2005 MV Agusta F4 S 1 1 (pics)
had to share this baad azz bike with you. btw it's for sale. don't know what the last pic is, not sure if it was painted a different color or what..
http://adcache.cycletrader.com/5/0/6/68296906.htm
yeah the black one is bad azz...
also the Senna version is pretty nice too
more pix these are too large to post inline...
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202003%20F4%20SPR%20(2).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202004%20F4%201000%20S%201_1%20(6).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202004%20F4%201000%20S%201_1%20(7).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202004%20F4%201000%20S%201_1%20(8).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202004%20F4%201000%20S%201_1%20(4).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202004%20F4%201000%20Tamburini%20(1).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202004%20F4%201000%20Tamburini%20(2).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202004%20F4%201000%20Tamburini%20(3).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202004%20F4%201000%20Tamburini%20(4).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202003%20F4%20S%20(1).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202003%20F4%20S%20(2).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202003%20F4%20S%20(7).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202003%20F4S%201+1%20(1).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202003%20F4S%201+1%20(3).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202003%20F4%20Ago%20(1).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202003%20F4%20Ago%20(3).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202003%20F4%20Ago%20(10).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202003%20F4%20Brutale%20serie%20oro%20(1).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202003%20F4%20Brutale%20serie%20oro%20(3).jpg
http://www.mvagusta.com.au/2004photos/hires/MV%20Agusta%20-%202003%20F4%20Brutale%20serie%20oro%20(11).jpg
that silver and blue is sexy
Originally Posted by Chaptorial
Very unique looking bike.
What are the specs?
What are the specs?
http://www.mvagusta.com.au/2004models/mv_f41000s11.html
Engine:
4 cylinder, 4 stroke, 16 valve, DOHC with radial valve
Displacement:
998cc
Compression ratio:
12:1
Starting system:
electric
Bore x Stroke:
76 x 55
Max power:
122 kW (166 hp) at 11,750 rpm – Lim 12,700 rpm
Max torque:
109 (Nm) at 10,200 rpm
Cooling system:
liquid cooled with oil heat exchanger
Engine management:
Weber Marelli 1.6M ignition - injection integrated system, induction discharge electronic ignition, Multipoint electronic injection
Clutch:
wet, multi-disc
Gearbox:
cassette gearbox, 6 speed, constant mesh
Frame:
CrMo steel tubular trellis (TIG welded)
Front suspension:
upside-down telescopic hydraulic fork with rebound-compression damping and spring preload adjustment 49mm diameter
Rear suspension:
progressive, with single sided swingarm, single shock absorber with rebound-compression( High speed / Low speed) damping and spring preload adjustment
Front brake:
double steel floating disc, 310mm diameter, 6 piston caliper
Rear brake:
single steel disc, 210mm diameter, 4 piston caliper
Front tyre:
120/65 - ZR17 inch
Rear tyre:
190/50 - ZR17 inch, or 180/55 - ZR17
Fairing material:
thermoplastic
Wheelbase:
1408mm
Seat height:
810mm
Min ground clearance:
130mm
Dry weight:
193kg
Fuel tank capacity:
21 litres
Originally Posted by UNCTYPE-S
dont mind my illiterateness on bikes, but whats so special about them.
Originally Posted by evilone
http://www.mvagusta.it/2003mvagusta/images/f4spr/F4_SPR_5_1024.jpg
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
Joe Avesyan
09-29-2015 03:57 PM
MrHeeltoe
09-28-2015 05:43 PM
