2003 Honda Civic HID lights
I would like to find out the type of bulb that is in my wife's 2003 Honda Civic. Is it an H4 bulb? Does that mean that both the high and low beams are coming from the same bulb? If I get an HID kit, will I have to get a bi-xenon kit for her? Can I get an HID kit that has HID lights for the low beam and the halogen filament for the high beam, all in the same bulb?
Originally Posted by supraken
I think up until 2003 (before the 2004 refresh), the Civic used a 9003/H4 dual filament bulb.... So yes, you would need a bi-xenon setup to preserve the high beam.
If I did not want Xenon for the high beam, could I just get a dual purpose bulb, one that has xenon (HID) lighting for the low beam and a halogen filament for th high beam?
Originally Posted by daemonicus
i've never heard of a xenon/halogen bulb for the lo/hi beams. if in fact your wife's car takes the H4 bulb, you could easily get a bi-xenon bulb because the H4 is the only bulb that has it available. unless you live in a very dark, secluded area though, i wouldn't recommend getting a bi-xenon kit. i have an H4 kit without the hi beams and i've never once wanted to use them, the low beams are definitely bright enough.
Originally Posted by AMGala
Go to sylvania.com and choose automotive lighting. There you can choose your car and it will list all of the bulbs that are in the car.
fap fap fap
i have an HID kit for my xB. its has the dual bulb ur lookin for. low beams HID, high beams are halogen. also comes with a relay & fuse. works great ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
check here http://www.scionlife.com/forums/viewtopic.php?t=152060
Lamborghini Aventador FTW
No dice. It just lists the Civic 3-door, which is the SI version. I don't think the headlights are the same for the 2003 Civic LX sedan...
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
2003 HONDA Civic Exc. 3-dr.
High & low beam headlamp
9003
9003ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9003XV XtraVision Halogen Upgrade: Up to 30% Brighter
9003CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
168
7443
Front turn signal
7443
Rear turn signal
7440
Tail light
168
7443
Stop light
7443
High mount stop light
7440
License plate
168
Back up light
7440
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Cornering
7440
Front sidemarker
7443
Rear sidemarker
7443
Map light
168
DE3175
Dome light
578
DE3175
Trunk/Cargo area
168
If all else fails, just go remove the bulb from your wife's car and read the model off of it.
saberlove
03-11-2021 09:29 AM
