It's a fun shitbox
Trying to put as little $ into it as I can & keep it going.
Need to replace the FRM module so the windows/dash lights will work again. Putting it off for now. All in, it's $4-500.
Radio still inop. HK amp is a grand, but have seen a few run a JBL DSP that can be had for $2-300, that'll be the route I likely go, unless I can luck into a functioning used HK amp that'll plug & play.
But if you go headunit, your own amp, you can just tap into the speaker leads after the HK amp...
is the sound system incredible? If so, I guess just fix it right, if not, make something better for way cheaper.
No idea how the HK audio is. It's been dead since I got it. With it being a ragtop, I don't expect stellar audio as it is.
Figure a $2-300 JBL amp is the simplest route for now. And it's confirmed to work in place of the HK amp.
A nice HU with a screen & AndroidAuto would be nice, but shitbox, so not in a rush to drop much $ on it.
I'm a BMW driver for real now.
The footwell module [FRM] has gone into full fail mode.
Before when it would 'fail' I'd lose all instrument lighting, door windor control & the blinkers would work but not self cancel & there was no dash indication for them, and the reverse lights didn't work.
This would come & go with no real consistency.
That changed this week. Typical FRM fail condition, but now I have no blinkers at all.
Also, the door windows don't index, so they arent lowering that 1/2in when opening. The head/tail lights are in an always on state & no high beams. And, all of the interior lighting is now off.
Waiting on a vendor on the Mini forum to advise on the correct part to order, as there's 3, with no real indication of which is correct. Then have to get it programmed to the VIN.
I saw this parked at a trailhead with the driver sitting in it. I had a 20 minute long conversation with him about it. I couldn't believe it's a '93. He imported it from Japan. Pretty neat little car.
We passed one on our drive to Pensacola from Houston last week. My kids were shocked at how tiny it was.
I'd love a vintage Cooper. Would be even better if my Midget was a year older, as it'd share the 1275cc engine with the Mini.
Well, no go. Pulled the FRM & cleaned up the board & pins a bit more. Still no dice.
Checked the fuses that are supposed to go to it & all 4 are good.
Looks like I'll be out a few hundos to order a new FRM & get it programmed.
Was all set to order a new FRM & get it programmed locally, was going to run nearly a grand
Found a company in PA that will take the bad FRM & load the VIN/build data into a new one & send it back, plug & play
Cost me a bit over $300 less than option 1.
If this fixes all these issues, the only thing left will be getting a new amp for the HK system so the stereo will work.
the harder it is for something to look cool...the harder I work at it.
my gf has a 2025 in the new rendition of British Racing green....I put it on some overpriced H&R springs and XXR bronze wheels...
it looks SO good...also painted the calipers yellow.
@is300eater LOL...she loved the look of the new 530 in Bronze/Gold on her British Racing Green, honestly, super nice.
I don't think the XXR 530 is all that new because I had them on my Mini Cooper S 🤷 (unless I've mistaken the model number)
I missed this car, if I had the choice to keep it when I got the Subaru, I would have 😕
Got my FRM back from ECUPro. The sent me the replacement, and sent back my water damaged, failed FRM. Just installed the replacement, and everything seems to be working again. Bonus, the dome light now works [hasn't worked since I got the car], and I didn't even know there were lights in the bottom of the door panels! No lane change blinker, only get 1 blink, but that was something that came & went before, so maybe it'll get back to normal, too.
Need to pull codes & make sure the FRM code is gone, or clear it and make sure it doesn't return.
Now to give it a few days & make sure all is good, then I can start thinking about the amp replacement so I'll have a functional stereo.
I'll miss the 2022 F150 I've been driving, makes me miss having a truck, just a bit. The effortless torque from the TTV6 is quite nice, and a 1700rpm cruise at 75mph isn't bad either. The knobby all-terrain tires on it, though, nearly as noisy as the Cooper at highway speed
When I got the car, the exterior A-pillar trim was missing, thinking it was leaking in from there.
That, or the detached rear window let water travel all the way forward from there
With both of those fixed, car no longer fishbowls when it rains
