1334hp!!!!!!!!!!!!!!!
Old Feb 2, 2005 | 06:54 PM
stangg172004's Avatar
_____ like a rabbit
too bad the car looks like i shitted it out, just horrible!
Year: 2001
Displacement: 5.987 cm³
Power KW / HP: 995 / 1334
Torque: 1.300 Nm
Weight: 1.280 Kg
Top Speed: 400 Km/h
0 to 100 Km/h: 3.6 Sec.
0 to 200 Km/h: n/a
Length: 4.120 mm
Width: 2.080 mm
Height: 1.120 mm
Valvetrain: V12
Drive Wheels: Heck Antrieb
And this could be a repost, if it is, my bad!
Old Feb 2, 2005 | 07:36 PM
Black CL-S 4-Life's Avatar
Floyd Mayweather Jr.
My 1st time seeing it but you are right it does look like shit.
Old Feb 2, 2005 | 07:38 PM
mattg's Avatar
i like the way it looks
Old Feb 2, 2005 | 07:49 PM
sauceman's Avatar
Moderator Alumnus
Old Feb 2, 2005 | 07:56 PM
teg_to_bike's Avatar
I'm back, biatch.
I like the overall shape of the exterior, but the body panels need work. The interior is
Old Feb 2, 2005 | 08:50 PM
DownUnder's Avatar
Looks like they used the dash of a Porsche 968, and the front looks similar to the Koenigsegg. Overall it looks OK, but the power to weight ratio is whats amazing.
Old Feb 2, 2005 | 08:54 PM
jz-97-c7's Avatar
givin the business
looks like it's out the 80's...not that bad
Old Feb 2, 2005 | 08:57 PM
goldmemberer's Avatar
goldmemberererer
Old Feb 2, 2005 | 08:58 PM
goldmemberererer
Oh, and 3 more HP is all they needed to make this car 1337... a shame that they didn't go for it.
Old Feb 2, 2005 | 09:02 PM
phile's Avatar
Pinky all stinky
Answers the question: What if Saturn made a supercar?
Old Feb 2, 2005 | 11:17 PM
Lung Fu Mo Shi's Avatar
Registered AssHat
That's what I was going to say.
Old Feb 2, 2005 | 11:29 PM
Jput's Avatar
Not a big fan.
Hey back to the future called they want their car back.
Old Feb 3, 2005 | 01:11 AM
importtuner's Avatar
I think that car is teh Lotec; not sure, but it has an S600 engine twin turbocharged; badass to say the least.
Old Feb 28, 2007 | 10:03 AM
Yumcha's Avatar
Post Lotec Sirius
WYHI...?
Old Feb 28, 2007 | 10:04 AM
Yumcha's Avatar
Old Feb 28, 2007 | 10:06 AM
Yumcha's Avatar
Info from Lotec...
Manufactured from the lightest and most modern materials applied in the aerospace and automobile industries, carbon fiber composites combined with tubular steel.
The bodywork is produced from the optimum combination of carbon, Kevlar and glass fiber materials.
Engine: Mercedes 600 V 12
Position: Mid-engine
System: V-12 engine, 48 valve, double Turbo
Cylinder capacity: 5987 ccm
Bore x stroke: 98,0 x 80,2
Compression ratio: 8,5 : 1
Valves: 4 per cylinder
Turbo charging: 2 special KKK Turbo charger K 27
Intercooling: twin air - air intercooler
Lubrication: drysumplubrication
Cooling: water
Performance / horse power (variable):
0.85 bar boost: 1.000 h.p. at 6.300 r.p.m.
1.20 bar boost 1.200 h.p. at 6.300 r.p.m.
Performance / KW (variable):
0.85 bar boost: 735 Kw at 6.300 r.p.m.
1.20 bar boost: 882 Kw at 6.300 r.p.m.
Max. Torque:
0.85 bar boost: 811 lbf ft at 3400 r.p.m.
1.20 bar boost: 974 lbf ft at 3400 r.p.m.
Acceleration (km/h):
0 - 100 at 3.8 sec.
0 - 200 at 7.8 sec.
Top speed: V - Max up to 400 km/h (optional transmission)
Tachometer: up 400 km/h
Brake system front: Brembo ventilated racing disk brakes with ABS
Brake system rear: Brembo ventilated racing disk brakes with ABS
Gearbox and power transmission: 6 speed manual gearbox from CIMA, synchronized limited slip differential, transmission oil cooler
Motor-Management: LENZ Turbo-Tronic, www.lenz.de
Suspension: Independent front and rear suspension with unequal length upper and lower A-arms, coil springs, tube shocks, anti-roll, bars and power steering. Racing power brake system including ABS
Tires and Rims: 3-piece Works-Rim with
9,5 x 19" 255/40 ZR 19" front
13 x 19" 345/30 ZR 19" rear
Exterior and Interior: Free choice of colours and interior finishing, Instrument panel with circular type instruments, rev. Counter, speedometer up to 400 km/h., middle console with display for several indication functions, air conditioning, velour carpeting, sport seats and three point safety belts. Tinted glass fitted as standard. Full leather upholstery optional.
Dimensions and Weight: length: 4.120 mm
width: 2.080 mm
height: 1.120 mm
ground clearance: 80 mm
curb weight: circa 1,280 kg
No, not enough power.
Old Feb 28, 2007 | 10:22 AM
evilone's Avatar
COME AT ME BRO!
damn that thing is sick.. and with works!!
Old Feb 28, 2007 | 10:43 AM
Leviathan's Avatar
Holdin it down for MS
Beat me to it
