2006 TechArt 911 Turbo
One of my dream cars....
engine Aluminum M96/70S Flat-6
position Rear Longitudinal
aspiration Borg Warner Variable Turbine Geometry (VTG) Twin Turbos
valvetrain DOHC, 4 Valves per Cyl
fuel feed Bosch Motronic DME 7.8 Fuel injection
displacement 3596 cc / 219.4 cu in
bore 100 mm / 3.94 in
stroke 76.4 mm / 3.01 in
compression 9.0:1
power 432.5 kw / 580 bhp @ 6000 rpm
hp per litre 161.29 bhp per litre
bhp/weight 358.69 bhp per weight
torque 700 nm / 516.3 ft lbs @ 4850 rpm
drive wheels 4WD w/PSM, PTM
body / frame Unit Steel
front brakes PCCB Ceramic Discs w/Brembro 6-Piston Calipers, ABS
f brake size 350 mm / 13.8 in
rear brakes PCCB Ceramic Discs w/Brembro 4-Piston Calipers, ABS
r brake size 350 mm / 13.8 in
front wheels F 50.8 x 21.6 cm / 20 x 8.5 in
rear wheels R 50.8 x 30.5 cm / 20 x 12 in
front tire size 245/30 ZR 20Continental Sport Contact 3
rear tire size 325/25 ZR 20 Continental Sport Contact 3
steering Rack & Pinion w/Power Assist
f suspension MacPherson Struts w/Lower Control Arms, Coil Springs, Gas Pressurized Twin-Tube Shock Absorbers, Anti-Roll Bar
r suspension Multi-link w/Coil Springs, Single Sleeve Gas Pressurized Shock Absorbers
weight 1617 kg / 3565 lbs
wheelbase 2350 mm / 92.5 in
front track 1490 mm / 58.7 in
rear track 1548 mm / 60.9 in
length 4450 mm / 175.2 in
width 1852 mm / 72.9 in
height 1300 mm / 51.2 in
transmission 6-Speed Manual or 5-Speed Tip-Tronic
top speed 339 kph / 210.6 mph
0 - 60 mph 3.4 seconds
compression 9.0:1
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
