another Vortech install (03 G35 coupe)
fastest time 13.4@107 !!!
for those of you that remember we did the install on zimbo's G35 sedan, zimbo posted pics with before and after dyno sheets... our new project is a G35 coupe (dollar 99) jimmy drove all the way down from Maryland yesterday to have us install and tune the vortech kit on his car. we will post lots of pics before and after with dyno sheet too..
here is the base line dyno sheet.... mods in this run are, intake,exhaust,grounding kit...
Originally posted by Chaptorial
Thats a lot of power for being semi stock. What kind of gains does the intake and exhaust give on a G35c?
I'm guessing this is MT too right?
intake and exhaust sould give about 10-15hp
a gain of approx 15hp and approx 50 ft-lb of torque?
the increase in torque is great! But how come the increase in hp is so low?
the increase in hp on the cl is about 40-50 hp.
i'm just curious as to why the numbers are the way they are, i'm not tryin to say this is bad or anything, just tryin to be more understanding of the dyno and the setup.
Thanx!
Thanx!
Where'd ya get the 50tq from?
sorry, i meant approx 40 ft lbs, i compared the highest base dyno run to the after dyno run that he had mentioned.
the highest base run was about 232, and the after dyno run was 277 so we get 277 - 232 ~ 45 ft lb torque increase
Originally posted by Scrib
:sqnteek:
You need to get your eyes checked.
Unless I'm not seeing another dyno graph..
:sqnteek:
i mistakenly saw the 250 hp and 277 ftlbs of torque in the sig and thought that was what they dyno'd after for the g35
sorry for the mixup, i'll go kick myself now.
sorry to hijack
fastvtec, dont kno how if you saw this http://www.v6performance.net/forums/...0&pagenumber=1
or
http://www.v6performance.net/forums/...958&forumid=81
...slap on 200
or
...slap on 200
Re: another Vortech install (03 G35 coupe)
From what I've been able to gain, exhaust and intakes on the G don't do squat.
Originally posted by '03TLP&'03ACCRD
mmmm..... I think they dyno 226whp stock, so the I/E definitely added like 12whp. Not bad. However, It looks like it causes the car to run really lean. The ecu's way of reacting to the mods. Maybe this is why so many engines blew up. They added breathing mods, after boosted applications, causing the immediate lean condition. Hmmm..... if this guy were to stay N/A I would like to see the car tunned with safc-2, to correct that 14.1!
Originally posted by darrinb
stock ones put down about 230 right, seems like they dont benefit from mods as much as us
Originally posted by blubyu2k2
they range from 225-245 its mainly how the dynos calibrated.
Administrator Alumnus
right, so we really need before and after dynos from this same dyno to really tell that he's not making any power from I/E. All this is speculation at this point.
So why you're trying to stir up the pot, I don't know.
Originally posted by jtkz13
Thats because you have an excess of low end tq. Most people just look at the peak numbers, which in reality dont mean a whole lot.
I ran a 13.72@99.9 on my 18's and my best motor dyno is only 224whp...
I see what you're trying to do and it won't work. You should know by now by trolling all the G boards that the VQ doesn't really benefit from intakes, exhausts and especially headers.
http://www.nissanperformancemag.com/projects/350z.php
there are so many dynos on the engine section of my350Z.com its not even funny. i/e/h, and people see 244, 255+whp, no problem. You can't just assume that i/e on any given car "does nothing". In order to back that up with factual data, dollar99 would have to do before and after dynos to evaluate the effect on power the mods, as he put them on. If you want to believe that the modded numbers are stock, because it makes you sleep better, at night then fine. but when the engine is breathing differently there will be a change in #'s. just look at his a/f ratios.
how does the vq engine benefit from aftermarket cat backs compared to our cars??
well the coupe made 359whp and 305tq at 8psi. The timing was retarded approx 6 degrees at full boost and was tuned to about 11:5:1 across the board so this thing should be safe as a non boosted VQ. Now if only Procharger could settle there timing issues it would be all set.
Mods on the coupe were Vortech Sc'er, Exhaust, and grounding kit.
