Jul 5, 2017 | 05:34 PM
  #72
oonowindoo's Avatar
That is it?
BMW's ECO mode is dangerous to public safety IMO.
Old Jul 5, 2017 | 10:47 PM
  #73
Sarlacc's Avatar
The Third Ball
That is it?
Thats it. And I know....I tried to once...never again.
Old Jul 6, 2017 | 02:54 AM
  #74
RDX10's Avatar
I didn't even think about that. Yeah that too. So I remain at my original position. Start stop is a major gimmick.
Old Jul 6, 2017 | 08:22 AM
  #75
Not sure about others, but mine has a quite large AGM, $$$ to replace compared to a standard battery.
Old Jul 6, 2017 | 01:00 PM
  #76
RDX10's Avatar
Would you beleive me if I told you the 2007+ X5 has a monsterous battery (literally like double the size of a standard one) and in order to change the battery, you have to go to the dealer in order to reprogram the new battery?!?! Holy crap! So a battery change is like a $500 cost. Hell no.
Old Jul 6, 2017 | 01:27 PM
  #77
Pass. Both of my '82 diesel Mercedes had a massive battery, but they were old HP-less but torquey diesels.
Old Jul 6, 2017 | 09:07 PM
  #78
DaIll1's Avatar
Will a slight power-brake override the auto shut-off?
Old Jul 7, 2017 | 12:01 AM
  #79
oonowindoo's Avatar
there are many ways to over ride it... slightly releasing the brake pedal, turn the steering wheel, turn on sport mode and a few more i think. For stick, if i you leave it in first or neutral+ clutch then auto off wont engage.
Old Jul 8, 2017 | 01:24 PM
  #80
Costco's Avatar
Had a Chevy Cruze rental the other day, wasn't my choice. But it had a particularly annoying system.
You can't disable it. At all.
The only way you can override it is by putting it in L (basically sport mode for shift logic only) then pressing up to select the highest gear you want to allow. Nobody would know that without researching it.
