2003 Eclipse RS Drum Brake Help Requested
Old Apr 12, 2007 | 11:22 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
hey guys. i'm pretty sure this is the right forum but if not someone let me know and i'll repost.
i consider myself a pretty decent amateur mechanic. i've shimmed valves, dropped gas tanks, replaced whole suspensions, replaced a transmission sensor here and there, yada yada, but i just never, ever could bring myself to do a drum brake job. yes i know, it's ridiculous.
so here's the scoop. my girlfriend's 2003 eclipse RS needs new rear brakes and i personally don't find the mitsu shop manual very helpful. i could use a little help with a good DYI with photos or direct experience if anyone has it. also, would i be better off buying a new hub or just replacing the pads? (provided the existing hub isn't damaged or anything).
for those of you who are wondering i did troll a few eclipse forums but i just couldn't find what i needed. everyone was more interested in the drum to disc conversion it seems.
thanks in advance!
Bob
Old Apr 12, 2007 | 02:22 PM
daemonicus's Avatar
club3g has everything you would ever need to know about eclipse's. the amount of info on there is 10x what you could find on here.
www.club3g.com
Old Apr 12, 2007 | 09:59 PM
gtg710w's Avatar
06 GBM AT TSX + 35% TINT
what is drum brake?
Old Apr 12, 2007 | 10:26 PM
Will Y.'s Avatar
Registered but harmless
Originally Posted by SatinSilverTypS
i consider myself a pretty decent amateur mechanic...but i just never, ever could bring myself to do a drum brake job... i could use a little help with a good DYI with photos or direct experience if anyone has it. also, would i be better off buying a new hub or just replacing the pads? (provided the existing hub isn't damaged or anything).
One way is to raise the rear end, take both drums off, and work on one side while using the other side as a guide. It's a pretty easy job; just keep tension on the springs to keep them from shooting off after disconnecting. Remember to chock the wheels and release the parking brake, etc.
Replace the pads, but turn/machine the drums as well. The machine shop, brake shop or auto store that turns the drums will let you know if the drum(s) need replacement due to insufficient thickness. That shouldn't be a problem if the pads haven't been changed previously.
Originally Posted by gtg710w
what is drum brake?
It has been a few years since any Honda had drum brakes, hasn't it??
Old Apr 13, 2007 | 06:19 AM
ChairmanMaoSaysRTFM
www.club3g.com
thanks for the help guys. i was actually on club 3g and eclipseforums.org and maybe it was the way i was searching but i couldn't find any DIYs. i'll try again, maybe i just missed them.
Hey Will Y., thanks for the tips. i might just buy all new drums and change them out because i won't be able to leave her car in pieces for more than a morning before she will need it again.
Bob
Jul 16, 2017 07:33 AM
Pham Alvan
Mar 16, 2016 09:17 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
